Closed Guide
Guide Tools
<!-- google_ad_section_start -->1.2 Timing Belt Change<!-- google_ad_section_end -->
1242cc (Taken from Autodata 2004)
Published by richydraper
22-08-2011
Unrated
User Rated:Unrated
Timing Belt Replacement Intervals
Apart from the visible condition of the belt. which is explained fully later in this section. there are several other factors which must be considered when checking a timing belt:
1. Is the belt an original or a replacement
2. When was the belt last replaced and was it at the correct mileage
3. Is the service history of the vehicle known
4. Has the vehicle been operated under arduous conditions which might warrant a shorter replacement interval
5 Is the general condition of other components in the camshaft drive, such as the tensioner, pulleys, and other ancillary components driven by the timing belt, typically the water pump, sound enough to ensure that the life of the replacement belt will not be affected
6. If the condition of the existing belt appears good. can you be satisfied that the belt will not fail before the next check or service is due
7. If the belt does fail, have you considered the consequences. If the engine is an ‘interference’ type then considerable expensive damage may well be the result.
8. The cost of replacing a belt as part of a routine service could be as little as 5to 10% of the repair cost following a belt failure. Make sure you are aware of the consequences.
9. If in doubt about the condition of the belt - RENEW it.
*Where possible the recommended intervals have been compiled from vehicle manufacturers information. In a few instances no recommendation has been made by the manufacturer and the decision to replace the belt must be made from the evidence of a thorough examination of the condition of the existing belt.*
Contents
<< <    Next Page: Check for Engine Damage (Page 1 of 7)    >  >>
Old 22-08-2011   #1
Trader Rating: 10
dave has donated!
Re: 1.2 Timing Belt Change
you only need to lock the exhaust cam for a belt change. the other cam cant move
“What is right is not always popular and what is popular is not always right.”
Albert Einstein.
dave is offline
Old 23-08-2011   #2
the 1.2 is a single cam isnt it?
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline
Old 23-08-2011   #3
Trader Rating: 10
dave has donated!
no 16v twin cam single pulley
Albert Einstein.
dave is offline
Old 23-08-2011   #4
learn sommin new every day cheers dave
Rich
Old 25-01-2012   #5
Banned
MarkThompson4 has donated!
I read from another source that on the 1.2 16v twin cam it didn't get set at TDC, rather it was set so that all 4 pistons were in line with each other, do you know if this is true?
MarkThompson4 is offline
Old 26-01-2012   #6
i can neither confirm or deny this
Rich
Old 26-01-2012   #7
Trader Rating: 10
dave has donated!
Quote Originally Posted by MarkThompson4 View Post
or course it is, you must use the tools or you will bugger it up like so many before
Albert Einstein.
dave is offline
Old 02-02-2012   #8
D-Turbo POWW!!!
m20b25 has donated!
Ireland
Yes, no1 piston is halfway down on its downstroke.
They line up in order to lock the cams.
For goodness sake, don't use chalk or tippex to time these as the cam sprocket has to be loosened (with the special tool for holding the sprocket) for the belt to be properly fitted!
The ultimate driving machine, the real M20B25
"Ride me sideways"
VAN-dalised Bravo
Small, fuel economic, environmentally friendly Alfa
I am this gombeen
m20b25 is offline
Old 19-05-2012   #9
Hi did my timing belt and tensioner today stilo 1.4 16v just over 40,000 on the clock I just did what I have done many times before tippex took about 45min
fig1 is offline
Old 19-05-2012   #10
Trader Rating: 16
beau has donated!
i too have changed alot of super fire 16v cambelts and only ever used the tippex method (i used a green touch up stick though lol)
Maserati 3200 GT Coupe
beau is offline
Old 19-05-2012   #11
Trader Rating: 10
dave has donated!
belt tension wont be right if you used tipex
Albert Einstein.
dave is offline
Old 22-05-2012   #12
Chris
Trader Rating: 2
Bushboy has donated!
Ok, This is the most complicatedly worded guide I have ever read.
Doing this myself in a few days (need to replace the water pump). I have grudgingly purchased a pair of locking tools and a tentioner tool. I can't help think Ive wasted my money. If there is only a single pulley, why do I need to lock the cams in place?
The timing on my engine is spot on as is so surely removing the old belt, whacking over a new one and tentioning will do the job? Kinda can't see why it wont? Why does the cam pulley need to be loosened when tentioning? If I didn't lock the cams, I wouldnt need to and why would I need to lock the cams if the timing is right?
Hi!
Bushboy is offline
Old 22-05-2012   #13
Trader Rating: 10
dave has donated!
belt wont tension right if cam pulley isnt loose. you only need to lock front cam for belt change
Albert Einstein.
dave is offline
Old 25-05-2012   #14
Chris
Trader Rating: 2
Done the belt change.
Don't bother with the tools if you are changing the belt on an already timed engine. Total waste of money and not needed.
There is a guide on BOO (for the 1.2 16v bravo but same engine) which explains how to do it without any tools although I just found it exactly the same as doing the 8v engine except the tensioner was a little more fiddly.
Thanks MarkThompson4 thanked for this post
Hi!
Bushboy is offline
Closed Guide
Guide Tools
(T) Timing Belt Change colinurquhart Bravo 15 08-02-2014 07:56
(G) Cam Belt/Timing Belt Change Just to be Safe quaffle Punto (Mk2/2b) 12 31-03-2011 16:51
(T) Timing belt change Rustbucket Barchetta 2 19-02-2010 16:49
(G) Timing Belt, When to change? SPIRITO DE PANDA Panda (Classic) 8 25-10-2008 21:49
(T) How to change your Timing Belt Trancendental Tipo (Classic) 1 09-10-2006 21:09
