The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-05-2008   #1
LeeStilo's Avatar
Trader Rating: (0)
audio help - new headunit
just got an aftermarket headunit fitted in my stilo but when the ignition goes off the stereo stays on :S anyone know why it does this, was there a wire out of place or is it a common problem? - its a kenwood headunit
also whats the cable with the blue plug at the end for behind the headunit, is it what connects to the dash screen? if so anyway i can connect it have this feature? thanks
My Fiat Stilo 1.8 16v Dynamic: CLICK HERE FOR THE GARAGE
Hertz set up
Clarion DUZ388RMP head unit
LeeStilo is offline
Old 24-05-2008   #2
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
Re: audio help - new headunit
because there is no ignition feed in the stilo. so the stereo doesnt know when the keys being switched on or off. and that blue wire is likely to be a remote feed for pre outs, it has no communication to the dash screen which was controlled by the multicoloured plug that is no longer connected and only works with the original one sorry to say
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
Old 24-05-2008   #3
LeeStilo's Avatar
Trader Rating: (0)
ah right cheers
i only use my ipod anyway so may look at another solution to use that and use the standard radio cassette player instead
Hertz set up
LeeStilo is offline
Old 24-05-2008   #4
*custom name*
j0nny's Avatar
Trader Rating: (0)
tbh a lot of the other aftermarket head units out there are a much better soloution. if you want it to switch on and off with the key follow this giude i pasted in this thread:
http://www.fiatforum.com/stilo-techn...o-problem.html
i done the same in my car and works a treat
j0nny is offline
Old 24-05-2008   #5
LeeStilo's Avatar
Trader Rating: (0)
cheers will check it out
Hertz set up
LeeStilo is offline
Old 24-05-2008   #6
LeeStilo's Avatar
Trader Rating: (0)
theres no chance ill be touching any wiring lol
Hertz set up
LeeStilo is offline
Old 24-05-2008   #7
*custom name*
j0nny's Avatar
Trader Rating: (0)
lmao, you have to be a bit more confident than that now.
theres no real chopping of wiring there. actually theres none at all. you simply push it in and hold it there with a bit of insulation tape. and connect it it to the stereo via the bullet connectors. simple and very worth it
j0nny is offline
(G) Audio AndyW Punto 4 31-03-2007 12:44
(G) no audio snowboardriders Punto 7 25-01-2007 19:02
Audio help! Aruffell I.C.E 0 03-10-2006 17:47
(T) Audio Help connor Bravo / Brava 1 21-06-2005 19:28
(T) Can this be done - audio FiatStiloJTD Punto 3 28-05-2005 20:10
