| | #16 | ||
| Whaddya mean too old? | re: MAP sensor fault - but it isn't? [throttle body clean] The MAP sensor is more to do with economy when your up in the revs and you'll find the 1.6 just drinks the juice if you have MAP fault code recorded as it ignores the MAP entirely It really sounds like thats a red herring. Your poor idle is more likely to be your throttle body inlet valve again (see Stilo Guides if you haven't already) or pre cat lambda sensor. Your engine should hold a steady idle even with the MAP totally disconnected. At idle your MAP just sits there at around 30kpa, pretty boring really I'd clean the throttle body inlet valve again Re your MAP, I'd put some contact cleaner on its connector, clear the fault code which also resets the ECU and see how you go See if you can find someone that can hook up and give you running data of your MAP and Lambda at tickover
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 30-04-2008 at 19:13. | ||
| The following user says "Thank You!" to Deckchair5 for this useful post: | ||
Steely (30-04-2008) | ||
| | #17 | |||
| Dislikeskeyboardwarriors | re: MAP sensor fault - but it isn't? [throttle body clean]
__________________ | |||
| | #20 | ||
| | #21 | ||
| Grumpy Forum Moderator | re: MAP sensor fault - but it isn't? [throttle body clean] sounds like you got a bird stuck in your engine
| | #22 | ||
| Whaddya mean too old? | re: MAP sensor fault - but it isn't? [throttle body clean] Sounds sweet now ![]() Nice to see that rpm gauge rock steady on tickover again isn't it. Should find it's a lot smoother on the initial pick up from low revs and burbling along in crawling traffic should be a breeze now. Poor thing was really struggling before
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 01-05-2008 at 08:47. | ||
| | k4y4m4n | Stilo | 2 | 08-10-2008 21:21 |
| | muji | Stilo | 5 | 19-12-2007 00:11 |
| | DeanF | Stilo | 19 | 15-12-2007 20:34 |
| | johntra | Bravo / Brava | 20 | 13-02-2006 23:16 |
| | b1gduk | Marea | 4 | 22-01-2006 21:53 |
