The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Satellite Navigation
Old 26-01-2007   #1
Trader Rating: (0)
Using TomTom One navigation system
I am considering buying a TomTom One navigation system and I wondered if anyone in the group could comment on how easy it is to use in a GP.
Specifically I have wondered if the long sloping windscreen may make it difficult to find a convenient position for mounting using the supplied suction pad - ie it will either have to be too high up, or too far away. If it is high up the charging cable to the cigarette lighter socket is likely to be a nuisance.
Any comments appreciated.
James
Andrew56 is offline
Old 26-01-2007   #2
Chasing Cars
ChrisUK's Avatar
Trader Rating: (0)
ChrisUK has donated! United Kingdom
Re: Using TomTom One navigation system
James
Try tilting it and mounting it on the A-Pilar window that's where I put my TomTom although it wasn't the One version. As far as the windscreen goes it will go anywhere.
Present: 05 Punto Sporting 1.4 16v
ChrisUK is offline
Old 26-01-2007   #3
kip02's Avatar
Trader Rating: (0)
NO way will it fit there if you use the standard tomtom ONE holder, let you off seen as though you don't have one
The holder that you get with the ONE is really small. I either mount mine in the middle of the windscreen but it fits fine right next to the a-pilar window even with it powered from the car as the cable tucks neatly behind the steering wheel without much obstruction.
kip02 is offline
Old 27-01-2007   #4
Trader Rating: (0)
I use a Navman 503 because it came with all the maps for europe and a remote control - very important I think in a GP because the screen is so far away. It was just a shade over £200. No problem at all fits nicely centre screen. Everyone seems to think Tom Tom these days because of all the marketing. I've used both often and the Navman is just as good except you can't download all the silly voices and warning noises to it.
Old-Boy racer is offline
Old 27-01-2007   #5
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
My cheap Garmin came with a Disc which is stuck to the dash (the sticky pad is useless on the textured surface) but a Drop or two of Araldite epoxy solved that problem then you stick the suction cup to that.. the daft thing is araldite will just peel off which i wont need to do till i sell the car....
Andy Monty is offline
Old 27-01-2007   #6
Andy Monty's Avatar
Trader Rating: (0)
Old 27-01-2007   #7
Trader Rating: (0)
Just a point on sticking to the dash, it is quite neat and easier to reach but the satellites are blocked more by the roof in some instances so you might have more problems with them geting lost. The centre of the windscreen is best in this respect. That's why I wanted one with a remote control.
Old 27-01-2007   #8
Andy Monty's Avatar
Trader Rating: (0)
not had a problem with my Garmin aquiring satalites even on tree lined streets, suppose it depends on the quality of the antena along with the atmospheric condititions, cloud cover ect. My hand held GPS unit i have for mountain biking regularly drops reception in dense woodland... i dont have a solar reflect/ heated windscreen either which also blocks the signal apparently,,
Old 27-01-2007   #9
sdl
Trader Rating: (0)
I have a tomtom one and it fits nicely to the lower right of the windscreen. I can still reach it to tap thing in. and the cable , i don
t use as i charge it up in the house.
sdl is offline
Old 28-01-2007   #10
FastGP's Avatar
Trader Rating: (0)
FastGP has donated! United Kingdom
I did fit my tomtom 1 near rear view mirror.
Why?
1. Easy to control.
2. Can be seen inside the car
Bad point when charging.
Its Multijet, its red, its fast
FastGP is offline
Old 29-01-2007   #11
Trader Rating: (0)
i have it in exactly the same place and the cable fits fine round the back of the steering wheel just a little annoying around the gear stick but nothing major
elninio is offline
navigation system user-survey nikatnott Leisure Lounge 1 16-10-2006 15:34
Do you trust off-board navigation system coolbzl Leisure Lounge 1 30-05-2006 11:45
Running on water? gregit Auction Watch 28 11-11-2005 01:02
(T) Connect Satelite Navigation System porterdave Stilo 1 19-09-2005 11:16
Air Conditioning (climate system) controls ben743 Tipo 8 04-03-2005 14:31
