The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Styling
Old 10-03-2008   #1
Dislikeskeyboardwarriors
Steely's Avatar
Trader Rating: (0)
Steely has donated! United Kingdom
should I?? or shouldn't I??
lower it??
or keep it standard??
you decide!!!
Steely is offline
Old 10-03-2008   #2
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
Re: should I?? or shouldn't I??
lower Lower Lower Lower Lower
Binki
dave is offline
Old 10-03-2008   #3
Brookesy's Avatar
Trader Rating: (0)
Ireland
lower it!!!!!!!!!!!!!!!!!!!!!!!
1.4 16v 6-speed Fiat Stilo.
Mods: Lowered 40mm on Eibach Springs | Sparco pedals | Sparco Gear Knob | Birba Dials | GSR Induction kit | Ragazzon twin exhaust | KYROS front bumper | 17" Fiat Abarth alloys | Kicker soundsystem | Window tints all round
Brookesy is offline
Old 10-03-2008   #4
doM repuS
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Lower
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 10-03-2008   #5
Falling Into A Trap
Joshua Frost-Lunn's Avatar
Trader Rating: (0)
Joshua Frost-Lunn has donated! United Kingdom
im going to be the only one that says standard, but then again its your car
i calculated that i wouldnt be able to get in and out of my drive with it lowered as its on one hell of an angle
JOSHUA FROST-LUNN STILO
Joshua Frost-Lunn is offline
Old 10-03-2008   #6
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Lightbulb Re: should I?? or shouldn't I??
"Been there and done that" as they say
If you really want to lower it then make sure you go for Eibachs -30mm rather than cheap springs.
I'd also up-rate the dampers on the front at least.
I used cheap Pi springs which was a big mistake (nearly 40mm drop) even if the car did look better
It was pure joy to get back to standard springs afterwards - could actually push it through those fast curves again
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 10-03-2008   #7
Steely's Avatar
Trader Rating: (0)
going to try my best to get it lowered and cambelt/serviced by the time of donny then, got quite a challenge i think!
Steely is offline
Old 10-03-2008   #8
__________
dave's Avatar
Trader Rating: (9)
pah afternoon job, i still got no engine and gearbox
courier has phoned though to say sorry, stuck in traffic all day, i can belive that as he was in west london, and m25 been blocked all day
Binki
dave is offline
Old 10-03-2008   #9
Steely's Avatar
Trader Rating: (0)
does he know its a ring road??
first plan of action.. spring compressors!!
Steely is offline
Old 10-03-2008   #10
__________
dave's Avatar
Trader Rating: (9)
should have said before meet, i have some of them
Binki
dave is offline
Old 10-03-2008   #11
Low Rider..............
coyle's Avatar
Trader Rating: (0)
coyle has donated! United Kingdom
As little john says- Get low!
coyle is offline
Old 11-03-2008   #12
Trader Rating: (0)
Two brief comments:
1) As an alternative to lowering which preserves a half-decent ride quality but improves handling, how about fitting uprated dampers to standard springs? I've done this with KONI Sport Adjustables and am very pleased with the result.
2) If you do change your springs, don't bother with spring compressors. Take your struts to a garage and ask them to do it (even they will struggle unless they have a commercial press). The Stilo standard front springs take a lot of compressing and most DIY compressors can't 'squash' the springs enough to free up the top mount to allow them to be removed from the strut...
Phil Thomas
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive
Yellow Peril is offline
Old 11-03-2008   #13
minimad99's Avatar
Trader Rating: (0)
minimad99 has donated! United Kingdom
Steely,
I'd echo what has already been said, LOWER IT LOWER IT LOWER IT, LOL
but........... if you going to do it, do it properly and fit Eibach Spirngs with matching struts/shocks.
I fitted Eibach springs with Boge shocks and although the shocks are OK, i think the overal handling could be better with eibach shocks.
3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads
RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE
minimad99 is offline
Old 11-03-2008   #14
Argonought's Avatar
Trader Rating: (0)
So did you change your rear dampers or only the fronts?
Changing back to standard springs is a great education is seeing just how effective the oem dampers are when matched to the correct springs.
After 6 mths of driving lowered (and then reverting to standard) the effect is quite amazing as you can actually feel the suspension soaking up every bump instead of trying to bounce
You soon get used to it though and that's a big problem with mods as you can also get used to something being wrong
Old 11-03-2008   #15
Nello's Avatar
Trader Rating: (0)
PI's no good then? My mate swears by them on his Coupe?
Nello is offline
vB code is On
