The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 03-02-2008   #46
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Anyone had any success with an ELM323/327 interface
Originally Posted by Argonought View Post
ATFI is simply a command (in ASCII) you give to the ECU. If should reply "BUS INIT: OK" (see post #17)
Of course if you can't connect to the ECU then it also means you can't 'talk' to it
It seems Frank's problem might be different to mine as I CAN talk to the ECU. The problem is the ECU replies "NO DATA" to almost everything and what DATA it does provide is rubbish
OK, might have overstated this a bit.
I can certainly talk to the ELM interface OK (with "ATZ") but if I ask the ELM interface to connect to the ECU with ATSI (10.4k baud Slow Interface) or ATFI (Fast Interface) then in both cases I get "BUS INIT: ERROR".
In other words it would seem the ELM interface can't talk to the ECU after all.
I've tried both an ELM323 and ELM327 and both fail so guess it can't be the interface (or at least very unlikely )
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is online now
Old 12-02-2008   #47
performancestilo.co.uk
stilosporting's Avatar
Trader Rating: (5)
stilosporting has donated! United Kingdom
we we using elm327 with no luck.
anyone have any ideas yet? there must be a way to communicate?
www.reddotracing.co.uk
162.6bhp 219.8ft-lb
stilosporting is offline
Old 12-02-2008   #48
Trader Rating: (5)
anyone heard of the obd-diag 4000? lists it a compatable with the punto multijet 2004? can find a price or seller in the uk or any more info?
http://www.obdtools.co.uk/isolist.htm
162.6bhp 219.8ft-lb
Old 13-02-2008   #49
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
If it's any help they have found the same problems in France, they can read eng temp static at 215 and rpm is the figure divided by 4 but that's all.
They reckon that for Stilo diesels pre 2004 you're "cooked" for OBD
Someone believes older models didn't change til 2004 but the newer style models may have it at 2003. They have a lot of diesels over there as you can imagine
Make of it what you will but it might stop somebody going mad
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 13-02-2008   #50
Trader Rating: (5)
my car is 2005 05 so by law needs to be obd 2 or eobd compliant doesnt it?
162.6bhp 219.8ft-lb
Old 13-02-2008   #51
Argonought's Avatar
Trader Rating: (0)
Spot on Decks, this is EXACTLY what I can read
It's totally weird. I can't seem to initialize the ECU bus but I CAN read some data (as above)
I think you'll find they can also read airflow via the MAF sensor but very difficult to know just how reliable these reading are
Old 13-02-2008   #52
Trader Rating: (5)
just to let you know when doing google searches i found about five stilo jtd owners in the same situation. so it is jtd related but not related to year of manufacture.
162.6bhp 219.8ft-lb
Old 13-02-2008   #53
EgyTuner.com...
OzMoSiS's Avatar
Trader Rating: (2)
OzMoSiS has donated! Egypt
totally bizzare considering most software are listing the punto 1.9 diesel and the alfa 147 diesel as compatabile. they and the stilo are rather similar
Originally Posted by dan-the-man View Post
i only have one nipple
OzMoSiS is offline
Old 13-02-2008   #54
Trader Rating: (5)
exactly my point.
162.6bhp 219.8ft-lb
Old 14-02-2008   #55
Trader Rating: (5)
ok more info on the obd-diag 4000
modes / protocols
ISO9141-2
KWP2000 slow init
KWP2000 fast init
PWM
VPWM
CAN 11bit/250kB
CAN 11bit/500kB
CAN 29bit/250kB
CAN 29bit/500kB
K/L transit mode
KK/L transit mode
99.99 euro from www.obd-diag.de/
what do we think??? it was this tool that listed the punto jtdM 2005 as compatible?
162.6bhp 219.8ft-lb
Old 14-02-2008   #56
Trader Rating: (0)
I have an OBD-Diag 4000. I dont think they are very good. Lots of compatibility issues. I have not got it to work on any Citroen or Fiat cars yet. Ford / Mazda, VAG (not can bus) and Vauxhall seems to be OK though. CAN bus seems to be compatible with nothing.
Very limited support/ help, except if you speak german.
john55 is offline
Old 14-02-2008   #57
Trader Rating: (5)
and what year is your jtd?
162.6bhp 219.8ft-lb
Old 14-02-2008   #58
Trader Rating: (5)
according to this site the 1.9 jtdm is ISO http://www.obdtools.co.uk/isolist.htm#fiat
162.6bhp 219.8ft-lb
Old 14-02-2008   #59
Trader Rating: (5)
could one of the fiat techs on here not find out what protocol the stilo jtd uses?
162.6bhp 219.8ft-lb
Old 15-02-2008   #60
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Sorry to hijack the thread, but it is of some relevance...
Anyone tried this?
http://cgi.ebay.com/ebaymotors/ws/eB...198166059&rd=1
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
Tags: , ,
vB code is On
autogas italia powerjet lpg interface help required wing1200a Stilo > Technical 0 22-06-2007 19:56
Poll: This interface vs. FCCUK interface Skins Coupe 38 06-12-2005 09:07
my ebay success!!! details within, lol beau Leisure Lounge 6 08-08-2005 10:21
