| | #3 | ||
| Re: should I?? or shouldn't I?? lower it!!!!!!!!!!!!!!!!!!!!!!!
__________________ 1.4 16v 6-speed Fiat Stilo. Mods: Lowered 40mm on Eibach Springs | Sparco pedals | Sparco Gear Knob | Birba Dials | GSR Induction kit | Ragazzon twin exhaust | KYROS front bumper | 17" Fiat Abarth alloys | Kicker soundsystem | Window tints all round | |||
| | #4 | ||
| doM repuS | Re: should I?? or shouldn't I?? Lower
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #5 | ||
| Falling Into A Trap | Re: should I?? or shouldn't I?? im going to be the only one that says standard, but then again its your car i calculated that i wouldnt be able to get in and out of my drive with it lowered as its on one hell of an angle ![]()
__________________ JOSHUA FROST-LUNN STILO | ||
| | #6 | ||
| It's about GO! not SHOW! | "Been there and done that" as they say ![]() If you really want to lower it then make sure you go for Eibachs -30mm rather than cheap springs. I'd also up-rate the dampers on the front at least. I used cheap Pi springs which was a big mistake (nearly 40mm drop) even if the car did look better It was pure joy to get back to standard springs afterwards - could actually push it through those fast curves again ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #7 | ||
| Dislikeskeyboardwarriors | Re: should I?? or shouldn't I?? going to try my best to get it lowered and cambelt/serviced by the time of donny then, got quite a challenge i think! ![]()
__________________ | ||
| | #8 | |||
| __________ | Re: should I?? or shouldn't I??
![]() courier has phoned though to say sorry, stuck in traffic all day, i can belive that as he was in west london, and m25 been blocked all day
__________________ Binki | |||
| | #11 | ||
| Low Rider.............. | Re: should I?? or shouldn't I?? As little john says- Get low! ![]()
__________________ Stilo, Private Plate, Black Chrome 17" Blades, GSR'd, Lowered 50mm on Eibach Kit, Wind Deflectors, Fiat Sun Shades, BIG ICE, Abarth Badges, Debadged Rear, Abarth Body Kit, Fully Colour Coded, Debadged Grill with Added Fiat Badge, Detailed Engine Bay, Painted Callipers, Richbrook Arial | ||
| | #12 | ||
| Re: should I?? or shouldn't I?? Two brief comments: 1) As an alternative to lowering which preserves a half-decent ride quality but improves handling, how about fitting uprated dampers to standard springs? I've done this with KONI Sport Adjustables and am very pleased with the result. 2) If you do change your springs, don't bother with spring compressors. Take your struts to a garage and ask them to do it (even they will struggle unless they have a commercial press). The Stilo standard front springs take a lot of compressing and most DIY compressors can't 'squash' the springs enough to free up the top mount to allow them to be removed from the strut...
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive | |||
| | #13 | ||
| Re: should I?? or shouldn't I?? Steely, I'd echo what has already been said, LOWER IT LOWER IT LOWER IT, LOL but........... if you going to do it, do it properly and fit Eibach Spirngs with matching struts/shocks. I fitted Eibach springs with Boge shocks and although the shocks are OK, i think the overal handling could be better with eibach shocks.
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | |||
| | #14 | |||
| It's about GO! not SHOW! | Re: should I?? or shouldn't I??
Changing back to standard springs is a great education is seeing just how effective the oem dampers are when matched to the correct springs. After 6 mths of driving lowered (and then reverting to standard) the effect is quite amazing as you can actually feel the suspension soaking up every bump instead of trying to bounce You soon get used to it though and that's a big problem with mods as you can also get used to something being wrong ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #15 | |||||
