Rolling roads figures, fact or fiction?
Towcester, Northants
I came across this well written article over on the Renault Turbo Owners Club site and thought it would make some good reading to folks on here.
MEASURING ENGINE POWER
There is in fact no way of directly measuring power - all types of dynamometer measure torque and then power is calculated from the formula we saw in the previous articles - BHP = Torque (ft/lbs) x rpm/5252. This basic equation is the cornerstone of all engine design and development work. Two main methods of measuring power are used in the automotive industry - (1) measurement at the crankshaft of the engine or (2) measurement at the driving wheels. We'll look at both of these separately.
ENGINE DYNAMOMETERS
If we want to know the power of the engine alone then an engine dynamometer (or dyno) is used. This is how nearly all manufacturers rate the output of car engines. The engine is bolted into a cradle and connected to the dyno with a prop shaft which bolts onto the back of the crankshaft (or the flywheel). The power figures measured in this way are therefore usually called "flywheel power". The dyno is essentially a "brake" which can apply a known torque (or "load") to the engine. When the engine is holding a steady speed under a given dyno load then the torque being applied by the dyno must be exactly equal to the torque being produced by the engine. If this were not so then the engine would either accelerate or decelerate. Let's say we want to know the engine torque at full throttle at 3,000 rpm. The throttle is gradually opened and at the same time the load applied by the dyno is increased - eventually by juggling the amount of load applied we get to the situation where the throttle is fully open and the rpm is steady at 3,000. The torque being applied is written down and then the operation would be repeated at say 4,000 rpm. Soon we get a complete chart of torque at all engine speeds. Of course we could also measure part throttle power if desired.
Modern dynos are computer controlled and can generate power and torque curves very rapidly without the operator having to manually adjust throttle and load controls. They can be programmed to measure every so many rpm, say in 250 or 500 rpm steps - or they can measure a continuous torque curve while the engine accelerates at a preset rate. This can be used to simulate how the engine would actually operate in a particular gear when installed in the car.
There are various ways in which the dyno load can be applied. Older dynos use a hydraulic system with a rotor inside a water filled cavity - rather similar to the torque convertor in an automatic gearbox. Modern dynos generate the load with large electric motors. Even a simple friction disk or drum brake will work fine and this is where the name "brake" in Brake Horsepower came from. The important thing is that the load is able to be measured accurately and that there are no frictional losses in the system that escape measurement.
In order for dyno results to be comparable and universally understood there are a number of things that need to be closely controlled during the measurement process:
Operating Conditions
Air temperature, pressure and humidity affect the amount of power an engine produces. Cold dense air means a greater mass of oxygen per power cycle and thus more power is generated (provided of course that air/fuel mixture is properly calibrated for the conditions prevailing). There are formulae that can be used to calculate how much the measured power would change if the test conditions were different. This enables dyno results to be "corrected" back to standard conditions to enable comparison with anyone else's test results. Sadly however there is no one universally accepted set of "standard" conditions because different automotive bodies in different countries use different standards to calibrate to. "SAE" power standards are used in the USA and sometimes in England. "DIN" standards are used on the continent and there are a few other oddball systems just to confuse the issue. So just because your car is rated at 100 bhp and a friends at 110 bhp doesn't necessarily mean that his engine is more powerful - it depends whether both measurements were corrected to the same standard conditions.
One of the tricks I've seen used to get bigger "corrected" bhp numbers is to use a very high ambient temperature reading for the dyno test. If the operator measures the temperature close to the engine rather than well away from it then obviously he will get a reading that is much higher than ambient. When the bhp numbers are corrected back to a lower standard ambient temperature they will increase. I saw an engine dyno sheet the other day where the ambient air temperature in February, in England was supposedly 37 degrees C. Now either that test was done with the temperature probe sat right on top of the engine or it's a part of country I don't yet know about where I would very much like to live !!
Engine Ancillaries
When installed in the car, the engine has to drive a number of items like the alternator and power steering pump which sap power. Also the exhaust and air filter systems will reduce power to some extent. If the engine is tested without any of these ancillaries fitted then it will show much higher power figures. The Americans used to rate their engines like this back in the fifties and sixties and often the installed power of the engine would only be 2/3 of the claimed figure in the sales blurb. This used to be called "gross" flywheel power and if the ancillaries were fitted the power was called "net" flywheel power. Nowadays the gross system, which was very misleading, is not used and all modern published data should be "net flywheel" power. Major manufacturers abide by rigorous standards which set out how the engine should be installed on the dyno to simulate closely the "in car" conditions.
ROLLING ROAD DYNAMOMETERS
Also called chassis dynamometers, these are used to measure power at the driving wheels. This avoids the inconvenience of having to remove the engine to test it if a tuning modification has been made. However, it means that the power figures obtained will be lower than the flywheel power because of the frictional losses in the drivetrain and tyres. This leads to one of the biggest sources of confusion, error and plain misinformation in the tuning industry. You see, as discussed above, all major manufacturers quote flywheel power so it is understandable that people want to know if the hard earned cash they spent on tuning mods increased the power of their engine and by how much. To know this for certain means knowing how much the transmission losses are. There is enormous pressure on rolling road operators to be able to quote flywheel bhp rather than wheel bhp and most operators now run proprietary software systems which "supposedly" print out flywheel power.
PROBLEM !! - THESE SOFTWARE SYSTEMS DO NOT AND CANNOT WORK !!
Yes - I know - the whole chassis dyno tuning industry quotes flywheel figures and here's me saying none of it works. So I'd better explain some more and then you can make your own mind up.
First, let's look at how a chassis dyno works. The car is driven onto a rig so that the driving tyres are resting between two steel rollers. The torque is measured at different speeds in exactly the same way as an engine dyno works except that it is torque at the rollers rather than torque at the flywheel. The braking load is applied to one of the rollers by either a hydraulic (water brake) or electrical system again in just the same way as the engine dyno would apply a torque to the crankshaft of the engine. The same universal equation at the top of the page can then be used to calculate bhp at the rollers by knowing the torque and the rpm of the rollers (NOT the rpm of the engine at this stage) - but if the engine rpm is measured simultaneously then we can know roller bhp at a particular engine rpm. The BIG problem with all this is if any tyre slip is taking place. Remember these are smooth steel rollers which over time get quite polished. How much grip do you think you would get if roads were made of polished steel rather than tarmac? The effects of tyre slip are complex (i.e. I don't pretend to fully understand them myself!) but what I do know is that you can get some really strange bhp figures from highly tuned engines on narrow tyres and the readings are invariably too high not too low.
What is a transmission loss ? Well all mechanical systems suffer from friction and a proportion of the power fed into a system will get dissipated by friction and turn into heat and noise. Note the key phrase there - "power fed into a system". For there to be a loss there must be an input - simple and obvious yes but we'll see the relevance in a minute. When your car is parked overnight with the engine switched off, the transmission losses are obviously zero. When the car is running then some proportion of the flywheel power will be lost in the gearbox, final drive, drive shaft bearings, wheel bearings and tyres. For a given mechanical system these losses will usually stay close to a particular fixed %, let's say 10% for arguments sake, of the input power. So if the car is cruising and developing 20 bhp then 2 bhp will get absorbed as friction - under full power, say 100 bhp, then maybe 10 bhp will get absorbed. Now it is true that not every component in a transmission system absorbs a fixed % of the input power. Some components like oil seals and non driven meshed gears (as in a normal car multi speed gearbox) have frictional losses which are not affected by the input torque. These losses do increase with speed of course but at a given rpm can be taken to remain constant even if the engine is tuned to give more power. We'll look at real world transmission loss percentages later. Finally, the biggest source of loss in the entire transmission system of a car is in the tyres - they account for half or more of the total losses between the flywheel and the rollers. Each set of driven gears, i.e. the final drive gear or the particular gearbox ratio that you happen to be testing the car in, only absorbs about 1% to 2% of the engine's power.
Ok - so how do these software systems that supposedly measure transmission losses so as to "predict" back to the flywheel bhp work. The power curve at the wheels is taken in the usual way as explained above. Then, at peak rpm, the operator puts the car into neutral and lets the rollers slow down under the drag of the tyres and transmission. The software then measures this drag (or "coast down loss") as "negative" power and adds it to the wheel power to get back to the supposed flywheel power. BUT - and hopefully you've all spotted the problem now - the engine is not feeding any power into the drivetrain while the car is in neutral - in fact it isn't even connected to the drivetrain any more!! Whatever drag this is that's being measured it has nothing at all to do with the proportion of the flywheel power that gets lost as friction when the engine is powering the car in the normal way. The engine could now be an 800 bhp F1 engine or a 30 bhp mini engine for all it matters because it isn't connected to the gearbox or feeding any power into it. Obviously this "coast down loss" is something to do with the transmission and tyres but it is not the true transmission loss - in fact this coast down loss should never be expected to change for a given car regardless of how much you tune the engine whereas a true transmission loss will increase as the engine power increases because it is dependent to a large extent on the amount of power being fed into the transmission. I've seen a car that over time was tuned from 90 bhp at the wheels to 125 bhp at the wheels and the "coast down loss" stayed the same for every power run to within a fraction of a horsepower - exactly as you would have predicted. As the engine was tuned to give more power the "true" transmission losses must have also increased to some extent but these chassis dyno systems don't, and can't, show this happening.
So is there any way of really measuring the true transmission loss of a car? Yes - only one - by measuring the flywheel power on an accurate engine dyno, the wheel power on an accurate chassis dyno and taking one away from the other. There is no way on God's green earth of finding out the true transmission loss just by measuring the power at the wheels.
So hopefully that's got you all thinking a bit more now instead of just taking for granted the "flywheel" figure you were given last time you took your car to the rollers just because a nice man with some flashy equipment told you so. Even worse is the fact that some of these software systems allow the operator to just programme in the % transmission loss he wants the system to add to the wheel figures !!! So if that isn't a nice easy way to show some big fat flywheel bhp then I don't know of a better one. It's certainly a lot easier than actually doing some proper development work to make the engine perform better - just dial in a bigger transmission loss and bingo - the same wheel bhp now turns into a bigger flywheel bhp - happy customer, happy dyno man - just a shame it was all sleight of hand. See the end of this article if you doubt that this sort of thing really happens.
So what should you do when you take your car to a rolling road? Firstly, make sure you get printouts that show the wheel bhp and not just the flywheel bhp. Then at least you can see if they look sensible in comparison. If you have a desperate need to know the flywheel bhp then you will have to estimate it - there's no other way short of using an engine dyno. The corrections you need to make for cars with manual gearboxes are these:
The average front wheel drive road car with between 100 and 200 bhp loses about 15% of the engine bhp as transmission losses.
The average rear wheel drive road car with between 100 and 200 bhp loses about 17% of the engine bhp as transmission losses. The increase in % loss over front wheel drive is because the differential has to turn the drive through 90 degrees at the back axle which soaks up a bit more of the engine's power.
What your own specific car loses is anyone's guess - yours is as good as mine - but it shouldn't be far from the figures above. For sure though, no car in the world, unless it has flat tyres and a gearbox full of sand, loses anything like 30% of the engine's power in the transmission and tyres as many rolling road operators would try to have you believe. So take the wheel figure and divide by 0.85 for FWD or 0.83 for RWD and that will get you as close to the true engine bhp as you are ever going to know. In general though it is fair to say that low powered cars have higher % losses than high powered cars. For example, a 60 bhp Fiesta will have around 14 to 15 bhp total transmission and tyre loss whereas a 90 bhp XR2 will only have about 17 to 18 bhp loss - a smaller % obviously. By the time you get to cars with engines in the 300+ bhp range, losses can be down to 12% or so.
Another rule of thumb I use which is quite accurate is to treat the losses as being 10% of the flywheel power plus 10 bhp for FWD and 12% plus 10 bhp for RWD cars. This equation "loads" low powered cars more than high powered cars which is more closely like what happens in reality.
Remember, these percentages are not "gospel" - they are good realistic averages. The measured wheel bhp can change depending on tyre pressure, tyre size, suspension angles and other things which won't affect flywheel power - so the actual transmission loss % will also change. It pays to try and standardize as many of these things as possible if you intend to do a series of power runs over a period of time. Always use the same tyre pressure because this is a factor which can easily change from day to day.
Some time ago I had three almost identical race cars set up together in a group session at a rolling road. The engines were very similar except for minor differences in the camshafts fitted. One showed 118 bhp at the wheels, another showed 124 and the third showed only 98. The operator spent ages I'm told (I wasn't there) trying to find why the third car was so poor. It wasn't till the next day when that particular owner was checking things before the race that he noticed that the tyres only had 7 psi in them - the car had sat unchecked over the winter and no-one had bothered to standardize the pressures before the dyno test. In the race, that car went just as well as the other two and if anything was slightly the fastest of the three. That gives you some idea of how much power a set of flat tyres can absorb.
As you tune a particular car, the losses won't increase exactly in proportion to the power because as mentioned above, some components in the transmission have fixed losses which are not dependent on engine power. However, neither you nor the dyno operator will have any real idea of exactly how the losses have changed so you might as well just continue to apply the percentages above to give some sort of realistic guide to the new flywheel bhp.
What sort of % transmission loss do these software systems show? - well for normal road cars in the 100 to 200 bhp category, I've seen as high as 35% and as low as 10%. So take the same car with 100 bhp at the wheels to 2 different rollers and you might get anything from 110 bhp to 140 bhp being "predicted" as the flywheel figure. In reality 100 bhp at the wheels will be no more than about 120 bhp at the flywheel. If being told a bigger figure makes you happy then good for you - the car won't go any faster and you'll be no nearer to knowing whether you really got more power out of it than standard.
Another good way of bumping up the power figures on rolling road tests, as mentioned above under engine dynos, is by "playing about" with the air temperature and pressure corrections . If you dial in your own "standard" conditions as being freezing cold with the barometer going off the scale, or you put the temperature probe near the engine, you can get the system to add huge amounts of power to what was actually measured. So make sure you know if such corrections were made or not and to what standards they were made if any. Plenty of rollers still just quote the measured figure because they don't have computer systems to do the calculations.
Hopefully it should be apparent that 100 bhp is not just 100 bhp and end of story. It depends how it was measured, where it was measured, what corrections were applied and of course whether the dyno was even accurate in the first place. So I don't get too excited anymore when I see other people quote huge power outputs for their engine mods. If my engines still beat their ones on the track then they can quote whatever power figure they like. As the saying goes - "when the flag drops, the bull**** stops".
The moral of the story is clear - if you don't know the power at the wheels you don't know diddly-squat.
Any comments?
he`s saying it because a lot of people make wild claims about bhp figures or think that what they get told or show is the exact figure when it isnt.
I think it highlights that the only way to ensure that any tuning work being carried is working is to establish a base figure with a given rolling road, then use those techniques on the same rolling road with the same operator at the same load points.
Any improvement, or not, will then be as accurate as possible.
It doesn't matter what the catual numbers are, as long as an improvement can be verified.
man thats long lol
makes useful reading tho
the last rolling road i got has both fly wheel and at the wheel power output.
still needs to be re-dynoed tho :(
J333EVO said:
Any comments?
I agree, wheel power is the figure I go by as all others can be basically what ever you (or the dyno guy!) want to see.
I also agree with what rallycinq says, if you going to tune your car / bike, then always get it setup at the same dyno to be as accurate as possible. Even then it's not always possible to replicate the exact same conditions (ie, ambient temperature) as a previous run.
When I first had my bike dyno'd, it had 58hp at the wheels, which I was quite happy with. This was with just an endcan.
I then aquired a tasty twin pipe Jap exhaust and got it setup, but this time at a different dyno. The chart showed a substantial increase throughout the rev range - the "butt" dyno agreed, but to be a little more accurate on the increase, I should return to the original tuning shop.
Phew! Long post, but VERY informative. Think twice when you see a modded car for sale with outrageous rolling road power claims.
I totally agree with RallyCinq, in that the best way is to take a car to a recommended rolling road, have it tested, then take it back to the same rolling road after modifications have been made. Only then can a true indication of power gains be shown.
It would appear it's not the total amount of power shown by a modified engine, but the percentage increase over the standard engine that matters. Test as standard, then test again once mods are made.
And as for bhp, well, my little Uno produces a claimed 45hp, yet can cruise at 70mph all day and 80mph at a push. Down hill in the right conditions it can show a 100mph on the clock. All from 45hp?!!! ;)
Once again, though slightly nerdy and techy (some of us like that :p) , an excellent post J333EVO!
Anybody who has owned a good nick standard 899cc Cinq will say the same too.
In my Fiat Tipo Manual it has the Standard BHP of my engine and other Tipo Models.
If this is the same for all other cars what you could then do is take the car on a Rolling road and compare the reading with the manufacturers.
if there is say +10 BHP then you know the actual BHP, if you then continue to modifiy and test with exactly the same Dyno Set-up you wiill have an accurate result of the Actual BHP
eg:
Actual = 85bhp
Dyno = 95bhp
After Mods on Dyno = 135bhp
New Actual = 125bhp
And so on :)
