| 1.6 16v Dynamic | Fit abarth clocks etc into 1.6 is it possible to fit the abarth tft display ( speedo) etc into the 1.6 stilo without to much work or would it require a lot of rewiring??
__________________ ![]() Member #7 and supporter of MACS Honestly! Does TSC really look like f***ing whores re-united! To find out more about MACS - Click Here! | ||
| EgyTuner.com... | Re: Fit abarth clocks etc into 1.6 rich (rroope) has done this before, didnt require a lot of work, its a straight plug and play jobbie. although he did hav to fiddle with the needles a bit to fit the dials for his 1.8. and possibly your rev and speedo would be out. its something i have also been thinking of. and ohh, you need a connect+ nav to set time, date, etc...
| | #3 | ||
| Glutton for Punishment | Re: Fit abarth clocks etc into 1.6 Shaun, It'll work when the unit is new, however there are reports that it won't work when it has already been proxi-aligned (I got my dash brand new, but this one will be looking for ESP, rain sensors, parking sensors etc) . . . a few greek/italian people I spoke to when I did mine said they had a "Loose Connection" fault (as there are two connectors on the Abarth) and other faults that a proxi-alignment DID NOT cure. Oh, and without the Sat Nav it's kinda pointless anyway, doesn't do anything special except display the same information in a different way. One assumes at over £600 the unit you're looking at is used? Don't forget, you can't edit the mileage down either!
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion Last edited by Rich; 22-04-2007 at 23:02. | ||
| | #4 | |||
Hence moved to the Stilo section under its own thread, where it's proved to be more successful in its own right.
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion Last edited by Rich; 24-04-2007 at 21:34. Reason: Change due to separation thread. | |||
| | activematt | Stilo | 755 | 12-11-2007 15:17 |
