| | Guide Tools | Search this Guide |
Published by Deckchair5 29-06-2011 | ||||||
| | #1 |
Posts: 2,184 Thanks: 144 Trader Rating: 0 | Re: Fuel flap hinge repair Thanks Decks, great guide. Mine broke in a different way - one of the plastic tabs that holds the pins on the flap itself snapped off. Still repairable though. Took it to a body shop who glued the tab back on to the flap with some special epoxy. Good tip is to keep the hinge mechanism well lubricated to avoid breakage in the first place!
__________________ Phil Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form... |
| | Quote
| | #2 |
Posts: 5,589 Thanks: 689 Trader Rating: 0 | Re: Fuel flap hinge repair Hi Phil I knew it was a weak spot so I took especial care of it all the way through and often lubed the hinge and very carefully opened it each time but the hinge pin is plastic and so small that it's only a matter a time before they break. You can see the broken pin in the 2nd photo. I made it to 90,000miles so that's not so bad
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX |
| | Quote
| | #3 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | Re: Fuel flap hinge repair Thanks a million for this informative post. My fuel flap fell off exactly as you describe in your intro. (spooky no?) Followed your instructions to the letter, and viola!! good as new... thank you again.
| | Quote
| | #4 | ||
Posts: 9 Thanks: 1 Trader Rating: 0 | Re: Fuel flap hinge repair Thanks for this top tip, my wife just filled up with fuel and drove home without noticing it hanging off! Now fixed and lubricated.
| | Quote
| | #5 |
Posts: 106 Thanks: 6 Trader Rating: 0 | Re: Fuel flap hinge repair In mine the thing on the red circle broke. Four layers of 2 component epoxy glue and 24 hour later and it's good as new. But it needs A LOT of glue...
__________________ Stilo 1.6, 2001 , 3D, Jet Blue |
| | Quote
| | #6 | ||
Posts: 22 Thanks: 0 Trader Rating: 0 | Re: Fuel flap hinge repair Hi guys! in my case, I've purchased a similar fuel flap from Ebay and I want to replace it rather than just the hinge, trouble is I can't access the screws to remove the existing flap, I'm not quite sure what the Wheel liner is, Does it mean I have to remove the tire? thanks for your response in advance.
| | Quote
| Currently Active Users Viewing This Guide: 1 (0 members and 1 guests) | |
| Guide | Guide Starter | Category | Comments | Last Post |
| | Matt Boulton | Grande Punto | 7 | 23-08-2011 00:01 |
| | Oscar | Panda | 8 | 13-04-2009 08:18 |
| | DavePanda100 | Panda | 12 | 08-01-2008 12:54 |
| | tonyy | Stilo | 15 | 07-12-2007 13:35 |
| | carcazy | Stilo | 13 | 26-10-2006 17:48 |
