Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->FIAT STILO 1.9 JTD (all) Changing Gearbox Mount<!-- google_ad_section_end -->
Fixing the Nasty JTD Rattle Problem
Published by radoslavp
20-06-2009
Unrated
User Rated:Unrated
Problem Introduction and Little Story
As many of you have noticed all Stilos manufactured until year 2003 come with something we can call "manufacturer flaw" when talking about the gearbox mount. It is no accident that there's a sticky thread in the Stilo section, where many described the problem as it is.
I'll use this guide to try to describe the problem in detail, to point where it comes from, and eventually to learn you all how to fix it with your bare hands and some tools.
As far as I know all FIAT Stilo diesel and probably all petrol cars manufactured between year 2001 and 2003 come with the problematic gearbox mount with ePER number 46781889. After 2003 FIAT acknowledges the problem and starts making another replacement gearbox mount with ePER number 51711216. All old gearbox mounts should be pulled out from the market, but you should be very careful when buying yours, it's strongly recommended to use the replacement mount as all design flaws with the old mount have been fixed.
The problem with the original gearbox mount lies in the rubber it is made from, as it has the tendency to harden very quickly during the years. My car was manufactured 29.03.2002 and after 7 years the mount was long long gone. Once hard enough it transfers the vibrations from the engine and gearbox to the whole chassis of the car.
Typical symptoms that your car uses the "defective" gearbox mount and needs replacement:
- strong vibrations on the steering wheel (you can feel them at all times when the car is running)
- vibrations on the front hood (clearly visible)
- vibrations on the gear change stick
- vibrations all over the car's chassis
- even your pedals can vibrate
- last but not least the noise and nasty metalic rattle described by many in the sticky Stilo rattle thread
If you have all the above symptoms, but you still think your gearbox mount does not need changing, here's another symptop I personally found. Try turning on your climatic. Once turned it will transfer the load to the main engine mount and almost all the vibrations in the coupe and on the steering wheel will be gone. Turn off the climatic and all vibrations are back.
Thanks ESTpower, Steve148, Manxrobin, Jevge, emzo and 2 others thanked for this post
Likes ESTpower liked this post
Contents
<< <    Next Page: Tools Needed and Fixing the Problem (Page 1 of 6)    >  >>
Old 08-03-2012   #1
Macedonia
Re: FIAT STILO 1.9 JTD (all) Changing Gearbox Mount
Thank you for your help i have annoying vibration when the car is idle and while changing gears i hear strange sound (krak krak krak).
I will give a try with climate. I will identify if i should change other mounts have a good day.
Noli is offline Reply With Quote Quote
Old 11-03-2012   #2
Germany
Thanks so much !!!
Just got my gearbox mount changed, I needed in total 2h30 after some difficulties with the rear screw of the mount, access is really hard, only solution I found was to lower the engine 4-5cm and only then I managed to place correctly the spanner.
The before-after effect is just truly incredible !
The car feels 5 years younger, no more rattling noise in the engine beam, soooo good
Thanks again for the guide and the pics !
ESTpower is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Stilo 1.9 Jtd Gearbox Oil Grade ? DeanF Stilo 18 31-05-2011 15:13
(T) Changing Stilo JTD Fuel filter robertk2003 Stilo 6 30-05-2007 21:43
(G) Could you fit a Stilo JTd Sporting Clutch and/or gearbox to a Mk2? Randomman Punto (Mk2/2b) 8 22-01-2007 13:27
(G) Any Chance of fitting a Stilo Sporting JTD Gearbox to a Mk2 Punto? Randomman Punto (Mk2/2b) 1 20-01-2007 12:54
