| | Guide Tools | Search this Guide |
Posts: 6,081 Thanks: 280 Trader Rating: 7 | Re: How to replace upper glovebox hinge... Decided to help out a friend and change a broken hinge assembly on his Stilo cooler box(top glove box) for him. What a pain in the ass that was. Getting the old one out was hard but getting the new one back in was impossible. ![]() The 5 x T20 torx scews holding it in are unbelievably difficult to get to, due to the passenger side air bag being so close to the hinge assembly. After using 4 different flexible shaft screw drivers I eventually found one that was small enough to fit in and crack the screws loose. Finished removing them with my fingers. Took me 2 hours, 4 coffee's and a bacon sandwich to remove it. After a bit of jiggling around I got the new assembly into possition but stuggled for over an hour trying to get just 1 Torx screw back in. After studying it for a while I decided to replace the T20 Torx screws with similar Hex Key ones to enable me to use a set of Hex Keys instead of a Torx bit. The Hex Keys I have are the type with a ball shape on the end of the long leg of the key. This enabled me to use the Hex Key at an angle when screwing them in. Still the biggest pain in the arse job I've ever done but at least I did it.I've added a couple of pictures, hope someone finds this usefull. Not me, I'm not doing it again, ever.
| | Quote
| | Re: How to replace upper glovebox hinge... thanks for the pics.....now u feel my pain! i think were the only two to have done this...
| | Quote
| | #3 | ||
Posts: 6,081 Thanks: 280 Trader Rating: 7 | Re: How to replace upper glovebox hinge... Would you do it again?
| | Quote
| | #4 | ||
| | Re: How to replace upper glovebox hinge... not for all the tea in china.....
| | Quote
| | #5 | ||
| | Quote
| | #6 | ||
Posts: 8 Thanks: 1 Trader Rating: 0 | Re: How to replace upper glovebox hinge... shall be attempting this soon.got the hinge bit,just need a week to try and do it.Unless 1 of u lot wants to do it for me
| | Quote
| | #7 | ||
Posts: 6,081 Thanks: 280 Trader Rating: 7 | Re: How to replace upper glovebox hinge... That said if you happen to be near Wolverhampton this week end I'll do what I can to help you get it sorted. If you plan to go it alone mt advice is get a small but good quality flewable screwdirver that will accept a T20 torx bit, I found it quite usefull in reaching those screws.
| | Quote
| | #8 |
Posts: 379 Thanks: 12 Trader Rating: 0 | Re: How to replace upper glovebox hinge... attempted to take this dreaded challenge the last screw all the way on the right (possibly left for you right hand drivers) was rediculous to get off took me all afternoon and then another attempt till midnight. im def gonna look to find replacement screws with allen head instead. the difficulty for me now is to fix this. apparently everything is fine except the two black springs are broken. will attempt to make my own my taking steel wire of the same diameter. my other question is that i see in some photos other than the two black springs there is a silver one on the side. anyone have any clear pictures of this? i dunno if this was added later on but i cannot see this on mine. i can see that it is connected to one of the hinge pieces that sticks out like a lever but i see no attachment for the other end.
__________________ 1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr |
| | Quote
| | #9 |
Posts: 2,681 Thanks: 117 Trader Rating: 1 | Re: How to replace upper glovebox hinge... Well, here are some pictures, and a walkthrough of my challenge. For starters, a picture of some nice tools: ![]() Loads of small screws to remove outer cover: ![]() Two torx screws to remove inner lining: ![]() To gain extra acces, this is optional - just to gain extra access when refitting. Here's the summer coke cooler: ![]() Pull out inner lining and vent: ![]() A picture of the vent again: ![]() Praise out the airbag switch: ![]() Remove screw: ![]() Open lower glove box and unscrew two torx screws: ![]() Take out the plastic, just the way you open that particular door (like here, to the right): ![]() To remove the right (or left in the UK) vent, unscrew two screws underneath and one screw to the right: ![]() Pull the vent straight out: ![]() I have no idea how you do this without "Tack-it": ![]() To get to the worst screw: ![]() Completely removed: ![]() Job is worse when you have stuffed the rear of the compartment with other gadgets, as a line converter and a handsfree kit module: ![]() The cracked hinge: ![]() Same part numbers (on both hinge parts), but they aren't identical: ![]() Notice the differences in the springs:
__________________ jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts. member of the 5-door massive attack. |
| | Quote
| | #10 | ||
Posts: 15 Thanks: 0 Trader Rating: 0 | Re: How to replace upper glovebox hinge... WOW. thats all i can say... will be doing this in the next few days as i have had the new hinges on the back seat for about 2 weeks now. i did locate the screws when i brought the hinge but didnt even attempt to get them out (i did really, for about 5hours with no luck!) ![]() wish me luck guys
| | Quote
| | #11 | ||
| | Re: How to replace upper glovebox hinge... good luck! let us know when u succeed!
| | Quote
| | #12 | ||
Posts: 41 Thanks: 1 Trader Rating: 0 | Re: How to replace upper glovebox hinge... I need to get mine replaced, I'm pretty sure I broke it because the panel was not fitted correctly in the first place, and the irritating rubbing noise between panel and dash got right up my exhaust pipe, and smacked it senselessly in a rage after a crap day in work. There's one on flea bay atm going for £80 off an old Abarth (same car I got my CC stalk from) but to me It's a little steep in price, so am going to wait for however long it takes for one to come on at a reasonable price!
| | Quote
| | #13 | ||
Posts: 168 Thanks: 14 Trader Rating: 0 | Re: How to replace upper glovebox hinge... I need to replace mine as well... Can't find a hinge anywhere though. Anybody know what part no the hinge is? (for uk) Cheers
| | Quote
| Currently Active Users Viewing This Guide: 1 (0 members and 1 guests) | |
| Guide | Guide Starter | Category | Comments | Last Post |
| | mzhussein | Stilo | 55 | 09-11-2010 21:43 |
| broken stilo upper glove box hinge | bigmrbaker | Newbie Central | 1 | 03-07-2009 20:25 |
| | wizardflake | Stilo | 2 | 21-08-2008 14:44 |
| | Bertonex19 | X1/9 | 2 | 28-09-2006 07:32 |
| | Jojo42 | Stilo | 5 | 24-05-2006 19:56 |
