| popping out | painting engine cover Right I've searched and can't find anything, but I've just got up so I may have not looked properly I want to paint my engine and battery cover silver. I'm a complete beginner at painting so what do I need to do? I understand I need to get some heat resistant paint silver, blue and white. do I need to sand the cover down till it's nice and smooth and got rid of all the nobbly bits? lol Cheers
| The modfather | Tiz easy young Dan give your engine and battery cover a damn good clean [make sure there is no gease etc on them]and give then a light rubbing down to key the surface of them I used Hammerite smooth thats the one without the hammer pattern and it hasnt been affected by heat at all so there you are as I said tiz easy Oh if you dont feel happy with a spray then brush it on
__________________ Gone fishing | ||
| | #3 | ||
| popping out | Re: painting engine cover so I don't need to sand the dimples down then? just kind of prime the surface? how long does it take to dry? Cheers Phil, your a very knowledgeable man ![]()
| | #4 | |||
| The modfather |
just a light sanding just to key it for the paint to take to the surface and use the same make of undercoat as top coat hammerite is not compatible with some paints and you can only re coat hammerite within a certain time period read the instructions on the tin ![]()
__________________ Gone fishing | |||
| Punto 75 Engine tuning | StoneNewt | Punto | 4 | 19-07-2006 21:05 |
| Wanted: ROCKER COVER FOR A 1.1 SPORTING CINQ ENGINE (Parts Wanted) | Rob_Randomcruisers.co.uk | For Sale / Wanted | 0 | 14-02-2006 23:39 |
| Multijet available in the UK? | blackJTD | Stilo | 20 | 19-01-2006 07:31 |
| Re-start the engine after couple of minutes | zo_wi | Uno > Technical | 2 | 12-09-2005 16:23 |
| Engine mountings/cam cover ! | minislapper | Uno | 3 | 03-05-2004 02:11 |
