| JTD Multiwagon - unknown engine fault Have a diesel Stilo Multiwagon, its been an excellent car from new, now has 91,000 miles on it. Recently when accellerating firmly at around 2500 revs engine fault indication lights sometimes comes on, then normally goes out. Occasionally engine power drops significantly, which can be embarrasing when passing a wagon etc. Been to Fiat garage locally, run tests and found nothing, anybody any ideas what the cause can be, its happening more often, recent full service made no difference.
| re: JTD Multiwagon - unknown engine fault Hi boilertrol, Welcome to the forum, have a search for "crank sensor" and have a read of other peoples symptoms to see if they match yours. minimad99
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #3 | ||
| re: JTD Multiwagon - unknown engine fault Ive got the exact same behaviur.. Searched the forum for crank sensor, but none of the post match the symptons. The fault comes most of the time when the car needs a little more power. E.g. on the motorway just after you go out to overtake a car you press to accellerate and then sometime the engine fault sign lights and goes out again. The fault just comes on, without the engine loosing power. I've had the engine fault read with an examiner and it says turbo preasure unexpected (or something like that). The funny part is that there is 3 possible fault codes. Turbo preasure too high, Turbo preasure too low and the last Turbo preasure abnormal... I would think that either it is too low or too high. Any thoughts? /Thomas Fiat Stilo 1.9 115 HP Diesel 2003 200.000 km.
| | #4 | ||
| Veracocha | re: JTD Multiwagon - unknown engine fault Guys, have your intercooler pipe checked. Things to look out for is a hiss from the engine bay sometimes accompanied by a good bit of smoke. My reader (& the dealer one) did not report this fault in isolation, just turbo fault. These pipes have a habit of wearing through on the understray apparantly.
| | #5 | |||
Thanks for that reply, is the intercooler pipe the oval shape hard plastic pipe that is quite wide?
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | ||||
| | #6 | ||
| Veracocha | re: JTD Multiwagon - unknown engine fault Courtesy of Argo
| | #7 | ||
| re: JTD Multiwagon - unknown engine fault Thanks both of you. A picture says more than a thousand words.. I'll try and have a look under the car to see if it looks faulty. Just to clarify its the right pipe on the picture, all the way from the top where theres a rubber pipe down and along the hard plastic pipe?
| | #8 | |||
| It's about GO! not SHOW! | re: JTD Multiwagon - unknown engine fault
The tubing FROM the intercooler to carb/manifold seems to be made of a much harder plastic and from what I can gather no one has reported any problems with this yet. Not had any issues myself but Bozzy has had first hand experience of the problem
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #9 | ||
| re: JTD Multiwagon - unknown engine fault It is the pipe on the left. The sections that fail are the short rubber pipe section you can see, and also another short rubber pipe section at the other end of the metal section, where it goes into the intercooler.
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | |||
| | #10 | ||
| re: JTD Multiwagon - unknown engine fault hmm.. been checking the entire pipe from the metal housing where it is attached to the motor down and out to the side of the car, and everything looks ok. The rubber is not old or crumbling and there is no holes... I've been reading about the overboost valve, but my issue is not related to bad weather, the error is also present after a week of sun where all water should be gone.
| | #11 | ||
| re: JTD Multiwagon - unknown engine fault i had the same problem really annoying. try unplugging your maf sensor and taking it for a run the car goes back to defaults. if that does it get ur self a new one. got mine the other day for 96 quid from partco
| | #12 | |||
Just a guess but MAP (rear of engine) sensor might be worth a check.
| | NobleSX | Stilo | 1 | 20-12-2007 11:14 |
| | bozzy | Stilo | 39 | 15-07-2007 23:03 |
| | tremtastic | Stilo | 14 | 19-03-2007 13:15 |
| | ABZSTILO | Stilo | 12 | 15-12-2005 22:35 |
| | timr69 | Stilo | 13 | 04-11-2005 18:52 |
