The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 16-05-2008   #1
02 Abarth
benmuir's Avatar
Trader Rating: (0)
benmuir has donated!
Alarm Siren Position
Alarm siren is not working and the fault is showing on the dash console on start up (Alarm Failure return to stealers). Car does not beep on locking/unlocking anymore (used to) and when you leave the window down then break the infa red field the indicators flash but no siren
1. Any idea where the siren is located on my Abarth.
2. Can you do a reset etc.
3. Is the siren seperate or all one unit.
Aw well had 2 weeks motoring without alarms suppose thats good !!
02 Abarth
benmuir is offline
Old 16-05-2008   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Alarm Siren Position
Access is dead easy once you remove the scuttle cover.
Examiner has quite a few options for testing so you might want to get it checked out first although it does sound like a defective siren to me.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 16-05-2008   #3
02 Abarth
benmuir's Avatar
Trader Rating: (0)
What is the scuttle cover ??? Argonought
02 Abarth
benmuir is offline
Old 17-05-2008   #4
Argonought's Avatar
Trader Rating: (0)
It's the black cover that hides the wiper motor & mechanism.
To remove:
  1. remove both wiper arms (be warned this can be VERY difficult)
  2. remove 3 plastic clips at front (under bonnet at rear) and then remove scuttle cover (also a bit tricky)
You might want to search on this to get a few more tips. The scuttle cover is quite tricky to replace and I'd recommend taking very careful note of how it's fitted before you remove it (assuming it's never been removed before). Make sure you get some replacement clips from your dealer as the originals nearly always snap.
vB code is On
Turn off siren? combwork Multipla 5 23-08-2007 19:09
siren?!? tommypope Spotted / Was It You? 4 14-07-2007 00:12
For Sale: RALLY STAGE SIREN (Miscellaneous) cole5x5 For Sale / Wanted 0 29-03-2007 19:01
siren replacement bulldog5046 Security 2 01-12-2006 01:25
Alarm Position tom35i Cinq/Sei > Technical 8 08-11-2004 13:41
