FIAT Auto Specialist Team
Comment
Guide Tools
<!-- google_ad_section_start -->How to change the 1.6 Timing belt<!-- google_ad_section_end -->
Stilo 1.6 Timing belt change
Published by roy lovelock
22-08-2009
Unrated
User Rated:Unrated
Precautions and tools needed
Hello, some of you know me - I've been on and off the forums for some years now, I've owned my 1.6 active from new on an 03 plate and recently bought the wife a 1.6 dynamic MW on a 53 plate. Anyway my car had hit the belt change time and Fiat had quoted me an estimate of 750 per car to do this job, i figured that it would and is more cost effective to do the job myself.
This is a rough guide to how i changed the belt on my car, I will include any information I can remember or feel is important, but i wont take any sort of responsibility for people who damage their engines etc. this is a rough guide done my an owner, I'm not in the motor trade so some practices maybe wrong in a true mechanics eye - but I've done it and my car is back on the road.
CONTINUE AT YOUR OWN RISK
OK so your still here
First of all.....
If your not mechanically minded DON'T even attempt to do this job. Its not for the every day diy mechanic - you will need to know how the engines work (even I had some issues but i will go into them later).
The main thing with this is to check check and check again. The last thing you will want to do is put a valve though a piston.
Tools Needed.
Special first...
  • Correct Cam Locking tool (essential) - cost me 150 (made by Sealey)
  • Crank Locking tool - 20 - this is also made by Sealey, but the one they recommend wouldn't fit until I took an angle grinder to it. - this job would have been impossible without this tool
  • 36mm socket to remove crank bolt.
  • 22mm DEEP socket - this is to remove the fixed tensioner.
  • Axel stands + jack.
  • Good quality tool kit - socket set with normal size will be fine - some kits come without 15mm I've noticed and this is one size that is used often with the Stilo so get one.
  • Alum key set / or alum socket (unsure of the sizes).
  • Tippex
  • A long thin gardening stick (you will see later).
  • Lots of patience and plasters.
You will also obviously need a cam belt KIT - don't bother just changing the belt - Murphys law will state that what will go wrong.....
Also new aux belt and compressor belt (if applicable to your car).
You may also want to change the water pump, on the 1.6 its actually on the aux belt not on the cam belt - i didn't on mine (only because i forgot to get sealer) but i have purchased one and it was only 22 from Euro car parts.
I don't want to insult anyone's intelligence so I wont go into removing wheels and jacking, and tbh if you need a guide to do those then you really shouldn't be attempting this job.
Thanks gearfinger, 411 guy, Jevge, Morty Mort thanked for this post
Likes gearfinger liked this post
Contents
<< <    Next Page: Strip Down (Page 1 of 9)    >  >>
Old 22-08-2009   #1
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: How to change the 1.6 Timing belt
Nice guide Roy I always called you Mr. hands on..
PNL is offline Reply With Quote Quote
Old 23-08-2009   #2
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
This was a great guide. Next time, I will do it myself. Have changed on the Uno and Ritmo Abarth (twin cam) but it was propably much easier with straight forward engines and belt layout.
Thanks mate.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 18-08-2017   #3
Hi all Ive got a quick question. I am struggling to see how to fit the tensioner in the 100% perfect position. Do I simply fit it loose then the belt. Then use a screwdriver on the little arrow marker to make it line up with the circle in the tensioner housing and then tighten the nut ? It seems a bit vague as to how the tension actually is set correctly as the body and bracket of the tensioner move in and out along the mounting as well as the tensioner arrow. Basically I am not sure which point along the access the actual tensioner bracket should be.
only6greens is offline Reply With Quote Quote
Comment
Guide Tools
(G) Timing belt change Paul-C Punto (Mk2/2b) 2 31-01-2008 22:23
(T) When to change the timing belt? $tephenGiles Punto (Mk2/2b) 18 13-12-2006 18:55
(T) How to change your Timing Belt Trancendental Tipo (Classic) 1 09-10-2006 21:09
(G) how to change a timing belt.. christopher watson Panda (Classic) 10 02-01-2006 21:29
(T) Timing Belt - when to change ? Dodge Punto (Mk2/2b) 4 02-01-2006 20:49
