The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 06-05-2008   #1
Trader Rating: (0)
Question Paint Colour Match
Hello,
Well after paying out £1200 to keep my Stilo on the road, I managed to grind the entire passenger side against a wall in a car park...
The seals aren't broken, so I have decided that after popping out the dent, it should be ok to do a fill and a respray (I don't need a perfect finish, just enough to make it a little less noticeable!)
I problem I have is that I checked the local Halfords and they don't stock the correct colour. The colour is a dark navy metallic finish, which looks more purple in sunlight. Does anyone know if I can get a decent match, probably from a different car make? There are quite a lot of Fords that have a similar colour...
Any help would be appreciated.
westi is offline
Old 07-05-2008   #2
Trader Rating: (0)
Re: Paint Colour Match
Any halfords or similar spray can will look crap, especially if it is metallic, even if it is the right colour for the car.
I would get it professionally done, or get the correct touch colour if you are determined to go down that route.
Do you mean they don't have it on the shelf or they cant mix paint to your paint code? You should have the paint code on a sticker on the underside of the bonnet. Ask one of the bigger halfords with a paint mixing facility to mix that colour for you.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 07-05-2008   #3
The Phoenix has landed!
coyotes_uk's Avatar
Trader Rating: (0)
coyotes_uk has donated! United Kingdom
Paint shops can usually match up the re-spray. When someone dented my front corner I took it to a paintshop and they sorted everything! Didn't even need any details from me about the color!
Actually thinking about it, is the color not on that metal plate under the bonnet?
Go Phoenix Go! http://theangrybudgie.blogspot.com/
Light Blue 3DR 1.6 Stilo Active - Francesca
- Now with Giugiaro designed Vredestein Ultrac's!
- Now with new Xenon's
- 17" Stone Grey CLAWS
coyotes_uk is offline
(S) Paint colour match problem. sitdowndave Punto 4 30-01-2007 21:48
(G) paint match! garyaird11 Cinquecento / Seicento 4 16-11-2006 23:59
(S) Paint > colour match > Halfords? Cap'n Bravo / Brava 2 29-06-2006 22:00
(G) Help with Paint match jesterhud Marea 3 16-09-2005 17:00
colour match The Negotiator Leisure Lounge 58 24-09-2004 23:00
