Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Retrofit Electric Leather Seats into a hatchback<!-- google_ad_section_end -->
Published by Searchy
04-02-2011
Unrated
User Rated:Unrated
Removal of old seats and interior - Part One
First of all please disconnect your car battery!
Take photos for later on!
Remove your old interior starting with the front seats;
There are four bolts holding the each seat to the chassis and they are located by two bolts at the front within the seat rail and two at the back, one located within the seat rail and the other at the rear side of the centre console, these bolts are six mm hex screw bolts that are all the same width and length.
Once these bolts are removed, tilt the seat up at the front and disconnect the three cables for the airbag etc this is the same for both of the seats.
Then remove the seats.
Contents
Old 09-02-2012   #1
Re: Retrofit Electric Leather Seats into a hatchback
is the wiring there on all the stilo models?
thanks
mikefewkes is offline Reply With Quote Quote
Old 12-02-2012   #2
Trader Rating: 1
If you mean the wiring for the heated/electric seats then no, you need to get them from a donor car that has those seats, plues the rear fuse box.
1.8 3dr Dynamic Azzurro Blue - 17" Claw's, Schu Bumper skirts and spoiler, Debadged Grill, CN+, Cruise Control, Full Leather Elec - Heated & Abarth Speedo - Sold!
BMW 7 Series MSport Avius Blue
Searchy is offline Reply With Quote Quote
Old 12-04-2012   #3
iv got some seats out of a car that was breaking iv got all the seats and will be going back tomoz to get the door cards and loom for the seats
as my stilo dont have the rear fuse box i will be getting it and as much of the loom as poss
as for the plugs for the seats wen i cut then out from the scrap car were do thay then wire in to ?
and were do i get the power for the seats ?
chrisboulton is offline Reply With Quote Quote
Old 24-04-2012   #4
fitted all my seats in to my car now and are working spot on only thing i need to no is how to get the heated seats wired up i have got 2 wires left over coming from the rear fuse box
WIRE 1 (LIGHT BLUE/YELLOW)
WIRE 2 (BLACK /GREEN )
WERE DO THESE GO ?
CAN ANY ONE HELP ME OUT WITH THESE ?
Old 25-04-2012   #5
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
Seat heater elements wire direct to the seat ECUs.
Black/Green wires are not shown on the electric seats wiring diagram.
The only Blue/Yellow wire on the diagram goes to the electric seat relay in the rear fuse box from relay T12 in the dashboard fuse box. It's the main power supply for the seats and seat heaters, so if your seats are working, you must already have that wire (or a substitute for it) connected.
Stilo Parts For Sale:
Connect Nav+ Map Discs - Wiper Motor (NEW) + Croma Turbo i.e. Badges.
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 07-11-2012   #6
Alipuntogirl has donated!
on the connector of the fuse box, which colour does the pink/white (from seat connector) connect to?
Alipuntogirl is offline Reply With Quote Quote
Old 20-02-2013   #7
Quote Originally Posted by Searchy View Post
Hello,
Just about to take on this project , i understand that the passengers side wiring attaches to the rear fuse box however where do i attatch the drivers side wiring to ? Do I attach it to the rear fuse box aswell ? or the front fuse box ?
and1941 is offline Reply With Quote Quote
Old 20-02-2013   #8
Trader Rating: 1
Hi and welcome to the FF! All heated/movement wires go to the rear fuse box, the only cables that need to attach to the front fuse box are as I stated the can bus pink/black thin wire this allows the seat to move.
Good Luck!
Old 20-02-2013   #9
Trader Rating: 1
Quote Originally Posted by Alipuntogirl View Post
If its a thin type looking speaker cable, then look in the front fuse box below the steering wheel and you'll see the same type of wire, splice it and join them up.
Old 20-02-2013   #10
Good Luck!
Hello , Thankyou for the rapid reply , still a bit confused. how am i supposed to connect the drivers sides cables to the rear fuse box ?
Old 20-02-2013   #11
Trader Rating: 1
Well I fed the wires along the door sill with all the other spaghetti cables then branched off just at the boot area and duct tapped them to the bare metal under the boot carpet snd fed into the fuse box I only did it like that as I cut my wires a little short when taking them from the donor car you live and learn!
Old 20-02-2013   #12
sorry as you can tell im a novice when it comes to this, I understand that the passenger side wires lead strait to the rear fuse box; sharing the same coloured wires, however the drivers sides wires do not lead to the rear fuse box and the wire colours are different to those on the passenger side. therefore how do i connect the drivers side wires to the rear fuse box. do I splice all the cables running to the passenger side seat and extend them to the drivers side (so in effect they run in series?) or am i missing something
Old 20-02-2013   #13
Trader Rating: 1
Tbh I can not remember the colours but yes they are different, they have to be to help you connect the correct wires in the correct place. I found just looking at the original connector under the drivers seat in the donor car helped me locate the those colour wires that are bunched up in the passenger side door wiring loom and cut them from there (yes the drivers side electric wires go through the dashboard and flow along the passenger side door sill loom)
Hope that helps.
Old 21-02-2013   #14
Hope that helps.
Okay thankyou, my fiat already has a rear fuse box however does not contain the wires needed for the electric seat. Is my best option removing the original fuse box and replacing it with the fuse boxe from the donar car ?
Comment
Search this Guide:
(S) Retrofit Leather, anybody done it ? Cledwen 500 7 15-09-2009 06:23
(G) Leather seats with child car seats -any damage? danger girl 500 10 04-07-2009 10:51
(T) elec heated leather seats retrofit grundleweed Stilo 4 30-06-2009 16:18
(T) Retrofit Leather steering wheel w/controls?? reinventingyourexit Stilo 15 19-05-2007 17:27
