| HELP NEEDED !!! Which H7's do I fit..? Hi everyone this is my 1st thread & probably not my last... I need advice on what is the best H7 replacement "dipped" bulb to fit my recently purchased STILO 1.9 JTD ( 115 ) which I am impressed with..? I was thinking between Philips Extreme + 80 or the more recent Philips Diamond Vision Has any STILOIAN got either or can offer well appreciated advice Many thanx for looking WETBUTSAFE
| It's about GO! not SHOW! | Re: HELP NEEDED !!! Which H7's do I fit..? I'm sure this has been done before on the Forum. Try the SEARCH tool and you should find the posts. Welcome BTW
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| Jon & Co... | Re: HELP NEEDED !!! Which H7's do I fit..? I was pondering the same question..but iwent for it and got a H7 dipped beam conversion kit. They look fantastic! So very bright. You'll probs need some help on fitting the bulbs, as there not simple. So see my thread about how i fitted them. You could also considering uprating the sidelight bulbs at the same time ![]() My Thread: http://www.fiatforum.com/stilo/14516...heres-how.html
__________________ Stilo, Private Plate, Black Chrome 17" Blades, GSR'd, Lowered 50mm on Eibach Kit, Wind Deflectors, Fiat Sun Shades, BIG ICE, Abarth Badges, Debadged Rear, Abarth Body Kit, Fully Colour Coded, Debadged Grill with Added Fiat Badge, Detailed Engine Bay, Painted Callipers, Richbrook Arial | ||
| The following user says "Thank You!" to coyle for this useful post: | ||
WETBUTSAFE (05-05-2008) | ||
| | #4 | ||
| I've got a set of Hids to fit but, although I've read your guide it doesn't go into great detail on the wiring side. I've got 2 wires on my Hids and what do I attach them to? I've also got 4 of the 4 led sidelights to fit, did you have any problem with the blown bulb warning system going into overdrive when you fitted yours? I've seen them advertised with resistors to resolve this possible issue.
__________________ '54 3 Dr Stilo 1.9 JTD Dynamic, Metallic Black,Tinted Windows, Blade Sunroof, Full Abarth Body Kit, 18" Ace Aviators, Twin Freeflow Exhausts, Sports Cat, Heated Screenwash, 40mm Wheelspacers on Front Wheels, Brakes; (Front) Drilled Brembo GT's - (Rear) Crossdrilled Nitrac Discs with Ferodo Performance Pads, Suspension - Coilovers KW Inox-Line Version 1. Last edited by Kirbs : 04-05-2008 at 23:01. Reason: Forgot the other half of the question. | |||
| | #5 | |||
you should have wires going out of you balast now. they go to the new bulb. I didnt have to do any cutting. once you have your light unit out, it becomes very obvious what connects to where. and shouldnt take much more that 5mins on each side. with regards to the side lights. had no problems realy. none of them worked till i turned them round then they all worked fine. and i did get the bulb failure system coming on. but after about 10mins it went off, and hasnt been back on since
__________________ Stilo, Private Plate, Black Chrome 17" Blades, GSR'd, Lowered 50mm on Eibach Kit, Wind Deflectors, Fiat Sun Shades, BIG ICE, Abarth Badges, Debadged Rear, Abarth Body Kit, Fully Colour Coded, Debadged Grill with Added Fiat Badge, Detailed Engine Bay, Painted Callipers, Richbrook Arial | |||
| | #6 | |||
| has pooped his pants | Re: HELP NEEDED !!! Which H7's do I fit..?
If you're after a HID conversion, read some of the threads about them on here first, by all means go for a HID conversion kit, just be careful to make sure it's actually legal...
__________________ 02 Fiat Stilo Abarth Selespeed (5dr) Navy Blue with Cream Full Leather Interior 17" Razor Alloys, Denso Iridium Sparkplugs All Standard but Want the GSR Induction and ReMap ![]() | |||
| | #7 | ||
| Re: HELP NEEDED !!! Which H7's do I fit..? I fitted the philips +80's and i was really happy with them... Until one blew after only a few months use. Just then the osram nightbreakers were released with +90 light and +10% whiter! Naturally i went for those but i just seem to prefer the philips. Both are impressive either way.
__________________ | |||
| Does H4's fit the grande or H7's??? | Scott_20 | Grande Punto | 5 | 07-01-2008 19:11 |
| help needed! what can i fit? (head unit) | russellsb | Bravo / Brava | 5 | 21-12-2007 15:52 |
| Help Needed - Ducato 2.9 td recon engine supply and fit London | RichyP | Ducato | 2 | 11-08-2007 20:32 |
| whats needed to fit punto gt alloys?? | beau | Cinquecento / Seicento | 21 | 26-06-2007 16:46 |
| HELP Needed to fit BRAVO SX Gearbox | mapleleafs | Bravo / Brava | 2 | 08-01-2007 15:47 |
