| Banned | Re: Amp wire - 1.6 - How I Did It Nice one cheers for the info!
| Grand Stilismo | Re: Amp wire - 1.6 - How I Did It Yeah - No probs with the switch - Just pop it out - Then disconect the plug (yellow wires) and remove the screw behind - then the two that hold the panel in on the glove box ![]()
__________________ http://photobucket.com/albums/y20/Bo...h_IMG_0646.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0310.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0315.jpg ***************** Broom Yella Fella **************** | ||
| Re: Amp wire - 1.6 - How I Did It So the power cable goes from the battery through the first gromit hole right next to the ABS sensor thing behind the suspension block then round past the bonnet hinge through another grommit hole? Is that correct?
__________________ 2002 1.9 JTD 3dr Dynamic with Colour Coded Bumper strips in Crystal Green Sitting on 18's! ![]() | |||
Errr ... Yes ... Its kinda up and over to the left of the bonnet hinge - I could not get the camera in there ![]()
__________________ http://photobucket.com/albums/y20/Bo...h_IMG_0646.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0310.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0315.jpg ***************** Broom Yella Fella **************** | |||
PS sorry about the messy thread Stu ![]()
| Re: Amp wire - 1.6 - How I Did It Hey good stuff, glad you worked it out ... couldn't have done it better myself ![]()
__________________ http://img222.exs.cx/img222/1523/evil6ae.jpg | |||
| Re: Amp wire - 1.6 - How I Did It Ive poked every utensil ive got down that hole, and I cant get the little bleeder out! Any one got any tips?????? Also I need an ignition live, where the best place to take it from?
| Grand Stilismo | Re: Amp wire - 1.6 - How I Did It You have found the gromet I'm on about ? I just pushed the gromet with a screw driver (I was trying to make a hole in it) and it poped out, thats why I put some silicon in its place. Just wire the Ignition and the permanant together to the main live on the loom ... ok the headunit wont switch off with the key but it will save some time ... and remind you to remove the face. You could just run it from the fag lighter ... that works from the ignition.
| Re: Amp wire - 1.6 - How I Did It Its really hard to get to it with a screw driver, and to dark. I think im gunna have to take off the black plastic strip along with the wipers off to get to it. Anyone pulled apart the trim to get to the fag lighter yet? Is it easy?
| Grand Stilismo | Re: Amp wire - 1.6 - How I Did It Use a Torch .. thats what I did ![]()
| Re: Amp wire - 1.6 - How I Did It Is there anyway you can run the power cable down the drivers side as ive already put the rca's and others down the passenger side?
| Re: Amp wire - 1.6 - How I Did It Hey, i seem to be having a bit of a problem locating the gromet, anything i could be doin wrong? all i can see is a tiny bit of a rubber bung style thing,but not enough to do ote with. Benvo
| Veracocha | Re: Amp wire - 1.6 - How I Did It That's the one. Long thin screwdriver with power cable attached to the end and push like a bas**** through to the other side. More likely the gromit will go through with it into the bulkhead.
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| All About Amps | Luke | ICE Guides | 2 | 08-06-2008 19:32 |
| How to wire an Amp | Luke | ICE Guides | 1 | 14-04-2008 08:00 |
| Guide: How to wire an Amp | Luke | I.C.E | 3 | 11-07-2005 17:33 |
| Amps – The difference between all. | Luke | I.C.E | 4 | 20-06-2005 14:29 |
