| Im now missing an undertray! Car went in for a MOT today, and it was found my undertray was only held on with about 3 bolts if that, mountings on the car had broke and the undertray itself has multiple fractures so is now wasted. With the mountings on the car being totalled i dont think i'll bother with a new one. Car passed its MOT- parts missing from rear brake callipers dont seem to be a problem now!
__________________ | |||
| popping out | Re: Im now missing an undertray! I thoguht the undertray was screwed into the plastic side shrouds?
| | #3 | ||
| Low Rider.............. | Re: Im now missing an undertray! My undertray hangs realy low. right pain in the arse. a couple of the screws have been snaaped. might take it off completely
__________________ ![]() | ||
| | #4 | ||
| You can't fool owls. | Re: Im now missing an undertray! Thought you meant you'd been in for a service at T's ![]() | ||
| | #5 | ||
| The modfather |
__________________ Gone fishing | ||
| | #6 | ||
| It's about GO! not SHOW! | Re: Im now missing an undertray! The 2 x 10mm bolts on the front hold it firmly enough but the side screws easily rust and I'd say need replacing at some point ![]() If it falls at the rear then you can only drive forwards - unless you want to rip it to pieces when reversing - so be warned ![]() One of the great joys of having standard ride height is that my undertray barely makes contact with anything these days
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #7 | ||
| Re: Im now missing an undertray! not strictly true argo, i keep on writing to the council about speed bumps. Not all of them, as in bolton near work the are full sized sleeping policemen things and the car doesnt ground them. Its those square ones. down the road from me, they are narrow enough to fit in a stilos track, and high enough to smack a slightly loose undertray, and eventually smash it to smithereens, as above. And this is at standard height. and im not the only one having problems. They only slow me down in the stilo because the car cant get over them without conact, but the saxo will fly over them, infact the faster you go the less you feel. So all the big cars, (stilo, vectra, jag s types) get stuck and slow down, whilst all the little insurance friendly motors can whip over them. I tried driving ove them with one wheel, and it buggered the tracking. I been on about them for years. There used to be a proper sump smasher about 5 miles from here, where the busses going over it had worn grooves eitherside of it so cars dropped in it as the road collapsed. I hit it in the ibiza and beached more or less. on looking at it there were oil spills after it and pools of oil at the side of the road. onths later still wasnt fixed!
| | #8 | ||
| The modfather | I never drove directly over speed bumps in the stilo but between the two with one wheel on each bump and do the same with my Pandy..isn't there a regulated height for these anyway 4" high is the regulated height if I'm not mistaken.. ![]()
| | #9 | ||
| Re: Im now missing an undertray! the only problem i have PNL is that you can only do that at 2 in the morning as this is a busy road! Its a proper pain in the nads but hay ho.
| | #10 | ||
| The modfather | Our is a busy road and I do it any time of day down here ..you gotta time it right..and screaming out the window "Get out the Fecking way" helps as well.. ![]()
| | #11 | ||
| Re: Im now missing an undertray! on this road though, the residents are starting to get teed off with the traffic noise and dangers of the 'traffic calming' and want them removed
| | #12 | |||
| The modfather |
..I started on the case last year and got stuck into them I threatened them with the ferret [TV program for consumer rights ] and its now getting done next week ..will be nice not to have our rear garden flooded now each winter..![]()
__________________ Gone fishing | |||
| | #13 | ||
| Re: Im now missing an undertray! councils are hard work. dealing with them is bad, working for them, apparantly, is worse
| | #14 | ||
| The modfather | Thought I would ask ..have any of you guys had a successfull case against them with damage to your cars..ie.. pot holes and the like.. ![]()
| | #15 | ||
| Re: Im now missing an undertray! not yet, but i havent really pushed for compensation, however will be doing going forward, might even push for a new undertray ![]()
| undertray | wooferday | Stilo | 35 | 21-01-2008 16:07 |
| Custom undertray? | ChrisMClark | Stilo | 10 | 11-09-2007 15:15 |
| Undertray Where from? | merbals | Stilo > Technical | 14 | 27-07-2007 17:35 |
| engine undertray | kev1 | Stilo > Technical | 19 | 03-06-2006 19:53 |
| Undertray | seanory1 | Coupe | 18 | 26-08-2005 16:17 |
