The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 08-03-2008   #1
Trader Rating: (0)
Kelvin W has donated!
Engine Noise From Cold
Hi guys
I need some advice 1.6 (04 plate Stilo) 33000 miles it’s regularly serviced and oil always kept at the correct level.
The problem is a sort of over advanced binding/clonking engine noise from cold for a few seconds then goes away and runs fine, although I have got some hesitation on acceleration from stand still and some times it almost feels like its about to pink in an over advanced timing way
Any ideas
Regards Kelvin W
Kelvin W is offline
Old 10-03-2008   #2
Trader Rating: (0)
Re: Engine Noise From Cold
Kelvin
The 1.6 lump is a bit rattly when cold. Assuming you have done all the normal stuff (clean air filter, good spark plugs etc), to correct the hesitancy problems I suggest the following, in this order:
1) Clean the throttle valve (see this guide for how to do this: http://www.fiatforum.com/stilo-guide...rol-valve.html)
2) Try a tankfull or two of Shell VPower.
2) Consider fitting more earth leads (see this thread for how: http://www.fiatforum.com/stilo-techn...grounding.html)
3) If those fail to offer any improvement, get a re-map (Angel Tuning well worth a try IMHO: http://www.angeltuning.co.uk/)
Good luck!
Phil Thomas
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive
Yellow Peril is offline
Old 10-03-2008   #3
Trader Rating: (0)
This sounds identical to a problem I had, a rough hollow gargling sound (a bit like a dielsel) for a few seconds at startup. The dealership replaced several parts before I found the answer on this site.
It turned out to be a bad timing variator. If the car is under warranty, ask them to replace it.
Here, check this link to my thread a few years back.
http://www.fiatforum.com/stilo-techn...e-startup.html
Paparini is offline
Old 11-03-2008   #4
Trader Rating: (0)
Only problem with that theory is that the 1.6 doesn't have a variator! Only fitted to the 1.8 engine...
Phil Thomas
Yellow Peril
Old 11-03-2008   #5
Trader Rating: (0)
Well, you learn something new every day!
It sounds identical though, so what is the purpose of the Variator? Forgive me if it is a stupid question.
Paparini is offline
Old 11-03-2008   #6
Trader Rating: (0)
As far as I know (and I'm not a 1.8 owner) it is a device (driven in part by oil pressure I believe) to alter valve timing by roating the position of the camshaft relative to the valves.
Phil Thomas
Yellow Peril
Old 11-03-2008   #7
Trader Rating: (0)
Thanks Phil.
Paparini is offline
(T) Ticking noise coming from engine. oriongreypunto Punto 8 04-01-2007 23:28
(T) weird engine noise on a 55reg mk2b punto_cruiser Punto 2 10-04-2006 21:03
(T) Uno 1.0 ie. Smelly smoke and knocking noise. SilentPartner Uno 17 27-03-2006 17:00
(T) Strange knocking noise from the Engine when I start on cold mornings darkcircuitUK Punto 1 20-03-2005 17:28
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
