Comment
Guide Tools Search this Guide
Cleaning Your Inlet Control Valve
Deckchair5
09-11-2006
CLEANING THE INLET CONTROL VALVE/ THROTTLE/ IDLE CONTROL/ BUTTERFLY VALVE<br />
<br />
SYMPTOMS<br />
Unsteady and too low idle rpm cycling between 700 to 500rpm. No power at tickover as engine is struggling and it's easy to stall. You put the aircon on just to bump up the tickover a bit. Tricky
Old 07-01-2012   #60
colchesterlad has donated!
Re: Cleaning Your Inlet Control Valve
Quote Originally Posted by Davren View Post
The JTD engine doesn't have an inlet control valve.
sorry my mistake
colchesterlad is offline Reply With Quote Quote
Old 23-01-2012   #61
The examnier read 'Throttle Body' for my fault and my car doesn't start first time and it lost power when going at 70mph. Plus Engine fault lit for a week now.
It doesn't stall though ot have rev issue. Is cleaning it as above unlikey to help. Garage have said gven symtoms and examiner I need a new throttle body.
Any advice? Thanks. Also I notice above say harder to get to on 1.4, where is it anyone and how difficult to reach?
HornetUK is offline Reply With Quote Quote
Old 02-03-2012   #62
Light Seeker
vladof's Avatar
vladof has donated!
Romania
Clean the throttle body mate. Cleaning the valve will most likely not solve this issue.
Next time you have in issue not related to the inlet control valve, please start a new thread within the Stilo section. Unfortunately not many people are subscribed to this guide.
If you still have this problem, we can continue the conversation there.
Cheers.
______________________________________________
Stilo 1.8 Dynamic, 5 door, 2002, Navy Blue
Stilo 1.8 Dynamic, 5 door, 2002, Nero Moire VR
vladof is offline Reply With Quote Quote
Old 21-05-2012   #63
I have a W reg Bravo that is stalling at junctions/roundabouts. Is this process the same?
Rich L is offline Reply With Quote Quote
Old 21-05-2012   #64
Light Seeker
vladof's Avatar
vladof has donated!
Romania
It should be, if it's petrol. Although there may be several other factors that cause the problems.
Comment
Search this Guide:
(G) idle control valve cleaning gigahr Punto (Mk2/2b) 3 10-09-2006 17:56
(T) idle air control valve robinstall Punto (Mk2/2b) 0 23-06-2006 15:30
(G) Idle Control Valve AGAIN !! Capt T Ulysse 1 09-04-2006 19:11
bleed valve/adjustable boost control VS FSE Powerboost valve Bushboy Lets Talk FIAT 33 22-02-2006 17:58
(G) Cleaned idle control valve now worse Capt T Ulysse 3 26-12-2005 13:35
