The FIAT Forum
Go Back   The FIAT Forum > Guides > Stilo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Removing heater control panel (light bulb changes etc)<!-- google_ad_section_end -->
Published by Deckchair5
20-09-2007
Firstly remove the radio. To do this you need 4 rods like this to push in the 4 holes in the radio front to release the catches. These rods are 125mm long. 4 long nails will do the job just as well. You want a diameter that just fits in the holes
Name:	radio rods 2.JPG
They only need to go in around 50mm to release the catches. You may still need to do some careful leverage on either side of the radio to get it moving. You can put the radio to one side or probably better to detach the connectors and remove it completely but make sure you have the radio code first if you do
Name:	radio connectors 2.JPG
Now you have a bank of screws and you can see which ones you want to remove to release the lower panel.
Name:	radio tray 2.JPG
Now remove the lower ashtray and you'll find a couple of screws down there too. Detach the ashtray lighting wire
Then you're ready to release the heater control panel which has a couple of push in locking tabs. The connectors to the panel can then be released
Article Tools
Old 30-11-2007
Trader Rating: (0)
Re: Changing heater panel light bulbs
Does this apply to an air con version and if you fit a new panel will the change just be accepted by the cars system or would it need to go on the computer at the dealer to reset it?
nomad63 is offline
Old 06-12-2007
Trader Rating: (0)
Hi thanks for the help here but i'm still a little stuck.
got most of this done but I can't get the unit out at the end, it looks like all the white plastic bits that are attached are stuck behind the housing and it won't come out, do I have to click something, twist, lift, etc...?
please help, i've tried everything..and its doing my head in.
I had to put it all back together again.
thanks...dean
EX-Stilo Abarth, Jet Blue, Tan Leather trim, 17" Alloys, Multi changer.
Now Stilo 1.9 JTD 3dr - gotta love that MPG..
djewson is offline
Old 22-05-2008
Stilo JTD Sporting
James89's Avatar
Trader Rating: (0)
James89 has donated! United Kingdom
what bulbs does the heater panel take?
i need to replace mine...
i also have Air Con too if that makes a difference?
James89 is offline
Old 20-07-2008
Trader Rating: (0)
Thanks for this - might be worth adding that I tried forever to get the white unit out before realising it was not necessary - I just removed the three knobs and unscrewed the light distributor from the front, replaced the bulbs and put back in place.
Thanks for the guide
mylovehatestilostory is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
lol Donz Leisure Lounge 76 17-09-2007 12:37
Changing bulbs - IMPOSSIBLE! fiatstilo3doororiongrey Stilo 1 10-11-2006 21:03
Light bulbs andyotoole Ulysse 7 04-10-2005 20:19
Brava Interior Dome Light Bulbs Croesis Bravo/a > Technical 3 19-06-2004 04:45
Changing Interior Light? jdunderhill Punto > Styling 3 07-11-2003 03:28
