The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-04-2008   #1
Trader Rating: (0)
Stilo JTD. No aircon light.
Last week the aircon worked perfectly; this week the light doesn't come on when I press the button.
I called out a mobile aircon specialist. He:
Re-gassed the unit.
Checked the appropriate fuses.
Swapped the appropriate relays.
Checked the fault codes.
No luck. He then connected the compressor lead to 12V and the aircon worked so the compressor's OK.
Any ideas?
Stilo 1.9 JTD Active(AC) 5-Door Oct 2004 (54 plate)
DMarsden is offline
Old 24-04-2008   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Stilo JTD. No aircon light.
Dear me, what kind of specialist is this?
It won't be gas and it won't be the linear pressure switch and it wont be the compressor
Ok do a quick test and report back
Turn the internal fan switch off
Now with engine on select air con - do you hear a relay click and does the interior fan switch on?
If not then you have a basic power supply problem ie fuse - switch - relay- earth
Anyway, see what happens with the above test and we can go from there by eliminating quite a few items
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 24-04-2008   #3
loves you lots ;)
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! Jamaica
is it just the light that isnt coming on the control panel for it infront of the gearstick? (standard air con module).
or is it the full unit, if its not, could the bulb in the switch not perhaps have blown?
FIAT STILO..... ABARTH IN DISGUISE
SCORPION BADGES, SKYROOF, 17" ANTHRACITE BLADES, ABARTH SIDE SKIRTS AND SPOILER, BLACK OUT WINDOW BLINDS
PREVIOUS: 54 CORSA 1.3CDTI SXI - WRITE OFF
05 MICRA 1.2 16V SE - IN PURPLE - PART EX
Joshua Frost-Lunn is online now
Old 24-04-2008   #4
Deckchair5's Avatar
Trader Rating: (0)
As the warning light AND the air con compressor isn't running then it'll be a power/ earth open circuit. Just need to narrow down where it is
99 Bravo 1.2SX
Old 24-04-2008   #5
Trader Rating: (0)
Thanks for the quick replies. It's really, really dark out there; I'll report back in the morning.
From memory, there's no click and the fan doesn't come on. The other two lights on the three light panel work as normal.
DMarsden is offline
Old 24-04-2008   #6
Deckchair5's Avatar
Trader Rating: (0)
OK that's what i thought so it's just a case of working through where the power supply goes bad
The fact your internal fan isn't working too shows that the problem is somewhere in the circuit of
fuse F49,
the switch itself H80
Relay J34
or the earth from relay J34
Here's some drawings of your aircon circuit
Name:	air con 1.JPG
whole circuit
Name:	air con 2.JPG
Here's F49 which feeds switch H80 below
Name:	air con 3.JPG
H80 feeds relay J34 here which runs internal fan on setting No.1
Name:	air con 4.JPG
Just for reference, green circle is your compressor
yellow is linear pressure switch but your problem won't be here
Name:	air con 5.JPG
These are the relays for your compressor
99 Bravo 1.2SX
The following user says "Thank You!" to Deckchair5 for this useful post:
DMarsden (25-04-2008)
Old 24-04-2008   #7
Trader Rating: (0)
try bypasing the switch or test it with a multimeter.
WANTED: Faulty Connect Nav+ for parts, to fix mine.
john55 is offline
Old 29-04-2008   #8
Trader Rating: (0)
Sorry about the delay; bad weather and the need to re-decorate a bedroom diverted me.
I removed the dashboard panel covering the aircon switch to reveal a printed circuit board covered in integrated circuits and surface-mounted components, amongst them three switches and six lights. The bottom row of lights light the buttons for the switches and all come on when the ignition is on. The top three lights indicate the circuit is operating. The ICs are presumably latches since one press of a button switches the circuit on, the next press switches it off. The lights for the rear window heater and the recirculation of the heater both work.
To the right is a plug and by trial and error I located these two outputs using a meter. Putting 12V into the appropriate plug pins also causes the corresponding light to come on. From the look of the PCB I guessed which plug pin(s) might correspond to the aircon and fed 12V into that - no aircon and no light.
It looks like the PCB is faulty. Shorting the switch didn't work.
Does anybody (Deckchair5?) know which pins on the plug are for the aircon so that I can be more positive? Any idea how much a new PCB costs?
Thanks to everyone who replied - it was much appreciated.
Another Dave
DMarsden is offline
Old 29-04-2008   #9
Deckchair5's Avatar
Trader Rating: (0)
You might well be right but i can't be certain what you've checked
POWER SUPPLY
I'd check for 12v coming into the switch H80 at pin 4
Got that? No? Check Fuse 49
If so check next
POWER OUT OF SWITCH
Ok is power coming out of the switch at H80 Pin 1 (to relay J34 for operation of internal fan on setting 1)
AND H80 pin 10 (going to the ECU)
Don't seem to have a schematic for switch H80 pinout but here's wiring colours going in to each pin of the switch
Name:	H80 switch wiring.JPG
WIRING CODES
N= BLACK
B= WHITE
C= ORANGE
M= BROWN
A= LIGHT BLUE
S= PINK
V= GREEN
R= RED
Z= PURPLE
G= YELLOW
H= GREY
L= BLUE
So pin 4 power IN is AV = light blue/green
pin 1 is V=green = power to internal fan relay J34
pin 10 is L= blue = power to ecu M10
99 Bravo 1.2SX
Old 24-05-2008   #10
Trader Rating: (0)
Right! I've finally got round to fixing this thing. There is a printed circuit board behind the panel holding the aircon switch.
Putting 12V to the top leftmost pin of the plug at the right hand end starts up the aircon and puts on the appropriate light. The aircon relay clicks, the fan starts and the aircon works. Therefore the PCB is at fault. Here it is on the workbench (aka the kitchen table).
I couldn't see anything obviously wrong with it so I've soldered a switch between the two leftmost pins of the plug (the bottom one is 12v when the ignition is on) and left it dangling down in front of the gearstick for now.
The circuit is now as shown in the schematic posted by Deckchair5 (to whom many thanks). I'll try to get a replacement PCB from a scrappy but at least I've got aircon - just as well, I'm off to Italy via France in the caravan soon.
Once again, thanks to all who posted replies.
Another Dave
ID:	44096  Click image for larger version
DMarsden is offline
Old 24-05-2008   #11
Deckchair5's Avatar
Trader Rating: (0)
From what you say, it looks like it could just be a dry joint. I would redo the joints to the CB at the base of the pins, maybe go around and redo any other easy solder joints that you can see
Put a multi meter from one side on the pins and see if it's actually making contact on the other side of the board
99 Bravo 1.2SX
(T) Stilo aircon valve core andyp108 Stilo 9 04-12-2007 23:55
(T) Cleaning Stilo aircon mkarjala Stilo 8 22-02-2006 08:23
(T) Stilo 1.9 JTD ACTIVE AIRCON & CD player sebus Stilo 11 31-03-2005 20:11
