The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 15-05-2008   #31
Trader Rating: (0)
Re: Stilo fault codes 1684 1687 1220
Ta 4 the help Deckchair5 - I'm thinking the fave culprit is the wiring between the throttle body and ECU - where's the ECU sited as can't remember as car in dealership?
Ta
Stilo02dynamic16V is offline
Old 15-05-2008   #32
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
That's an easy one to find
Right of centre on top the engine with two large multi plugs.
Name:	 <a href='http://www.fiatforum.com/autolink.php?id=8&script=showthread&forumid=19' target='_blank' title='Engine Control Unit' class='gal'>ecu</a> 1.6 location M10.JPG
M10A and M10B here
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 15-05-2008   #33
Trader Rating: (0)
Ta - remember now! Have fingers crossed it's the wiring!
Old 16-05-2008   #34
Trader Rating: (0)
Hi all - problem sorted - it was the ecu - so have put the old throttle body back on - just for info fiat tech say if the throttle body goes you need to change the ecu and throttle body together - if its the ecu then can change only the ecu. Thanks for all the info and help - much appreciated - plus ecu has years warranty so hopefully no more fault codes!!
Old 16-05-2008   #35
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
your welcome although I disagree with the 'fiat tech say if the throttle body goes you need to change the ecu and throttle body together'.
You can donate know
http://www.fiatforum.com/donations.php
T14086 is offline
Old 16-05-2008   #36
Deckchair5's Avatar
Trader Rating: (0)
"although I disagree with the 'fiat tech say if the throttle body goes you need to change the ecu and throttle body together'.
Yep me too. I've heard Lindsay Lohan come out with less dross
Glad it's sorted
99 Bravo 1.2SX
Old 18-05-2008   #37
Trader Rating: (0)
Hi all - got car back Sat morn - took for drive today - did 60 mile, then engine fault - 1684 - limp home mode - exactly as before fiaqt dealership had it. Once home, (took hours) took connector off throttle body, checked continuity, put back on - car works fine - has faults stored so back to dealership tomorrow to give them hell - seems only fault has been bad connections in the 6 pin throttle body connection breaking down - does that seem reasonable?
Ta
Old 18-05-2008   #38
Forum Moderator
T14086's Avatar
Trader Rating: (0)
I posted here (ages ago & I cant find it) about using a cable tie to hold up the throttle body loom as it is quite heavy/hangs down & puts strain on the TB connector. Also I assume a throttle learn was carried out after ecu fitted?
T14086 is offline
Old 18-05-2008   #39
Deckchair5's Avatar
Trader Rating: (0)
Yes it does, see post 11 in this thread
99 Bravo 1.2SX
Old 18-05-2008   #40
Trader Rating: (0)
hi - yes dealership said they'd done a throttle body learn - after I got home on limp home mode - I started the car in the drive, and just touched the throttle body connector and could hear like a crackling sound from the throttle body - unplugged and reconnected the throttle body and hey presto car running fine. Have 1684 and 1687 faults stored so will take back to dealership tomorrow and get them to put my old ecu back on and a refund - can of contact cleaner and a couple of cable ties and jobs a good un. Ta for help etc.
Old 18-05-2008   #41
Forum Moderator
T14086's Avatar
Trader Rating: (0)
That ecu is useless now its been fitted.
T14086 is offline
Old 18-05-2008   #42
Trader Rating: (0)
i asked the dealership what happens if they fit a part that isn't required, and they said that i then wouldn't have to pay for it.
Old 18-05-2008   #43
Trader Rating: (0)
Hi Deckchair - is it reasonable to expect a full refund from dealer as nothing they have done has brought me any closer to sorting out the problem?
Old 18-05-2008   #44
Deckchair5's Avatar
Trader Rating: (0)
If your dealership said "you wouldn't have to pay for it if they fit a part that isn't required" then try to hold them to it. I'm sure that in the interests of customer loyalty and long term future profits that the Fiat integrity team will look beyond their noses and bend over backwards to placate and appease an otherwise aggrieved customer- but then again- see that pig?
99 Bravo 1.2SX
Old 18-05-2008   #45
Trader Rating: (0)
Weird thing was, car was driving beautifully right before the error codes! Is a brilliant car, think once this issue sorted car will settle down and be the cracking bit of kit that it is with all its gizmos. Just amazing that the dealer misses the obvious, albeit was an intermittent fault. Wish me luck for tomorrow - me v the dealership!
Tags: , , , ,
vB code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Fault Codes ScottyboyGsi Punto > Technical 5 14-05-2008 14:37
Fault Codes minimad99 Stilo > Technical 6 25-02-2008 09:03
Fault Codes Stevej Ulysse 2 29-01-2008 11:12
fault codes fueltank Stilo > Technical 2 29-06-2007 14:40
FAult codes blufin Doblo 2 25-04-2007 08:21
