The FIAT Forum
Go Back   The FIAT Forum > Guides > Stilo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Changing Headlight Bulbs<!-- google_ad_section_end -->
On a 2004 3 door Stilo...
Published by MF-Racing
05-10-2007
This guide shows you the best way to change the headlight bulbs on a 3 door Stilo. This involves removing the front bumper and the light clusters from the car. Changing the bulbs with the clusters in the car is almost impossible!
1. Removing the front wheel arch liner
This is secured with three screws. Two on the edge and one at the back near the brake hose mounts. Undo these and pull the liner out of the way (might help to point the wheels into the car to help with access)
2. Removing the bumper
You now need to remove the 4 torx bolts on top on the bumper, next to the grill.
Next, look into the wing where the arch liner was, you need to remove two bolts that secure the bumper to the wing. One 10mm bolt and one torx bolt. These can be quite tricky to remove and see. Get a torch to help to see what you are doing.
Finally, remove the under tray if fitted from under the car, and then remove the 4 torx bolts that secure the bottom of the bumper.
The bumper should now lift off the car!
3. Remove the bumper mounts
Look under the head lights, and you should see a piece of black plastic that the bumper rests on. Remove this by unscrewing the two 8mm bolts.
4. Remove the headlights
You can now remove the headlights by unscrewing the nuts (one on the bottom left and one of the bottom right) and the screw (top right) and disconnect the wiring from the back of the light (do this by pushing the gray locking ring sideways and pull backwards to remove the plug). You can now remove the headlights from the car!
5. Change the bulbs
Change the bulbs in the headlight on a nice flat surface making sure that you don’t touch any the glass part of the new bulbs.
6. Refit the headlight
Refit the headlight back into the car and connect back up the wiring. Make sure that all the new bulbs work before fitting the mounts/bumper again!
8. Refit the mounts/bumper and liners
Refit everything in the same order that it came off. The only tricky part is getting the inner wing bumper screws in place.
7. Have a beer!
Have a cold beer and feel pleased that your hands and arm aren’t cut to shreds from trying to fit new bulbs with the lights still in the car!
Matt
Article Tools
The following 2 users say "Thank You!" to MF-Racing for this useful post:
coyle (01-05-2008), kcalvert (10-03-2008)
Old 05-10-2007
doM repuS
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: Changing Headlight Bulbs
Why is this the best way? Some of us managed it with all the parts in situ
Good guide anyway
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 05-10-2007
MF-Racing's Avatar
Trader Rating: (0)
Good guide anyway
Pah! I bet you can’t change the passage side sidelights and fogs without removing anything from the car apart from the bulbs!
2004 1.6 Active Sport Stilo
Mods: Angel Remap, GSR Induction Kit, 35mm Pi Springs, Goodyear F1 GSD3 Tyres, Mintex Disks & Pads, Blue Calipers, Retro Fit Aero Wipers, +80/30% Headlight Bulbs, Blackout Blinds, Kenwood Double DIN DVD/Radio/Ipod Monitor, Badgeless Front Grill, De-Badged, & Ambi Pur Air Freshner!
http://www.mf-racing.co.uk/carsig.jpg
MF-Racing is offline
Old 05-10-2007
doM repuS
Stu DemonD's Avatar
Trader Rating: (1)
Luckily I will never find out
Old 14-10-2007
yellowperil's Avatar
Trader Rating: (0)
just done both my head lights only thing i had to remove from the car was the battery cover, oh and tilt the washer bottle back off its top mount. taking the bumper off is a bit excessive but what ever suits you is ok.
yellowperil is offline
Old 18-10-2007
Its all about torque!!
jackoneil3's Avatar
Trader Rating: (0)
jackoneil3 has donated! United Kingdom
I totally agree Matt had to change bulbs reasonable frequently and the size of my mits and arms if i didnt remove the front bumper i'd have to take the engine out! and dont need that!!
Driving a 1.9JTD Remap'd Stilo! Unknown BHP! Custom built BMC CDA induction kit, straight thru exhaust system, FMIC system. Lowered 50mm! Kyros front bumper so far!! Smoothed booty. Evo vent & Audi R8 style fogs!
jackoneil3 is offline
Old 22-10-2007
Stilatos's Avatar
Trader Rating: (0)
Greece
To be honest i didnt have to go that far for my car which is a left hand drive i only had problems with the left side of the car because of the battery and couldnt fit my hand trough to change the head bulb. TO change that i just proceeded to the step which involves removing the wheel plastic arch lining and reached my hand all the way up and very carefully not to touch the bulb with my fingers.
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
Old 08-11-2007
Trader Rating: (0)
Is it just me that feels the designer of this element of a Stilo need garrotting?? Think of all the parts of a car that need regular maintenance and make them accessible, easy really. What a palaver for a bulb!!!
Meady is offline
Old 15-11-2007
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
I found it much easier to remove the battery tray than do this. Ended up fuc*ing up the hella coil in the wing when I took the bumper off, never again .
Plus it gave me chance to respray some rusty brackets in the engine bay and tidy up FIAT's patchwork-quilt style wiring!
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 24-12-2007
The Phoenix has landed!
coyotes_uk's Avatar
Trader Rating: (0)
coyotes_uk has donated! United Kingdom
I know its not strictly appropriate but I had to change my driver side stop lamp last weekend and it was relatively easy!
remove the little container stuff under the boot light and then ease down the lining, un-screw the bolts, and out pops the whole cluster!
Easier than I thought!
Go Phoenix Go!
Light Blue 3DR 1.6 Stilo Active - Francesca
- Now with Giugiaro designed Vredestein Ultrac's!
- Now with new Xenon's
- 17" Stone Grey CLAWS
coyotes_uk is offline
Old 09-01-2008
Ged20D's Avatar
Trader Rating: (0)
I can see me looking forward to this on Saturday!
Ged20D is offline
Old 26-03-2008
Trader Rating: (0)
I had a bulb go on my Stilo recently. Its the 2nd time if had it happen, and both times its been my near side bulb, tucked in behind the battery! 1st time it went, I was booked in for a service the next week, so it was taken care of there.
However, 2nd time round, I thought I would take care of it my self. I popped the bonnet, and had a look. Put the bonnet down and retired inside for a stiff drink!
I suddenly had a relivation! It was dark at the time, so I called up the AA and gave them a story about how I wasnt car minded, and my bulb had gone as I turned my headlights on. I was just about to start a 60 mile journey and didnt want to be braking the law. Please please help me.
20 mins later, Gavin from the AA was with me, confidant that this would be sorted in a few minutes, after all, he only had to change a bulb right. Half and hour later, and quite a bit of swearing, it was done. He had to take the battery out, and remove the plastic casing from around it, giving him ample space to replace the bulb. But my bulb was replaced, and I didnt even break a sweat, let alone remove the bumper.
jaymorgan25 is offline
Old 26-03-2008
ow! pinched my eyeball!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
not quite
removed so the flufftards can dry their eyes
Want +20BHP for £2?
do not click this link!!!!
custard is offline
Old 04-04-2008
StevenkSengwayo's Avatar
Trader Rating: (0)
No need to remove the bumper. Mine was done in minutes @ Nationwide when I had my exhaust fited but halfords say you have too why I dont know. good guide either way
StevenkSengwayo is offline
Old 13-04-2008
Trader Rating: (0)
Anybody out there changed the dipped headlights (H7) for HIDSs? As I have just received my kit and to say the instructions are crap would be an understatement. Also will be replacing the front indicators and rear lights with leds. Tried the rear ones during the week but the bulb blown warning system went into overdrive,. Got some resistors with the indicator bulbs but don't know which wires to attach them to and I'd hate to have to pay a sparky to come out and do the job. So anybody know the answer?
Stilo
Kirbs is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Headlight bulbs stu14 Stilo 2 17-03-2007 07:43
Headlight bulb's R2/P45t Alan.D Panda (Classic) 67 06-03-2007 16:28
Changing bulbs - IMPOSSIBLE! fiatstilo3doororiongrey Stilo 1 10-11-2006 21:03
headlight protectors, silver bulbs, and security marked parts :thumb: christopher watson Panda (Classic) 6 12-11-2005 21:39
Changing headlight bulbs STILO8569 Stilo > Technical 8 31-08-2004 20:18
