The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 18-04-2008   #76
Trader Rating: (0)
Re: Blue Smoke on Start-up
i cant see a manufacturer selling many cars if whenever someone went for a test drive a cloud of blue smoke the size of a car came out the back and drifted slowly away from the car or back towards the front of the car if winds that way , and the salesman says " ah thats nothing to worry about " if nothing else its embarrasing but also cant be doing any good to the inlet manifold,egr, and cat.if somethings wrong in warranty is when its best getting sorted.how much should i expect to pay for a fuel filter from dealers and how hard is it to change, any procedure to prime it?
sussexa is offline
Old 18-04-2008   #77
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
I grant you yours puts out a fair bit more smoke than my JTD but I'm not sure I'd call it a massive amount. At least yours sounds quite healthy (compared to adruss85's motor )
As you say, worth checking out under warranty I guess.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 19-04-2008   #78
Trader Rating: (0)
ok got car back,job sheet did insist on new air filter fuel filter and fuel cleaner/additive.checked at parts desk fuel filter 77363657 is £55 +vat so diddnt get that today will shop around,additive that they use and sell is silver hook diesel treatment and injector cleaner so bought a bottle and added to tank this morning and filled up with tank of excellium.
sussexa is offline
Old 11-05-2008   #79
Trader Rating: (0)
near end of 2nd full tank of fuel since adding the bottle of injector cleaner,first tank noticed no difference to smoke from normal.added millers sport4 to sainsburys diesel this tank and have noticed that this week only smoke is all but gone,both going to work mid day and leaving work 22.00hrs?convinced this is related to weather as this weeks been really hot and mpg is also up 350 miles with 1/4 tank left.(showing 53mpg)
any updates from ananku or adruss?
sussexa is offline
Old 11-05-2008   #80
Driver Extraordinaire
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
did you add the bottle to a full tank, I thought those products were normally added to 30 or so litres of fuel?
If it was a whole tank, maybe you watered it down too much??
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 12-05-2008   #81
Trader Rating: (0)
no, it was added to about a 1/4 tank and given a good spirited drive on dual carriageway for 20 miles or so at strong concentration then the tank filled up.the millers i added at double dose to full tank,but am still convinced its more weather related.started car just as its stood for 40 odd hours and not even a puff toatally clear.i had been using millers regularly before this and excellium so would have imagined the fuel system was already pretty clean? seems to have ruled out mechanical ie valve stem guides/seals at least.
sussexa is offline
Old 12-05-2008   #82
jostheboss's Avatar
Trader Rating: (0)
I got a fuel filter from Partco for £9 - is very easy change...
www.carlin.co.uk
Fiat Stilo JTD 115bhp 3DR Green/Blueish! Skyroof New Goodyear Eagle F1 Rubber
jostheboss is offline
Old 15-05-2008   #83
Trader Rating: (0)
Finally got a response out of Fiat today (4 weeks from complaint tomorrow), not exactly professional.
Before I give a brief on what Fiat have said, I have been monitoring my cars smoke condition over the last 4 weeks. I am happy that the problem is "FUEL" not oil. I would suggest that you dont spend any money on trying to cure the problem, because, in a nut shell you wont be able to. It all about the engine overfueling at start up, in cold conditions - the colder the worse it is. With ambient temperatures of 14 degrees+ I dont have the problem.
However, I dont exactly know why. The obvious choice would be that the ECU's map is not right. But there are other possibilities that it could be. Work friends of mine who own Vauxhalls with the same engine and the same year of manufacture dont have the problem........Which lends me not to think its the ECU's map directly. Indirectly.......It could be the map. My theory is that Fiat have used up surplus stock of ECU's designated for cars to be sold to a hot climate (obsolescence) or they have modified a position for one of the engines sensors fitted into an engine part, and only introduced the mod to the Bravo, Saab, and Vauxhall ranges (so we are driving Prototypes, which I know Fiat do do. Imagine 20,000 field trial cars - heaven for a manufacturer).
Ok so here it is Fiats official responce.
Blue smoke at cold start is "NORMAL" for the Fiat Stilo 150 JTD Multijet.
This is obviously a carefully worded statement. Yes its normal for us to have blue smoke, because we have all got it - simple. However, its not normal for any engine to have this feature, especially when its thrown in free as part of the "Performance Characteristics" ( Iam always looking for a bargain).
Very thoughtful of Fiat to add such a feature - I wonder why no other Manufacturer has thought of it. Fiat should use it as part of their Marketing Programme. The Italian Job with built in smoke screen to help loose the Poilce on the get away.................!
If I get any further with the problem I will report on this thread - however I dont hold out much hope.
2006 1.9 Multijet Sporting 3 door 150 bhp,
but more importantly 305 Nm of TORQUE
ananku is offline
Old 16-05-2008   #84
Don't touch those!
adruss85's Avatar
Trader Rating: (1)
adruss85 has donated! United Kingdom
Good round up, I've noticed less (but still some) smoke recently, and also the very rough running. Looks like i will have to make do with the smoke for now and see if a GSR remap sorts it out!
Come to mention it my range drops by around 10 miles every time i start the engine!
adruss85 is offline
Old 16-05-2008   #85
Falling Into A Trap
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! United Kingdom
most will probably do that, i think mine does
i like it when i do a long journey for say 100 miles to durham etc, and the range with a full tank setting of wil grow to 600 and odd miles at a steady 70mph, and then once it gets to half a tank it nose dives
1.9JTD DYNAMIC, IN GRIGIO STEEL GREY, ABARTH SKIRTS & SPOILER, SCORPION WHEEL BADGES, SCORPION BONNET & BOOT BADGES, BLACK OUT BLINDS, SKYROOF, 17" ANTHRACITE BLADES
Joshua Frost-Lunn is online now
Old 16-05-2008   #86
Argonought's Avatar
Trader Rating: (0)
You want to try it when it says "Range 30 miles" (on along journey) and the needle is way down on the red
Economy driving here I come
As you say Josh, it's perfectly normal for the 'range to empty' figure to drop after a start on a coldish morning.
Old 17-05-2008   #87
Falling Into A Trap
Trader Rating: (0)
i had it on empty registering no fuel for about 40 miles and it still lasted, this was 2 months ago, never again, 64 pound or so for a full tank i think, would be a lot more now
vB code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto 543 06-06-2008 17:15
