| Glutton for Punishment | Lowering a Stilo - Thread Choice Hey All Due to high repitition rates of threads regarding lowering a Stilo, I wanna put one as a sticky in this section. Now, give me a problem to do with the Stilo's electrics and I'm there , but I know sweet F.A. about lowering! So if someone with experience, Matt, Rob, Phil, and knows a decent thread on here about it (3dr, 5dr, MW, options for each), please let me know; I can merge some threads together if some have relevant info.Once done, I'll unstick this thread and delete it. Cheers peeps!! ![]()
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| T.E.D. | Re: Lowering a Stilo - Thread Choice http://www.fiatforum.com/stilo/84821...lover-kit.html Is that any help? i can do a guide too if you want, i forgot to take pics though when i fitted my kit Jordan
__________________ Total Engineering Developments | ||
| | #3 | ||
| doM repuS | Re: Lowering a Stilo - Thread Choice Looks like Juego has taken some recent pics, for a guide that he is about to do http://www.fiatforum.com/stilo-styli...tml#post950371
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #4 | ||
| Pick a window,your leavin | Re: Lowering a Stilo - Thread Choice Didn't want to start a new thread, let me know if I shouldn't post this here: I have just read on an online store that if you lower a car by more than 30mm then you may have to change to shorter shockers. Is this the case with a Stilo? I wanna drop it, but I can't stretch to any more than just springs. Shocks will come later in the year.
__________________ Please use the 'thanks' button if I've been helpful And let me know how you got on!03 1.2 Stilo 3 door Active, GSR Induction with aluminium oil catch tank. OMP Braking, NBM Woolford braided hoses, Boge Turbo struts, Koni -35mm Springs,17" BSA Manik Rims on Federal Rubber, Blue calipers, Blue Leather gaitors.Back on MSN, see my profile for address. | ||
| | #5 | |||||
| Veracocha | Re: Lowering a Stilo - Thread Choice
| | #6 | ||
| Re: Lowering a Stilo - Thread Choice I have a set of PI -35mm springs coming on Monday....will be fitting them on Tuesday. I take it the guide that was mentioned hasnt yet surfaced? I will take my camera when I do it and sort one out if its of any help. I figure it cant be very difficult if it only takes a garage 2 hours.
| | #7 | ||
| Pick a window,your leavin | Re: Lowering a Stilo - Thread Choice Got mine done yesterday on -35mm Koni springs. Glad I did put it in the garage, they had real problems with the strut tops.
| | #8 | ||
| Re: Lowering a Stilo - Thread Choice Why? They are one bolt on each? I think they may have been justifying their bill.......Ive done my fronts in 1 1/2 hours this morning.....off to do the backs now!
| | #9 | ||
| Pick a window,your leavin | Re: Lowering a Stilo - Thread Choice On this one occasion, the garage weren't trying to take me! I stuck around while they did it, quite interested in watching mechanics working, and the top of the shock kept spinning round with the nut. The garage I took it to (Carson Cars) are top notch fellas, and I'd go back to them any day.
| | #10 | ||
| The modfather |
| | #11 | ||
| Re: Lowering a Stilo - Thread Choice Yep! Easy as that.......you need to seek out a garage that knows what its doing! The rears took me 50 minutes for both sides. 2hrs 20minuts in total...plus maybe 20 minutes setting up and clearing away. It was all basic stuff. I can easily do a guide for it as I took a set of photos as I went. I just need to know where to send it etc....I'm rubbish with a computer! The best thing about doing it was that you only need 3 spanners....6mm, 17mm and 19mm. The only other tools are a set of spring clamps, a screwdriver and a 6mm allen key......most cars need twice that amount of stuff. It has improved the handling nicely....not too stiff, but it feels more planted and it no longer looks like its set for 'off road' but at the same time its not 'slammed to da max bro!!!' and I wont need to avoid speed humps!! ![]()
| | #12 | |||
| It's about GO! not SHOW! |
What made you chose -35mm PI's over -30mm Eibach's ?
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #13 | ||
| Pick a window,your leavin | Re: Lowering a Stilo - Thread Choice They used the allen key. And it rounded out and split the top of the shocker. They had no problem at all with the other bits, just that one shock.
| | #14 | |||||
) and the Eibachs were £150 where as............Ive been out in it today for a reasonable run and it feels good....as I said not too hard but firmer than it was. It looks good too.....35mm is by no means low. It looks like it was meant to be that low. Chris, presumably now the garage have massacred your shock, youve had to have a new one? I hope theyre paying!!!
| | #15 | ||
| Pick a window,your leavin | Re: Lowering a Stilo - Thread Choice I'm usually the first one to have a go about garages ripping me off, but they didn't do anything wrong.They put the allen key in the top to hold the shock still and a spanner on the nut to undo it.They turned the nut and the top of the shock just split.I really don't think on this occasion it was their fault.
| Abarth Badges on None Abarths' | Koa | Put it to the Vote... | 72 | 19-08-2005 14:20 |
| Club Stilo......................... | twincamms | Stilo | 12 | 06-12-2004 23:04 |
| The Effects of lowering a Stilo. | Koa | Stilo > Styling | 88 | 21-11-2004 21:18 |
| Stilo Abarth - My humble opinion | Roberto | Stilo | 0 | 14-07-2002 22:06 |
