The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 27-04-2008   #1
Trader Rating: (0)
Stilo JTD Tyre Wear
I've posted a message on here before about excessive inner front tyre wear on my '02 5dr Stilo JTD.
I've had the tracking and camber checked and the tracking was out a tiny bit, but the camber is fine.
Anyway I'm getting vibration in the cabin and through the steering.
It gets really noticeable above 50 and seems to be worse in corners.
The weird thing is sometimes I can break and the steering is fine, other times I get a lot of shaking in the steering.
Now I'm thinking I'm going to replace the track rod ends and drop links, but my brother suggested it could be the sub frame.
Could someone tell me what the symptoms of a knackered sub frame are?
Steve
steven_cock is offline
Old 27-04-2008   #2
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Stilo JTD Tyre Wear
Personally I've never come across it on here before new one to me..I think you need to get all the steering joints/lower arms etc checked over and the rack as well for ware..if the rack has got ware the tracking will be out what ever you try ..
Bulitin was issued for lower arms [44.01.03] is the bullitin number if thats any help to you..
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 27-04-2008   #3
Trader Rating: (0)
Unhappy Re: Stilo JTD Tyre Wear
The car has 2 new suspension arms, 2 new monroe shock absorbers and new brake disks and pads. I had 4 new avon ZZ3's and the car was 95% sorted for a while but the shaking has come back. The front tyres were knackered in about 6-7K miles and I don't drive that quickly.
I've not replaced the worn tyres yet, I swapped them to the back to see what it would do and feels the same.
I had a tempra years ago that did this, a vibration I just couldn't sort.
The ball joints were badly corroded so I'm wondering if the track rod ends and drop links are in as sorry a state.
Old 27-04-2008   #4
Trader Rating: (0)
Vibration can often be caused by a worn drive shaft, which is not related to tyre wear.
What are they setting the tracking to? I believe stilo's have been changed and now should be set to 0 deg to stop tyre wear.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 28-04-2008   #5
Trader Rating: (0)
Ive heard that track rod ends on Stilos are a little bit of a common thing?
I think one of mine could do with being replaced as one tyre in particular on the front is wearing more on the inside edge. Although ive now swapped tyres back to front to monitor the wear.
Obviousl question, but are your tyre pressures correct? Checked often?
stilo16v is offline
Old 28-04-2008   #6
EgyTuner.com...
OzMoSiS's Avatar
Trader Rating: (2)
OzMoSiS has donated! Egypt
cant you try something as simple and cheap as re-balancing the wheels before you go stabbing in the dark at more expensive/complicated things?
Originally Posted by dan-the-man View Post
i only have one nipple
Check out my items in the classifieds section HERE
OzMoSiS is offline
Old 28-04-2008   #7
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
commonsense,replacing parts at whim is a expensive way to do things.
T14086 is offline
Old 28-04-2008   #8
Trader Rating: (0)
Yes the wheels were balanced + 4 new tyres + arms + shocks + brakes.
Shakes all the time worse in corners but sometimes really bad when braking.
Jacked the car up last night and tried to feel for play in left to right and up and down but nothing.
When driving the virbration is still there if I dip the clutch.
My old Tempra used do do this, never fixed that either, that had new arms and track rod ends.
Old 28-04-2008   #9
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
As a previous poster has suggested - it sounds like a drive shaft issue to me - even if not particularly obvious i.e you can't detect it as play.
I'd get it checked out
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Tags
drop links, stilo, track rod ends, tyre wear
(T) Stilo Excessive Inner Front Tyre Wear steven_cock Stilo 15 15-03-2008 20:20
(T) Tyre Wear? phostead Grande Punto 23 04-02-2008 13:14
Stilo tyre wear POLL StiloBoy Polling Station 25 27-05-2005 20:29
(T) Tyre sizes for a 02 STilo JTD shaunradams Stilo 4 05-05-2005 14:46
Return of the Stilo tyre wear Problem Scorg Polling Station 0 17-03-2005 10:34
