The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 26-05-2008   #1
Trader Rating: (0)
connect navigation on fiat stilo
my connect system on a fiat stilo multiwagon, has completely packed up, losing all of the functions, for the phone radio set up computer trip etc, my fiat deale says the units are irrepairable, and would have to be replacedb ata cost of £1500, has anyone come across this problem, and is there a repair that can be done, my fiat deale says even when sent off for repair, because they are out of the car they will not function anyway, due to ecu lock down tyhe unit is made by magneti marelli of italy
barkus is offline
Old 27-05-2008   #2
popping out
dan-the-man's Avatar
Trader Rating: (0)
dan-the-man has donated! United Kingdom
Re: connect navigation on fiat stilo
They can be repaired, some people on here have sent them off before, not sure where they sent it so I'm sure they'll be on soon to tell you
dan-the-man is offline
Old 27-05-2008   #3
Trader Rating: (0)
Please describe the exact fault. Is the screen black, or do you just get the Fiat Logo at startup etc. I can fix quite a few problems with them.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is online now
Old 27-05-2008   #4
Trader Rating: (0)
there is no life at all just a black screen, nothing works
barkus is offline
Old 27-05-2008   #5
Trader Rating: (0)
Could just be the backlight then, but usually it will still play a CD/ radio if that is the case. Are the buttons illuminated?
Old 28-05-2008   #6
Trader Rating: (0)
there is nothing illuminated, the fiat deale says the unit is completely defunct, i have removed from car, but the speaker leads do not seem to be connecting to the speakers, so cannot even fit an ordinary radio for the time being, does anyone know if the connect unit switches the speaker leads when its in use, thanks bren
barkus is offline
Old 29-05-2008   #7
Trader Rating: (0)
The Connect Nav+ unit uses standard ISO radio connectors for speakers and power. Another stereo will plug strait in and work (I had one fitted before I replaced my CN+ unit). Why do you think the speakers do not connect?
First thing to check if the CN+ unit is completely not functioning is the power to it. If you can plug another stereo in and it powers up OK, then the CN+ is faulty. If the new radio has no power then you have a problem with the wiring in the car.
Here is the pinout for the connectors
http://www.isham-research.co.uk/quat...85/isopin.html
Connectors A and B are standard ISO pinout on the CN+ and will plug into most aftermarket stereos.
Old 29-05-2008   #8
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
a new stereo wont work directly. remember theres no ignition feed so you can join live and ignition together it shud b fine
im sorry if this is a stupid question but have you checked your power feed to it? fuses? possibly even earth
the speakers shouldnt make a difference. if this all happened all of a suden it may be one of them. go to an ice dealer and tell them to test if everything going to the unit is working fine reminding them theres no ignition feed. they can usually do this with a small battery and multimeter. if it is then i would start 2 wry about repairing but finding out the fault would be my line of thought
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
Old 29-05-2008   #9
Trader Rating: (0)
My CN+ definately does have an ignition feed. No joining of wires or changing anything required.
Old 31-05-2008   #10
Trader Rating: (0)
will you post me an adress i cann send my unit to, for repair, regards Brendon
barkus is offline
Tags
nav, repairs, sat
(T) Navigation wit connect nav+ cycloon60 Stilo 1 27-03-2008 15:13
(G) Fiat Connect Satelite Navigation MattyBoy Stilo 12 19-01-2006 11:23
(T) Connect Satelite Navigation System porterdave Stilo 1 19-09-2005 11:16
