The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-02-2008   #1
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
Fault Codes
Had a service done yesterday and got the following fault codes shown;
1/Air temperature sensor,
2/Air flow meter,
3/Turbo pressure.
So,
1/ is the air temp sensor the green plug on the thermostat?
2 & 3 i think relate to my remap and the odd warning i've had flash up as mentioned in previous posts. This stopped when i cleaned the maf connector a few weeks back.
Anyone have any opinons, Thanks
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 24-02-2008   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Fault Codes
Your thermostat is to do with the water temperature
You air temp sensor is most likely in with your MAF sensor as Mass air flow and air temp (ie density) tells it what size chunks of air are going in to the engine so it would all seem related to the MAF.
There, wish you hadnt touched it now
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 24-02-2008   #3
minimad99's Avatar
Trader Rating: (0)
Re: Fault Codes
It was only the connector i cleaned, haven't had the balls to clean the actual thing. I haven't had any more "beeps" though so maybe that did the trick
Old 24-02-2008   #4
Deckchair5's Avatar
Trader Rating: (0)
Re: Fault Codes
So you cleared the codes and they haven't popped up again? That'll be good
99 Bravo 1.2SX
Old 24-02-2008   #5
performancestilo.co.uk
stilosporting's Avatar
Trader Rating: (5)
stilosporting has donated! United Kingdom
Re: Fault Codes
where did you get the service done?
www.reddotracing.co.uk
162.6bhp 219.8ft-lb
stilosporting is offline
Old 24-02-2008   #6
minimad99's Avatar
Trader Rating: (0)
Re: Fault Codes
Had the codes cleared - YES........... haven't popped back up- DON'T KNOW but haven't had any warning messages.
Roberts Aerospace & Automotive near Southampton. He's an independant Alfa/Maserati Specialist but he does work on Fiats too. He has all the specialist tools and his own examiner.
It's a bit far from you though Frank.
http://www.cars.robertsaerospace.com/index.htm
Old 25-02-2008   #7
Trader Rating: (5)
Re: Fault Codes
i was just curious what hardware/software he was using.
162.6bhp 219.8ft-lb
(T) ECU Fault codes?? HGT Engine cutting out metalgod23 Bravo / Brava 21 01-10-2008 09:33
Fault Codes Stevej Ulysse 2 29-01-2008 12:12
(T) Abarth fault codes? KK1 Stilo 3 23-06-2007 18:02
(T) Abarth Fault Codes Help Please!!! SwissTony Stilo 7 31-05-2007 21:33
