| elm 323 driver software anybody know where i can get the driver software for the elm 323 ? the guys down at (talktomycar.co.uk) sent me a cracked driver installation cd. thanks in advance
| FFFTW! | Re: elm 323 driver software is it usb/serial/bluetooth? for serial, you dont need a driver, for USB, you need a USB-Serial bridge driver... it depends on who made your interface as to which USB IC they used and hence the bridge driver required.... do you have a pic? i may still have the driver for the Prolific USB-Serial kicking around somewhere.
__________________ If my post has helped you, please click the Thanks button ![]() | ||
| | #3 | ||
| Re: elm 323 driver software on the front it says: ELM 323 SUPPORT ISO9141/KWP2000 PROTOCOL AND ITS USB BOUGHT FROM www.talktomycar.co.uk hope that helps
| | #4 | ||
| FFFTW! | Re: elm 323 driver software sorry, mines a different model to that im afraid.
| | #5 | ||
| Whaddya mean too old? | Re: elm 323 driver software If you're running XP SP2 then plugging into the usb slot should bring up the "found new hardware" wizard and, if you're internet connected, download the software automatically If not look here and choose the driver for your system http://www.ftdichip.com/Drivers/D2XX.htm
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 14-03-2008 at 21:31. | ||
| The following user says "Thank You!" to Deckchair5 for this useful post: | ||
zammo (15-03-2008) | ||
| | #6 | ||
| Re: elm 323 driver software sorted the driver problem but now the scantool is saying "interface not found" when i press connect. any ideas? ![]() thanks in advance
| | #7 | ||
| Whaddya mean too old? | Re: elm 323 driver software Is it connected to the car and ignition switched on? "Interface not found" also means no connection is made with car
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #8 | ||
| Re: elm 323 driver software yeah, im pluggin into the 16 pin above the fuse box inside the car.ive tried it with inition on,off and running sill the same thing no interface ive used :elm scantool,autotap.but there all sayin the same thing ![]() ![]() ![]() HELP!!!
| | #9 | ||
| Whaddya mean too old? | Re: elm 323 driver software As it's a usb does it recognise it when you plug it in or does nothing happen? Is the 16 pin connector pushed fully on to the car socket as it needs a firm push the first time? Are you sure you have the correct usb driver installed?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 15-03-2008 at 22:00. | ||
| | #10 | ||
| Re: elm 323 driver software ive uninstalled jus incase somthing was wrong, re installed and...nothing still the same anymore advice before i send it back for a refund?
| | #11 | ||
| Re: elm 323 driver software Interface not found can often be a port problem. Use the diagnostic software to search for the right port, or go into Windows Device Manager, find the USB interface and see if it tells you which port is assigned to it. If all else fails, the diagnostic software will have an Options or Settings page, just try all the different ports till you hit it. Remember, computer has to be on, car ignition has to be on.
| | #12 | ||
| Whaddya mean too old? | Re: elm 323 driver software You don't say what you've done or whether you're XP SP1 or 2 You need to make sure it installs the driver which you download from the above website and not let it search for what it thinks is best Almost certainly it'll be a usb driver problem or your own laptop configuration problem You may need to change the com port Number for the usb Have a look here to see how to install the driver http://www.ftdichip.com/Support/Know...ase/index.html If all else fails get the guys to send you another install cd
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 16-03-2008 at 22:41. | ||
| driver for the bt 1020 wireless card?? | beau | Computing | 1 | 16-05-2006 16:46 |
| Complete Sat Nav or just the software | Fozzybear | I.C.E | 4 | 30-04-2006 14:10 |
| | GTR | Stilo | 5 | 09-09-2004 18:03 |
