Ok heres the lookaround,
Firstly I couldn't find the multimeter, so I was off to a great start. Opened the bonnet and the rocker gasket has gone. Oil level about half way, oil didn't look that bad. Air filter did and was a bit oily. Brake fluid at the top and a good colour. Expansion tank? (See above post)
Heres the lambda sensor:
Underneath it looks pretty bloody solid. Sills appear to be original, is that possible?
The spare tyre is loose under the bonnet?
Ok, the boot that doesn't work, the button outside pushes in and then gets stuck. This is the only way I could get it open.
My ICE system.
The rear roof, i'm missing the elastic, the front one has torn too. The metal clip at the back is really loose. Tiewrapped shut at the minute.
Having said that, best idea ever!!!
When I opened the boot, water was coming out of the top left. Obviously the rear washer hose.
... and the steering wheel center came loose, how the hell does it go back on?
