| Accelerator
| Re: Accelerator You can't. If it is running badly, then you need to fix the fault. If you are just annoyed by the engine vibration at idle, we all are. There is nothing that can be done except put your foot on the accelerator a bit while at the traffic lights.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. Last edited by john55; 12-05-2008 at 11:31. | |||
| | #3 | ||
| It's about GO! not SHOW! | Re: Accelerator A disabled (or defective) EGR valve can cause excessive vibration at very low engine revs - as I discovered when messing around with mine.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #4 | ||
| performancestilo.co.uk | Re: Accelerator im sure there is a manual adjustment on the throttle body? | ||
| | #5 | ||
| Grumpy Forum Moderator | Re: Accelerator fly by wire (thus ECU controlled) no idle adjustment.
| | #6 | ||
| Re: Accelerator put some gum on the stop on the pedal...
__________________ www.carlin.co.uk Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof | |||
| | #7 | ||
| performancestilo.co.uk | Re: Accelerator there is definatley an adjustment. i was only looking at it yesterday. it either adjusts the opening or the closing? if opening then you are right you cant adjust it manually but if its for closing then that would adjust idle speed? | ||
| | #8 | ||
| It's about GO! not SHOW! | I'd imagine you're looking at the (factory) adjustment that stops the butterfly from jamming in the throttle body. Mess with that and it's "Wey Hey - Look at all the money I've got to burn!"
| | #9 | ||
| performancestilo.co.uk | Re: Accelerator but if you screw it out, (it looks like a screw adjustment) then would that not increase tickover idle speeds. | ||
| | #10 | ||
| It's about GO! not SHOW! | Re: Accelerator All you have to ask yourself is what's the price of a replacement throttle body (plus work of fitting it) ![]() Many of these adjustments are made in the factory and can't easily be reset (even with full workshop manual). Messing around with controls which aren't supposed to be touched is about as dumb as it gets ![]() Start with with just one fault and then the next thing you know you've got two...three...four faults - and even worse - you've created more faults just to cover up an existing fault ![]() Many of us have done really stupid stuff like that at one time or another (I have) - but you don't do it twice.
| | #11 | ||
| Re: Accelerator diesels are not like petrol engines. You can not adjust the idle speed by adjusting the butterfly valve. The ECU needs to be told to inject more fuel and change the timing. This is done via the accelerator pedal while driving. Introducing more air will not make the slightest bit of difference to idle speed. Also, I believe it is not wise to adjust the accelerator pedal stop as it may cause it to throw error codes.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #12 | ||
| Re: Accelerator Cheers lads was wondering where the cable was to adjust the fuel pump what a carry on all this modern stuff. Well i will just have to keep foot pressed down i suppose, would be nice if things were easy like they used to be. Cheers Welshman
| | #13 | ||
| It's about GO! not SHOW! | Why not pay for say half an hour on Examiner? It's almost certain to find one fault if your idle speed to too low.
| Tags |
| diesel, tic over |
| | faffer | Cinquecento / Seicento | 5 | 09-09-2007 22:54 |
| | leanna | Punto | 2 | 14-08-2007 19:05 |
| | shipley | Cinquecento / Seicento | 2 | 11-11-2005 12:56 |
| | excursion_uk | Uno | 7 | 03-09-2003 19:16 |
| | Bravodood | Bravo / Brava | 0 | 11-02-2003 06:21 |
