| | #61 | |||||
| Don't touch those! | re: Blue Smoke on Start-up (MultiJet 150)
Don't judge
| | #62 | ||
| It's about GO! not SHOW! | re: Blue Smoke on Start-up (MultiJet 150) Using full revs in an accident avoiding situation is fair enough (if that's what you mean) but you made it sound like you do it routinely.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #63 | ||
| Don't touch those! | re: Blue Smoke on Start-up (MultiJet 150) eeek no. ![]() bad for economy! ![]()
| | #64 | ||
| re: Blue Smoke on Start-up (MultiJet 150) The car is limited when cold - so that you treat it with respect. Until it gets warm - then all hell lets loose...... Fiat Corse
__________________ 2006 1.9 Multijet Sporting 3 door 150 bhp, but more importantly 305 Nm of TORQUE | |||
| | #65 | ||
| A few points on the engine performance: This engine in the Sporting variant is faster than the Abarth (appologies to Abarth owners if the truth hurts): The rev limiter or governor is there to obviously stop you over reving the engine. There is absolutely no problem with running the engine to the limiter so long as its hot. ![]() If you run the engine at high RPM when its cold your asking for trouble i.e. in later life - not good for the engine or the turbo. ![]() The torque curve for this engine is absolutely brilliant - Core Sportivo ![]() Torque gets you down the road not BHP. This is what the petrol heads fail to realise, with comments of good fuel economy but poor performance. So the reality is more torque the faster you can go. Add this to a long torque curve and bingo - Economy and performance, win win. In summary the 1,9 JTDm and the 2.4 JTDm are world class diesel performance engines. The next generation engines are on their way - so look out.
| | #66 | ||
| | #67 | ||
| Don't touch those! | re: Blue Smoke on Start-up (MultiJet 150) When starting the car up i'm now getting a huge "bang" type noise. Not an explosion but the whole car shakes and it sounds like somone has just thrown a big rock on the roof. Was accompanied by more smoke than usual today! ![]() Have informed my dealer and they said they will get back to me regarding any service bulletins about the car etc. Ananku - would it be possible to have a definitive list of all the things that have been changed/checked on your car, and a contact number for TJ Vickers service department, and anyone you may have spoken to at fiat uk? Any updates from anyone? sussexa? Cheers
| | #68 | ||
| re: Blue Smoke on Start-up (MultiJet 150) nothing new from me im afraid, havnt heard back about the battery yet they said it might not get seen until friday. the smoking was just added on at the end of the service sheet to check amount of smoke when started up as would have stood for a day or more, but this is the first time ive mentioned it to them so not holding my breath that they will even look at that.once batterys sorted i can leave it with them another time.
| | #69 | ||
| It's about GO! not SHOW! | You MultiJet guys shouldn't get too much of a hang up on smoky startups. This is my JTD115 (remapped) on first start of the day. DivX Video
| | #70 | ||
| Don't touch those! | re: Blue Smoke on Start-up (MultiJet 150) Only thing i would say is that if fiat uk are sending a techinician out to Ananku then there must be some concern from then? Also the work my dealer did that was supposed to cure a smokey start up did nothing.... Would rather take full benefit of the warranty while I can.
| | #71 | ||
| re: Blue Smoke on Start-up (MultiJet 150) stuck in work so cant pick mine up till sat morn now but over phone flat battery is a problem with aftermarket alarm setting off radiator fan?alarm was meta fitted at suppling dealer so ive got to take it there to get that looked at, is there an easy way to disconnect alarm and still use key fob to lock doors?.as for smoke they recommended a new air filter and a fuel treatment and possibly fuel filter(cant remmember now) before they would investigate further.when i asked which fuel treatment as most manufacturers wont recommend one she said id have to speak to the tech on monday.dealers really are stars.
| | #72 | ||
| re: Blue Smoke on Start-up (MultiJet 150) Replacement parts on my car to try and cure the problem (without success):- ECG valve, coolant sensor, MAF meter. Also - Calibrated injectors and full analysiser measurements sent for review to Fiat Technical. Also the Dealer put a Forecourt sale car on the analysiser for comparison (both cars were the same). My dealer confirmed yesterday that following a review of all the data that they sent to the Technical Support Team, they (Fiat) have stated that my car is running correctly and that there was nothing wrong with it. So as far as my Dealer is concerned thats it. In principle I agree with their statement, as I know that when the engine has started its all ok - it just at start up.I have therefore telephoned Fiat themselves, spoken with the Customer Services Dept (very pleasant Italian Lady), and made a complaint against Fiat (not my Dealer). Fiat have said that a case manager will contact me within 3 days to discuss and that they have marked it urgent. I have also telephoned my Dealer and let them know of the situation. Fiat's number is 0080034280000 select option 3 from the automated message (dont leave it to late to select as the message is repeated in Italian) . Make your complaint if you feel your Dealer cannot do anymore.I will report more when I have taken the call. Off now for some beers. ![]() Ciao.
| | #73 | ||
| re: Blue Smoke on Start-up (MultiJet 150) most info that ive found or been advised for blue smoke on start up always seems to be valve guide stem seals if they have held their hands up and can do no more did they check these at all ?not sure how they would other than rocker cover off and visually check.also is there any way to take injectors out and check they seal 100% shut, over 12-24 hours the smallest dribble will add up.could a small amount of diesel be artificially added to one cylinder to see if that recreates the blue smoke and then small amount of oil same thing this would give us a 50-50 oil or fuel unless they both smoke the same.whats easiest thing to remove for access to cylinder guessing glow plug ?but as car not with me now could be completely wrong.
| | #74 | ||
| re: Blue Smoke on Start-up (MultiJet 150) just been on shop4parts browsing and noticed a cold start sensor for £5 what does this do im guessing it would have been tested in anan's case
| | #75 | ||
| It's about GO! not SHOW! | re: Blue Smoke on Start-up (MultiJet 150) If you really want to see some smoke then it's a hell of a lot easier then that. Just do lots of false starts. Turn over the engine but try not to let it start. That should create plenty of smoke (briefly) but to be honest I really can't see the point. If it runs fine without using any oil then what's the problem
| | sussexa | Stilo | 5 | 30-07-2008 11:31 |
| Bravo Sport T-Jet 150 vs. Multijet 150 comparison | cstavaru | Bravo | 5 | 02-06-2008 14:56 |
| | sussexa | Stilo | 22 | 19-03-2008 13:57 |
| | johnson550 | Stilo | 6 | 19-02-2008 21:18 |
| | jmhv | Bravo | 0 | 31-12-2007 03:14 |
