The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 14-04-2008   #1
Trader Rating: (0)
JD4341 has donated!
Removing CN+ Headunit, SAT NAV problem
Hi all,
Firstly before I get flamed (cos I am sure this has come up before) I have done a forum search and not found much detailed advice....anyway heer is my question....
Firstly my problem with the SAT NAV in my Abarth '52 is that more aften than not I looses connect to the SA NAv antenna IE the sat pic is not green and diagnostics says fault with antenna. However sometime it kicks back in, I get the green SAT icon and all is well...just up unitl it goes off again.
I am thinking loose wire (anyone any other ideas) so my first solution is to remove headunit and check all wires at the back are seated properly, namely the GPS antenna.....only I can't remove the head unit. I have done the cut up coat hanger thing into the two holes on the front but that does not seem to release anything so the unit does not slide out. Scared of applying too much presure pulling out of the cut out hidden by the glove box lid.
Any thought much appreciated.
Again, sorry if solution already posted
Thanks JD
Ps anybody have had the antenna loosing connection issue?
PPs this is a great forun, no really
52 5dr Abarth
JD4341 is offline
Old 14-04-2008   #2
Trader Rating: (0)
Netherlands
Re: Removing CN+ Headunit, SAT NAV problem
two long 4 mm bolts screwed in for 1/4 inch will release the catches....
yellowstilo is offline
Old 15-04-2008   #3
Trader Rating: (0)
JD4341 has donated!
Tnx Yellow
JD
52 5dr Abarth
JD4341 is offline
Old 15-04-2008   #4
barwydennau + chromliniau
Dogspods's Avatar
Trader Rating: (0)
Dogspods has donated! United Kingdom
Or two electrical screwdrivers - need to be pushed in about 3"
Dogspods is offline
Old 16-04-2008   #5
Trader Rating: (0)
JD4341 has donated!
Thanks Dogspods, tried similar thing with wire coat hanger but no luck, will try as you suggest. Once you had put the screwdrivers in what point did you easy the unit out from.
Cheers JD
52 5dr Abarth
JD4341 is offline
Old 17-04-2008   #6
Dogspods's Avatar
Trader Rating: (0)
Slowly push the screwdrivers into the holes and you'll feel the clip release, then gently pull the screwdrivers apart and pull back, the head unit should slide out easily.
Dogspods is offline
Old 23-06-2008   #7
Trader Rating: (0)
JD4341 has donated!
Thanks Dogspods. I did eventually get this to work and removed the head unit...the problem now is that I have no idea which is the GPS Antenna wire...I took them all out in the end then put them all back in, this did not fix my problem. Anyone know which is the GPS antenna wire so I can avoid removing wires that would be best left alone?
JD
52 5dr Abarth
JD4341 is offline
Old 4 Weeks Ago   #8
Trader Rating: (0)
krismc has donated! United Kingdom
just to answer the question incase anyone else ever wants to know, the gps ariel is the grey connector at the top left corner ( if looking at rear of unit) the green connector which is almost identical is the gsm ariel.
Also the gps connector is a gt5 connection, replacement gps receivers are about £10-£30 on fleabay, if you'd rather not go down the £100+ new antenna base option
krismc is offline
Tags
headunit, sat nav
Sat Nav/Computer Problem. The Prof Ulysse 15 09-07-2008 21:59
Sat nav problem bucca Doblo 5 26-11-2007 21:36
Sat nav problem bucca Satellite Navigation 0 05-11-2007 12:31
Balupunkt Sat Nav headunit - connections?? sporting52reg I.C.E 1 01-09-2004 06:27
(T) Removing SAT Nav Connect+ david.bell Stilo 2 16-05-2004 23:58
