| It's about GO! not SHOW! | Re: Removing Glow Plugs Right at the far back, close to the inlet manifold. (or follow 4 cables from glow-plug relay which is mounted middle bulkhead) Effectively impossible to replace without the right tools ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| EgyTuner.com... | Re: Removing Glow Plugs i really need more info on this too. im getting the pre-heat fault again, and the last one i had changed cost me £90 so i cant afford that again ![]() | ||
| | #4 | ||
| It's about GO! not SHOW! | There's quite a bit of info in this thread but make sure you follow all the links. I'll produce a guide one day ![]()
| | #5 | ||
| Hi, Thanks for the guide, it enabled me to pin point the glow plug on No 1 cylinder as open circuit. Went to Main Dealer and was met with such tales of woe it's compleley demoralised me. The cost started at £90 and ended up at £600 as the maybe calamities followed. "They are well know for snapping as they are being removed and it could mean the engine coming out" Tried another dealer and was quoted two hours min, taking off the Manifold etc. I was under the impression that Fiat had special tools to take these out even if they did snap. I've settled to live with the pre-heat warning for the moment unless there is an easier way.
| | #6 | ||
| | #7 | ||
| Re: Removing Glow Plugs My dealer even fitted 4 to mine with a strutbrace fitted in just over an hour. Paid for one hours labour plus parts, about £130 all in i think from memory. Make sure you agree a price up front regardless of how long it takes them.
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| glow plugs | bubbles88 | Doblo | 4 | 23-02-2008 22:16 |
| Glow Plugs? | macfly56 | Punto | 1 | 27-07-2007 19:44 |
| td 100 glow plugs | multiplexed | Marea > Technical | 2 | 16-02-2007 13:53 |
| Glow plugs | csm | Ulysse | 0 | 29-06-2006 22:01 |
| glow plugs | Acrucioli | Multipla | 7 | 24-06-2006 18:07 |
