| Stilo Alarm Chirp Does anyone Know if you can get the "Alarm chirp" on arm and disarm turned off. I have asked on dealer and they said they couldn't. but i'd like a second opinion..
| | #3 | ||
| 5vp3r m0d | Re: Stilo Alarm Chirp This can be turned off via Examiner, surely? Or is your local dealer too lazy! I have the 'chirp' on mine, yet others don't, so must be an option somewhere.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #4 | ||
| Re: Stilo Alarm Chirp Ok gonna sound like an idiot here, but Examiner ???
__________________ 04(Facelift) 115 jtd Dynamic 5Dr, Black. | |||
| | #5 | ||
| 5vp3r m0d | Re: Stilo Alarm Chirp Examiner is the bit of kit they use to access your cars computer, via the OBD port under the dash.
| | #6 | ||
| Re: Stilo Alarm Chirp Was there not a bulletin issued to Fiat dealers about how to turn on the flashing sidelights to let you know the car had locked (Bulletin 22 I think)? The alarm beep may be included in that.
__________________ 2003 Fiat Stilo Multiwagon JTD Dynamic 1999 Fiat Coupé 20 valve turbo 1992 Mitsubishi Shogun TD 7 Seater | |||
| | #7 | ||
| one with the dark side | You need to order a code card, and then you can change the settings using the examiner. You can change things like indicator flash when arming/disarming, alarm chirps etc. | ||
| | #8 | ||
| Re: Stilo Alarm Chirp Umm, my alarm dosen't chirp; but the lights flash when being armed/disarmed?! My old der's stilo dosent do either?! Do you have to have extra piece to the alarm in the brio catalogue for it to do this (chirp that is)!! Dont fink tht my dealer would change the settings on my alarm bcos he couldnt be arsed to set the lights to flash on my old ders stilo when its armed/disarmed!! Dam lazy dealerships!
__________________ Grande Punto Sporting 1.9 8v Mjet - GSR Stilo 1.8 16v 155.9Hp - Kawasaki Z1000 ![]() | |||
| | #9 | ||
| 5vp3r m0d | Re: Stilo Alarm Chirp Sounds like it needs to be changed over to 'chirp'. I ordered a code card for mine a few months back - not expensive, plus you never know when you may need it.
| | #10 | ||
| Re: Stilo Alarm Chirp ive got the code card already, think ill have to pester my dealer into sorting it out! When i get the stilo back and doing both for me old der! well thats if i get my stilo back and if not ill be going to order a nice shinny new 1, and ill make sure i tell them to activate both functions!
| | #11 | ||
| Abarth Alarm Problem "Return to Dealer" My loved '52 Abarth has suddenly started telling me about a problem with the Alarm and advises me to "Return to Dealer" - yeah, like I really want to do that! At first I thought it just another false alert but it has been persistant - every time I start up. A couple of tests and it seems that the alarm is working except for the ultrasonic interior protection. Anyone had any issues with this in the past? Just my luck, it's now out of third year warranty - probably wouldn't have been covered anyway! Any comments (relevant ) welcomed.
| | #12 | |||||
| Re: Abarth Alarm Problem "Return to Dealer"
The only problem I ever had was that the alarm was too sensitive and kept being set off by any passing cars. Dealer desensitised the ultrasonics in accordance with Fiat's instructions - ie stuffing material into the sensors - rather like earplugs. No problems since then. Talk about bringing hi-tech down to earth!
| | #13 | ||
| Alarm Questions I had a new boot locking mechanism fitted by fiat last week as this was what was causing my boot light not to light up. Now when i press the button on my remote to open the boot it unlocks it, but when i lift the boot the alarm goes off. This never used to happen before they changed the lock. Any sugestions or is back to the dealer once again!!!! Cheers
__________________ Formerly Fiat Coupe then Stilo Abarth and now Punto HGT | |||
| | #14 | ||
| Glutton for Punishment | Re: Alarm Questions Just checked ePER thinking that the lock mechanism may be different for versions with an alarm but its the same . . . I'd go back to the dealer; when you hit the boot unlock button on the remote, the body computer should deactivate the alarm's sensors (both volumetric and the boot perimeter) until the boot is closed. Then, when the boot is closed, the body computer indicates all monitoring is reactivated by flashing all indicators twice. Can't see what they could do to make it not work now; maybe the need to reset something?
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | Mattster | Stilo | 24 | 17-10-2008 10:01 |
| | asdarch | 500 | 1 | 04-06-2008 22:39 |
| factory barchetta alarm | ricky952 | Barchetta | 5 | 23-12-2006 00:46 |
| punto gt factory fit alarm immob | phil_GT | Security | 4 | 01-09-2005 00:43 |
