| koni springs Hi, sorry for me ( possibly ) being stupid !! Ive just fitted a set of 40mm koni lowering springs to the front my stilo and im not sure but it seems to look higher ! Could this be because..... 1) i have fitted wrong ones to the front ( i fitted the longer ones with evenly space coils ) 2) i havnt fitted the rears yet due to the typical british weather !!! cheers Rich
| It's about GO! not SHOW! | Re: koni springs You've got it in one - you've fitted the wrong springs for your car. The rears will most likely be correct but of course it will only make the car look even more odd. This has come up before - try searching for say "Koni springs"
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| EgyTuner.com... | Re: koni springs chrismclark had exactly the same problem, appatenly the springs were designed for the WHOLE stilo range, which includes the heavier abarths and diesels, therefore the springs dont drop as they should on the 1.2/1.4/1.6/1.8s Last edited by OzMoSiS; 06-04-2008 at 21:26. | ||
| | #4 | ||
| Re: koni springs I ordered from Larkspeed in Leeds and they were aware of the 2 different types of springs for the front when i ordered as I was asked the front axle weight when ordering because they said the koni's were no good if i had the diesel or abarth. ![]()
| | #5 | ||
| Re: koni springs Looks like i will have to give them hell on the phone tomorrow, If need be i will try and get them swapped for an alternative set. What would people suggest ? Eibach ?
| | #6 | ||
| 5 pots rule!! | Re: koni springs
__________________ Previous Car : 2002 Mk2 Punto Active Sport in Broom Yellow Everday Car : 1999 Mk1 Punto Sporting in Silver Weekend Toy : Stilo Schumacher GP | ||
| | #7 | |||
Go any lower and you'll need to change standard dampers (which then starts to get expensive )
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #8 | ||
| | #9 | ||
| Re: koni springs cheers, just spoke to larkspeed where i bought the konis from and he has agreed to credit me for them if i get them returned ! I am not bothered about the looks too much, so it looks like eibach -30mm is the way to go.......i only changed in the first place because of the same old story of the standard ones snapping thanks Rich
| | #10 | |||||
| Re: koni springs
![]() Is it essential to change the dampers if i fit the -50 eibach sports or is it just advisable to ? i dont wanna get em only to find out that i need dampers aswell once fitted cheers, Rich
| | #11 | ||
| Re: koni springs Rich, the OE dampers aren't that great to start with, if you lower it 50mm then the damper will already be partially compressed so they'll be even less effective. You can get away from OE dampers on -30mm springs but i'd recommend changing the lot if you go -50mm. Just my opinon though
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #12 | |||
![]() send the koni's back and contact Proven Products (LINK), they'll hook you up with what you want | |||
| | #13 | ||
| It's about GO! not SHOW! | Re: koni springs I completely agree with minimad I fitted -35mm (but Pi's not Eibach) to mine and there's no question it degraded the handling on imperfect A & B roads. If you take a really fast curse and hit a pothole that the damper can't handle then you'll bounce - and there's only one place you're going to end up ![]() Wait the 2/3 weeks - it isn't that long
| | #14 | ||
| Re: koni springs what shocks should i go for ? dont wanna spend a silly amount, but dont want crap either Cheers
| | #15 | ||
| Re: koni springs Spend the money and get the Eibachs that match the springs you want or Bilstein are highly recommended, neither are cheap though. Suspension is definately an area where you get what you pay for.
| | Yellow Peril | Stilo | 15 | 30-05-2007 09:30 |
| | ChrisMClark | Stilo | 15 | 27-02-2007 23:57 |
| | Bottonick | Punto | 7 | 12-04-2006 20:12 |
| | 1.2turbocinq | Cinquecento / Seicento | 6 | 30-08-2004 14:50 |
