The FIAT Forum
Go Back   The FIAT Forum > Guides > Stilo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->How to Fit/Remove your grille<!-- google_ad_section_end -->
Published by Ben R
13-05-2006
Removing the FIAT Stilo Grille
Tools you will need:
  • T30 Torx Driver
  • Small pry bar or flat ended screw driver
How to do it:
First, undo the torx bolts that hold the top of the bumper on.
Next, gently pull the bumper forward and look behind it - you should see the lugs that hold the grille in place. With the prybar (or screwdriver) very gently and carefully lever the lugs out.
The bottom lugs are a little more difficult so be patient! Place the screwdriver underneath them and gently lever them towards you - you'll hear them pop once they're free.
You should then be left with the sight of this ....
To fit the new grille, just use the same process in reverse order (top first so that the gille lays flat). The bottom ones again are more difficult - place the screwdriver above the lugs & ease them in, as before, you will hear them pop once they're in.
Now go and make yourself a celebratory cup of tea
Article Tools
Old 21-05-2006   #1
Stilo Possee
Firewarrior's Avatar
Trader Rating: (0)
Firewarrior has donated!
Re: How to Fit/Remove your grille
Its good to see a guide on how to do it properly, i just yanked mine off and broke it lol
Firewarrior is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(S) msdesginuk front grille???? xxemmaxx Stilo 23 21-06-2005 22:11
(G) MK1 Mesh Grille?? F R O S T Y Uno 17 06-05-2005 01:05
