| | #31 | |||
| It's about GO! not SHOW! | Re: Blue Smoke on Start-up
You can certainly disconnect the MAF sensor connector at any time but you'll need to set aside perhaps an hour, and have a good toolkit, to block off the EGR valve. You can easily disconnect the electrical connector on the EGR valve but this wont help if the valve is mechanically jammed open.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #32 | |||
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | ||||
| | #33 | ||
| 5 pots rule!! | Re: Blue Smoke on Start-up
__________________ STILO Schumacher GP 247lbs/ft of torque and 199.7 Bhp , thanks Pete!!![]() | ||
| The following user says "Thank You!" to red-devil for this useful post: | ||
Argonought (27-03-2008) | ||
| | #34 | ||||||
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||||||
| | #35 | ||
| Don't touch those! | Re: Blue Smoke on Start-up well i'll try unplugging the maf sensor and see what happens as they said could be either. i'm guessing this wont do any damage to the engine?
| | #36 | ||
| | #37 | ||
| Don't touch those! | Re: Blue Smoke on Start-up Point! I'm pretty fed up of this car already actually . Had massive issues with the dealer i bought it from, and now it's gone wrong i just hope i don't have issues with the dealer who's fixing it!
| | #38 | ||
| Re: Blue Smoke on Start-up hi hows it going,any info back from dealers, does it look like its going to be a long repair?hope it gets sorted soon for you.
| | #39 | ||
| Don't touch those! | Re: Blue Smoke on Start-up Spoke to them this morning, parts have arrived but I'm away on a course next week so it's not going in until the 14th. Looking forward to seeing whether the fix works or not!
| | #40 | ||
| | #41 | ||
| Don't touch those! | Re: Blue Smoke on Start-up Well performance is much better! Pulling from just under 2.5k now and much smoother... Looking forward to see if it smokes tomorrow morning!
| | #42 | ||
| It's about GO! not SHOW! | Re: Blue Smoke on Start-up So you didn't ask what was done then? (assuming you didn't get a bill ![]()
| | #43 | ||
| Don't touch those! | Re: Blue Smoke on Start-up I did but you never know with these dealers ![]() Took my Corsa to the Vauxhall dealership once, diagnosed £400 of problems Took it back to have the work done, and they did something else ![]() In fact it's running so well i may spend some more money on it ![]()
| | #44 | ||
| Re: Blue Smoke on Start-up Hi, just joined the Forum. I have a Stilo 150 Multijet Sporting Nov 2006. I have been reading this thread, and guess what? I to have blue smoke at start up, masses of it. My dealer tells me its fuel, however, I think its oil. I have had a new ECR and MAF, and neither of these have fixed the problem. My dealer has had my car on and off for about 2 weeks trying to fix this without luck. I am currently monitoring the problem post a new coolant sensor. Still no improvement. I have just spent all night reading the Fiat workshop manual trying to get a understanding of how the engine works. Please post your findings following your cars return?
| | #45 | ||
| Don't touch those! | Re: Blue Smoke on Start-up Will let you know tomorrow morning after my drive to work! Looks like we could have 2 that came from the same shift at the factory ![]() EDIT: Has he looked at the valve stem seals? These days dealers seem to be obsessed with sensors, never actually considering any mechanical problems! If mine is still smoking tomorrow then i'll be calling them up!
| How many Puntos are there on the Forum? - The Thread | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
