| Re: How to fit a front upper strut brace! I gave the Strut Brace a good testing on the way home. 100% improvement from such a simple and cheap mod. Cornering roll is reduced, no more understeer, more sensitive and precise steering with plenty of feedback. Well recommended, well fitted and well done Ben - thanks mate
| 5vp3r m0d | Re: How to fit a front upper strut brace! BTW, I intend to make the photos bigger ![]() Nice How-To though
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #3 | ||
| Re: How to fit a front upper strut brace! hey mate im kinda stuch i ahve the same stutbrace as you.it wont go down because its hittins somtheing.like a tube.it kinda looks like a nos can.do i need to unbolt it?thanks
| | #4 | ||
| Orka inte | Re: How to fit a front upper strut brace! Consider myself braced. Great guide. Worked like a charm. Never again will I need a garage to fit a strut brace.. can't believe how easy it was.
__________________ HO! HO! HO! Den som väntar på nåt gött väntar aldrig för länge I think you'll notice when I turn this way, I'm done talking to you! | ||
| | #5 | ||
| Re: How to fit a front upper strut brace! All, Just a quick heads up on the front strut brace.... only relevant if your a selespeed owner! It would appear the Fiat in their wonderful wisdom have at somepoint changed the selespeed reservoir. When I came to fit the brace on my 54 Stilo, there was no way it was possible with the reservoir. When comparing the pictures, the reservoirs are totally different.
__________________ 08 Bravo 1.4 T-Jet (All the options except for the MP3 CD Player.... who needs it anyway!) Drive it like you stole it! | |||
| | #6 | ||
| Re: How to fit a front upper strut brace! I think JTD's might have a problem with this procedure as; the fuel (or is it the oil) filter is in the way of the strutbrace; I remember there was a post in which someone said that she lowered the filter a bit to allow the strutbrace in the engine compartment...
__________________ Stilo 1.9 JTD, 145 BHP (re-mapped), Sassi Grey | |||
| | #7 | ||
| NobodyBlamesTheHappyGuy:D | Re: How to fit a front upper strut brace! Hello. This is an excellent guide, which I followed until I reached the last point... After mounting my OMP brace I found it strange that I should pull the brace ends inwards (shorten it). Stress over years of enthusiastic driving will most likely make the suspension turrets bend inwards, and hence the need to be pushed further away from each other, to it's original state. Result: The car is now even more stable when cornering. But... am I totally wrong here?Regards, Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | ||
| | #8 | ||
| Re: How to fit a front upper strut brace! Nice tip Morten. I've just adjusted mine as you suggested and got more than a full turn of the adjuster in the opposite direction (lengthening the brace). Now we just need someone with lots of engineering know-how to come on here and tell us it's the worst thing we could have done! But until then, we'll enjoy..!
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive | |||
| | #9 | ||
| The modfather | I believe that the brace should be in a neutral position neither pushing outwards or pulling inwards at the turrets ..I am in the process of building and designing a new turret mount for the stilo and have a working prototype the new brace will have adjustments at both mounts and on the bar
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #10 | ||
| Re: How to fit a front upper strut brace! Fitted mine today on a 1.4 16v, no major problems, just that you have to move the stuff from the left turret(looking from outside), and when installed the brace vibrates against the thing in the image, on the upside the vibrations do make the car sound kinda beefy under acceleration but i would suggest mounting a bit further towards the back. i used 4.5mm self tapping bolts (10mm head) a 3mm bit to start the holes off but then that snapped
__________________ Last edited by oliemery311; 07-08-2007 at 23:34. | |||
| | #12 | ||
| Re: How to fit a front upper strut brace! Hi! Houmies! I´m new here, i live in Spain and i bought a front&rear Strutbrace for my Fiat Stilo "stilin" 1.4 16v. 95hp. Good. I received the strut braces but i don´t know how to fit the bars.... the front with this tutorial... perfect except one thing.... not have sujection for below? only a 3 screw? not hit with a suspension? But... What happened with the rear strutbrace? I don´t know how install. I need your help please because i bought the bars and i believe how install it but I am a silly. Thanks very much. I wait your help. If you should have the amability of upload a photo... better. Thanks all.
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| | fredjudd | Cinquecento / Seicento | 31 | 03-10-2005 22:47 |
| | _CinqueCento_ | Cinquecento / Seicento | 8 | 28-01-2005 17:29 |
| | tearer | Cinquecento / Seicento | 2 | 20-04-2004 18:01 |
| | Bushboy | Cinquecento / Seicento | 25 | 17-03-2004 08:18 |
| | Mikey_B | Cinquecento / Seicento | 13 | 09-03-2004 21:18 |
