| | #106 | ||
| Re: Anyone had any success with an ELM323/327 interface Im not looking for code reader/cleaner because this I can do with normal softwares... I can connect with all ELM softwares to car and read/clean codes normaly... Problem is reading parameters like rpm, temperature, speed, air flow... I need interface which can do this. For RPM I can build own application which multiply value from OBD by 4. But speed I can't fix because when I have speed 0 show 0 when I drive show 255 also temperature show allways same I dont remeber how but I think show 120°C if car is cold or hot...
| | #107 | |||
| It's about GO! not SHOW! | Re: Anyone had any success with an ELM323/327 interface
![]() Based on what you just said, your JTD is NOT OBDII compliant (at least based on my testing) How are you managing to clear codes and what software are you using to do so ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #108 | ||
| Re: Anyone had any success with an ELM323/327 interface Im try connect to OBD trought hyperterminal and send code and wait for answer then Im convert from HEX to DEC and Im receive same values than in any software that Im try(Scan Tool, ScanMaster and a lot of other which I don't remeber now...) All give me same values... Then Im reproduce Error on engine and check error code and Im see one error, then Im clear code and read again and code has been cleared I think that Im do with Scan Tool. Then Im on local fiat service ask if can find any error code and he didn't find it...
| | #109 | ||
| It's about GO! not SHOW! | Re: Anyone had any success with an ELM323/327 interface You seem to be making a fair bit of headway on this (have you read the whole thread?) Any chance of listing the full command list you're using?
| | #110 | ||
| Re: Anyone had any success with an ELM323/327 interface Im not read whole thread because there is a lot of post... But in future I will read it... Yesterday Im delete all my OBD programs and data because Im sell device... I have only this PID codes: LINK I hope that this will help you ![]()
| | #111 | |||
I build the interface. Installed the UniDiag program. Selected the Alfa 166 or so configuration file. ![]() No connection with my Fiat ECU. ![]() Unless I do something wrong I am afraid this is also not the solution for our problems. ![]() For the wrong calculations like RPM, I can make new a program to correct this. ![]() But the one’s like speed, that only give 0x00 or 0xFF there is no solution in that. ![]() Dan, Any suggestions about possible error I make in connecting via the UniDiag program? Can you tell us where to find these documents describing the protocol? ![]() Unless there are good suggestions I let it rest a while before I get mad. ![]() Hans.
__________________ Fiat Stilo 1.9 JTD 115 Pk Dynamic, 5 Doors, from Sept. 2003. | ||||
| | #112 | ||
| Re: Anyone had any success with an ELM323/327 interface @Oldman Do you get any data back at all, any keybytes? When setting up the comms settings make sure the DTR box is checked, this powers the circuit and must be ticked. Also, check what the logfile says, you will have to scroll to the bottom of the window as it doesnt do this automatically. My punto hgt works with those settings, i also had to connect tx and rx together and wire them to the kline pin on the odb connector as it doesnt have an L line I believe. Let me know how you get on and Ill see if I can help. Regards Dan
| The following user says "Thank You!" to danhans115 for this useful post: | ||
OldMan (09-07-2008) | ||
| | #113 | ||
| Re: Anyone had any success with an ELM323/327 interface Hi all, Well, I think my car has a L line. ![]() Splitting the K and L did not work. ![]() So I think I have to build another interface, my third one. ![]() ![]() ![]() If I get in the mood, next week more news. ![]()
| | #114 | ||
| Re: Anyone had any success with an ELM323/327 interface Stilo's don't use the L-line.... this was only used until 1997/98 to wake up the ecu - the rest of the communication was done over the K-line. On the later models from 97/98 onward only the K-line was used for wake-up and communication .
| The following user says "Thank You!" to yellowstilo for this useful post: | ||
| | #115 | ||
| Re: Anyone had any success with an ELM323/327 interface Hi, got my Elm327 today and connected to my 2.0 jtd 2004.Various programs seem to talk to ecu ok but dont tell me much. So i used the terminal interface it tells me i have 1 fault so i ask what the fault is ie, 03 and i get 43 00 00 00 which seems to me to mean no fault? I can reset the MIL light but it returns when i start the engine. When i used monitor mode the airflow and rpm change with the throttle. I did a scan with wobd and get the following; Thursday, August 07, 2008 02:56 PM Header: 686AF1 Mode:01-01 Pid:00-FF Suffix: X 0100 SEARCHING... V 0101 81 03 81 00 [....] 2164490496 V 0104 00 [.] 0 V 0105 FF [.] 255 V 010B FF [.] 255 V 010C 00 00 [..] 0 V 010D 00 [.] 0 V 010F FF [.] 255 V 0110 00 18 [..] 24 V 0111 00 00 [..] 0 V 011C 05 [.] 5 Scan Completed Events(s):256 No Data:245 Invalid:1 Zero:4 Does this mean anything?
| | #116 | ||
| It's about GO! not SHOW! | Re: Anyone had any success with an ELM323/327 interface I'd recommend you try digimotolite. It's a free download and should indicate straight away if your JTD is compliant or not (the full version is quite nice too)
| | #117 | ||
| Re: Anyone had any success with an ELM323/327 interface Tried Digimotolite no improvement.Does anyone know exactly how many parameters are in theory readable from the 2.0 jtd in a 2004 ducato. I found copies of the full fiat ecu specifications but as yet they seem to confirm the commands i am using to obtain info. Here they are in case anyone needs them.
| | #118 | ||
| It's about GO! not SHOW! | Re: Anyone had any success with an ELM323/327 interface Useful info but at the end of the day your JTD isn't OBD compliant so all those generic access programs are a waste of time (I presume you've read the whole thread)
| | #119 | |||||
| Re: Anyone had any success with an ELM323/327 interface Hello,
Kind regards, Sander.
| | #120 | |||
CAN Protocol Pins If pins 5, 6, 14 and 16 are populated, the vehicle supports CAN. Pin # Description 5 Ground 6 Data 14 Data 16 Power ISO and KWP Protocol Pins If pins 5, 7, 16 and, optionally, 15 are populated, the vehicle supports ISO or KWP. Pin # Description 5 Ground 7 Data 15 Data (this pin is optional and may not be present) 16 Power VPW Protocol Pins If pins 2, 5 and 16 are populated, the vehicle supports VPW. Pin # Description 2 Data 5 Ground 16 Power PWM Protocol Pins If pins 2, 5, 10 and 16 are populated, the vehicle supports PWM. Pin # Description 2 Data 5 Ground 10 Data 16 Power There are some CAN scanners softwares around the internet, but my questions is if this will work with the ELM interface in case i resolder the pins on the OBD interface side.
__________________ Stilo 1.9JTD Dynamic | ||||
| Tags: ecu, elm323 elm327, maf |
| autogas italia powerjet lpg interface help required | wing1200a | Stilo > Technical | 0 | 22-06-2007 19:56 |
| Poll: This interface vs. FCCUK interface | Skins | Coupe | 38 | 06-12-2005 09:07 |
| my ebay success!!! details within, lol | beau | Leisure Lounge | 6 | 08-08-2005 10:21 |
