The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > Guides > Stilo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Removing a front strut<!-- google_ad_section_end -->
Published by Deckchair5
17-04-2007
HOW TO REMOVE A STILO FRONT STRUT
This is on a 1.6 engine Stilo - models may vary
Ring a round and find a garage who will change the springs for you. Don't attempt to change springs on your own. A spring in the face is very likely and some of you are ugly enough already.
Bear in mind the reason why many people are changing springs is because they tend to fracture under stress remember? Point taken?
First of all check your tracking and make some notes as although your steering shouldn’t be altered at all or by much, you are moving some chunky suspension bits around and a mm here and a mm there may add up by the time it gets down to your wheels.
But you haven’t got laser tracking facilities I hear you say.
Can you see the sea horizon? Can you see the moon at night? Then you don’t need a laser to do tracking checks. Have a look in “How to check your tracking" and after learning how to do that you may not be visiting the tyre shops quite so much
REMOVING THE STRUT
Name:	spring change 1.JPG
Name:	spring change 2.JPG
OK so do the usual, jack it up, wheel off and axle stand stuff. You can see where I put the jack and axle stand here.
Name:	spring change 3.JPG
ABS CONNECTOR
Pull up the clip and disconnect the wheel ABS connector. Then pull out the brake hydraulic hose, ABS wire and brake pad wear wires from the strut
Name:	spring change 4.JPG
Name:	spring change 6.JPG
ANTI ROLL BAR LINK
Just get hold of the back of the ball joint with a mole wrench over the protective boot and undo the nut with a 16mm socket. The protective boot on the drop link is very tough so you can use a mole wrench on it to grab the shoulder of the ball joint underneath without problems. You can put on new links using this method too without problems of damaging the boot. Move the link out of the way, no need to disconnect the bottom one
Name:	spring change 7.JPG
STRUT BOTTOM BOLTS
Name:	spring change 8.JPG
These are not as tight as you might think they are gong to be but a long bar makes easy work of them. Don’t remove the nuts entirely yet, only run the nuts up to the end as you’ll need to use a hammer to knock the bolts through and don’t want to damage the thread. BUT BEFORE YOU DO. Move the ABS and brake pad wear wires out of the way. Don’t want to smack them with the hammer
Name:	spring change 9.JPG
OK just knock the bolts through a bit to get them moving as they’ll have a bit of rust holding them.
TOPSIDE NOW
Name:	spring change 10.JPG
Put some oil on and get to undoing the very top nut but don’t take it off completely just yet, you’re just loosening it ready, so take it up until it’s just finger tight and then leave it ready. You may need to use a torx or allen key in the screw centre to stop the shocker spindle turning while you unscrew the nut..
BACK TO THE BOTTOM STRUT BOLTS
Name:	spring change 11.JPG
Ok you can take off the nuts and turn and knock out the bottom bolts now. Then you can lever the hub out towards you
Name:	spring change 13.JPG
Now the strut is just hanging by the top nut and cover, so, supporting the strut with one hand underneath just undo the top nut. Take off the cover and now your strut is ready to remove from the car. It’s not very heavy.
WARNING DON'T even attempt to undo the nut shown down in here under the top cap. This is the strut spring retaining nut and is holding your strut spring on. Click image for larger version
Name:	spring change 12.JPG
CHANGING THE SPRING
Don’t try changing the spring yourself. A garage or tyre shop will do it for you for next to nothing in just a few minutes in complete safety. The Stilo spring is very strong and goes all over the place when compressing so have a garage do it. Bear in mind why you’re changing the spring, because it tends to snap and if it’s going to snap it’ll do it in full tension just where you’re face is so don’t mess with it. It’s quick, cheap, safe and effortless in a garage.
POINTS TO NOTE - VERY IMPORTANT
Name:	spring change 12a.JPG
When your garage man reassembles the strut with the new spring for you, make sure they have lined up the top cap and bearing surface like this with the point on the cap and the hollow on the top plastic bearing surface all in line with the bottom bolt mounting brackets. If not then they’ll have to do it again as it determines the angle of the top mount in relation to the bottom strut
REINSTALLING THE STRUT
When you reinstall the strut, wait until the car is back on the ground again before finally tightening the top mount nut
Now check your tracking is still ok as before
Article Tools
The following 4 users say "Thank You!" to Deckchair5 for this useful post:
Greggers (03-10-2008), ivan73 (05-07-2009), Jevge (16-11-2009), ninjaben (23-09-2008)
Old 03-02-2008   #1
27col has donated!
Re: Removing a front strut
Nice to see such a good quality set of photographs.
27col is offline
Old 06-04-2008   #2
I'm with MR Ford
ROWENA's Avatar
ROWENA has donated!
JUST CHANGED MY O/S SPRING YOUR STEP BY STEP WAS GREAT!! SPRINGS AREN'T THAT DIFFICULT TO CHANGE YOU NEED GOOD SPRING COMPRESSORS THOUGH THE STILO SPRINGS ARE MASSIVE THANX AGAIN FOR THE STRIP INFO
ROWENA.
ROWENA is offline
Old 03-05-2008   #3
Today I replaced off side front spring on my multiwagon jtd, first time I have changed a coil spring so took all morning using a draper double prong compressor tool and wearing my bike helemt just in case of any rapid firing springs, still job done car back on the road and keeping an extra eye open for them pot holes that caused it to snap at 10mph..
many thanks for this handy guide
mhowse
mhowse is offline
Old 03-08-2008   #4
RadioForsh
forsh has donated!
Finland
i wish i seen this guide before trying to change my snapped spring
oh well now i can return to the car and try again
after bashing the front abs cable i think i could of fraid the cable a bit
couldnt work out how to take that anti roll bar nut and bot off,it just span and span round and round
taking a susspension off with the roll bar still attacked is nasty and hard work
managed to get the springs on and off no problem
after this i am going to my nearest dealership and trading my stilo in for a different car
maybe a bmw compact or a honda crv.hrv type thing
love my stilo,but i hate fixing it when i have problems
so hard to get round places in there
forsh is offline
Old 23-09-2008   #5
Thanx for the brilliant guide. Took awhile to get fronts off, had to drill out one of the bolts. The backs came off in 15 mins. Only prob left is car is pullig to left. Had tracking checked but said it was OK. Goin to get computer tracking done later.
Cheers matey
ninjaben is offline
Old 03-07-2009   #6
Thanks Deckchair,
I have just refitted the new spring. I do agree that it would be best to arrange to remove the spring at a garage. It would save stress that is caused when you can see the spring bending out of shape and the spring compressors slipping round the spring.
The spring compressors are only on their second spring (first one on a Punto) but I can't risk using them again as threads are damaged.
Also I would have finished the job yesterday in the sun and not be finishing it today in driving rain!
Also despite (or maybe because of) having had a new spring fitted three years ago at the FIAT deaalers, the bottom nut and bolts were rusted solid. I had to split the nut to remove it.
I repeat Deckchairs' advice: TAKE THE STRUT TO A GARAGE!
Nig1 is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(G) Is the front strut from a JTD the same as a TD ? TDF Bravo / Brava 4 13-09-2006 21:40
(T) Removing Front bonnet badge dr_hillmann Cinquecento / Seicento 1 13-09-2006 16:52
(S) Removing Front bumper paint. Louie Bee Uno 2 01-07-2005 08:22
(G) Fiat Uno Front Strut Brace - Competition Spec SuperUno Uno 0 27-08-2004 21:15
Copyright ©2002 - 2010 FIAT Forum
