The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 28-05-2008   #1
Trader Rating: (0)
Question Reversing lights not working
Stilo 1.9JTD 02 plate - can someone please tell me where I can find the reversing light switch - exact location please as I am unsure what it looks like - any photos would be a great help - many thanks
Tivvyfan is offline
Old 28-05-2008   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Reversing lights not working
An easy double check to make sure it's the switch (and not a fuse or bad electrical contact or even duff bulbs) is to check if your rear wiper works automatically when you select reverse with front wipers on. If that doesn't work either then odds are its the switch
Name:	reversing light switch.jpg
Switch looks like this and is usually on top the gearbox
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
The following 2 users say "Thank You!" to Deckchair5 for this useful post:
fiat brava jtd elx 105 (30-08-2008), Tivvyfan (28-05-2008)
Old 28-05-2008   #3
Trader Rating: (0)
Originally Posted by Deckchair5 View Post
An easy double check to make sure it's the switch (and not a fuse or bad electrical contact) is to check if your rear wiper works automatically when you select reverse with front wipers on.
Attachment 44328
On a JTD it is on the rear of the gearbox , out towards the passenger side wheel and accessed from underneath the car with the engine under tray (if you have one) removed.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is online now
The following user says "Thank You!" to john55 for this useful post:
Old 28-05-2008   #4
Deckchair5's Avatar
Trader Rating: (0)
There you go then, lying on your back job on a JTD, got to be easy
99 Bravo 1.2SX
The following user says "Thank You!" to Deckchair5 for this useful post:
Old 28-05-2008   #5
Trader Rating: (0)
You will need a 19mm offset ring spanner 10 minute job, switch about £12 if I remember correctly.
cris1117 is offline
The following user says "Thank You!" to cris1117 for this useful post:
Old 28-05-2008   #6
Trader Rating: (0)
Thanks Deckchair5 for boths posts and John55 and Cris1117- much appreciated - now that I know what and where the switch is. Got a quote for switch from Fiat dealer around £20 - many thanks all
Tivvyfan is offline
Old 29-05-2008   #7
Trader Rating: (0)
Go to a good motor factors shop and they should have them for half that price. I just changed mine recently, bought it from fiat and then was asking about something else for the car in a local shop when they mentioned they had reverse light switches, but not the part I wanted.
Old 29-05-2008   #8
punto60_s's Avatar
Trader Rating: (0)
Thanks for this, just done mine after reading this thread took about 15 minutes and cost me around £5 for the switch from local motor factors, happy now I've got reverse lights although I cant get mine to do that mirror thing.
punto60_s is offline
Old 29-05-2008   #9
Trader Rating: (0)
That mirror thing is rubbish anyway (at least on mine) it moves a bit, but not really in a way that is very useful for reversing.
Old 29-05-2008   #10
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
whats the mirror thing?
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
Old 29-05-2008   #11
Trader Rating: (0)
When you select reverse gear, the passangers side mirror moves to a supposedly better position for reversing.
Old 23-07-2008   #12
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
I need to change my switch, can anyone who's completed the job be more specific with its location or is it really obvious, LOL
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 23-07-2008   #13
Trader Rating: (0)
It is the only wiring plug going into the gearbox so it is not like you can get the wrong one. Look up from underneath at the gearbox and you will see it on the outside end, nearest to the passengers side front wheel.
Old 23-07-2008   #14
minimad99's Avatar
Trader Rating: (0)
LOL,
yeah I found it easily in the end, easier to get to by removing the n/s wheel and the side trim.
Had to order the switch from Fiat as my local motor factor didn't have it listed and woudl take a week to get it from Lucas.
Should get the Fiat one on Fri morning, £17+VAT.
Old 1 Week Ago   #15
cme
Trader Rating: (0)
I have a 1.9 JTD 52 plate - the reversing light switch is not working - I Removed the engine tray cover but could not see any switch under the engine (passenger side) - I plan now to remove the NS wheel, will this give me access to the switch? - any diagrams would be useful - thanks
cme is offline
(T) Reversing lights not working StevenRB45 Punto 1 30-03-2008 20:33
(T) Parking sensors/Reversing Lights Not Working. jazzman Stilo 2 25-04-2007 17:08
(G) Reversing lights are not working on Sei? Its not the bulb. minidriver Cinquecento / Seicento 3 20-09-2006 18:17
Reversing lights fenderman Ulysse 2 08-03-2004 21:54
instrument lights / reversing lights fenderman Ulysse 3 17-11-2003 22:25
