The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Styling
Old 04-05-2008   #1
Trader Rating: (0)
WETBUTSAFE has donated! United Kingdom
HELP NEEDED !!! Which H7's do I fit..?
Hi everyone this is my 1st thread & probably not my last...
I need advice on what is the best H7 replacement "dipped" bulb to fit my recently purchased STILO 1.9 JTD ( 115 ) which I am impressed with..?
I was thinking between
Philips Extreme + 80
or the more recent
Philips Diamond Vision
Has any STILOIAN got either or can offer well appreciated advice
Many thanx for looking
WETBUTSAFE
WETBUTSAFE is offline
Old 04-05-2008   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: HELP NEEDED !!! Which H7's do I fit..?
I'm sure this has been done before on the Forum.
Try the SEARCH tool and you should find the posts.
Welcome BTW
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 04-05-2008   #3
Low Rider..............
coyle's Avatar
Trader Rating: (0)
coyle has donated! United Kingdom
I was pondering the same question..but iwent for it and got a H7 dipped beam conversion kit. They look fantastic! So very bright. You'll probs need some help on fitting the bulbs, as there not simple. So see my thread about how i fitted them. You could also considering uprating the sidelight bulbs at the same time
My Thread:
http://www.fiatforum.com/stilo/14516...heres-how.html
coyle is offline
The following user says "Thank You!" to coyle for this useful post:
WETBUTSAFE (05-05-2008)
Old 04-05-2008   #4
Trader Rating: (0)
Question Re: HELP NEEDED !!! Which H7's do I fit..?
I've got a set of Hids to fit but, although I've read your guide it doesn't go into great detail on the wiring side. I've got 2 wires on my Hids and what do I attach them to? I've also got 4 of the 4 led sidelights to fit, did you have any problem with the blown bulb warning system going into overdrive when you fitted yours? I've seen them advertised with resistors to resolve this possible issue.
Stilo
Last edited by Kirbs : 04-05-2008 at 22:01. Reason: Forgot the other half of the question.
Kirbs is offline
Old 05-05-2008   #5
coyle's Avatar
Trader Rating: (0)
remove the two wires from the standard bulb....attach them to the two wires which feed in to your HID balast. it then gets amplified.
you should have wires going out of you balast now. they go to the new bulb.
I didnt have to do any cutting.
once you have your light unit out, it becomes very obvious what connects to where. and shouldnt take much more that 5mins on each side.
with regards to the side lights. had no problems realy. none of them worked till i turned them round then they all worked fine. and i did get the bulb failure system coming on. but after about 10mins it went off, and hasnt been back on since
coyle is offline
Old 05-05-2008   #6
has pooped his pants
Greggers's Avatar
Trader Rating: (0)
Greggers has donated! United Kingdom
or the more recent
WETBUTSAFE
I went for the Philips +50%'s and I've been really happy with them. The +80% are probably brilliant... literally!
If you're after a HID conversion, read some of the threads about them on here first, by all means go for a HID conversion kit, just be careful to make sure it's actually legal...
02 Fiat Stilo Abarth Selespeed (5dr)
Navy Blue, Cream Full Leather Interior, 17" Anthracite Alloys, Schumi GP Eibach Springs and Bilstein Dampers, Denso Iridiums, EBC RedStuff Pads. Want: Ragazzon/Supersprint Cat-Back Exhaust
Greggers is offline
Old 06-05-2008   #7
chicken_chau_mein's Avatar
Trader Rating: (0)
I fitted the philips +80's and i was really happy with them... Until one blew after only a few months use. Just then the osram nightbreakers were released with +90 light and +10% whiter!
Naturally i went for those but i just seem to prefer the philips.
Both are impressive either way.
chicken_chau_mein is offline
vB code is On
Does H4's fit the grande or H7's??? Scott_20 Grande Punto 5 07-01-2008 19:11
help needed! what can i fit? (head unit) russellsb Bravo / Brava 5 21-12-2007 15:52
Help Needed - Ducato 2.9 td recon engine supply and fit London RichyP Ducato 2 11-08-2007 19:32
whats needed to fit punto gt alloys?? beau Cinquecento / Seicento 21 26-06-2007 15:46
HELP Needed to fit BRAVO SX Gearbox mapleleafs Bravo / Brava 2 08-01-2007 15:47
