Thread Tools
Old 21-03-2010   #16
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Setup CD for Connect Nav+
Hi yamaheinz. Welcome to the FF.
Your current software version should be at the bottom right corner of the blue Fiat screen. I've never seen one without it.
There is another way to find out which software your CN+ is has with the self diagnostics menu.
Switch the CN+ on and wait a few minutes until it has fully started.
Press "Setup" then-
Press "CONNECT" (button 10,11 or 12) 4 times quickly then press "ENTER".
A new button labeled "SERVICE" or "AID" will apear on the screen.
Scroll down to the new button and press "ENTER"
There are 4 pages of diagnostic information you can step through. The second page should look something like this:
CD Changer........ Present
Amplifier............ Absent
SIM Card............Present
Key Signal......... ON
CAN Network......ON
SW Version........01N192L4009.8
HW Version........05035500242.0
FIAT Drawing.....735317569
The 6th line down on this CN+ shows 01N192L4009.8
9.8 at the end means this CN+ has software version 9.8
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 22-03-2010   #17
Germany
thanks for the quick response!
Here are 2 photos of my CN +
You see, the version number is not there.
If I at "Connect" 4 times quickly press the "Enter", nothing happens.
Regards
yamaheinz
yamaheinz is offline Reply With Quote Quote
Old 22-03-2010   #18
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Ahhh.... sorry, just read your original post again and seen that it's for a Croma. I assumed it was for a Stilo.
I've never tried the self diagnostic proceedure on the Croma version but it may be the same as for the Stilo.
You may have misunderstood my explaination of the Stilo process, it should be:
1.. Switch the CN+ on and wait a few minutes until it has fully started.
2.. Press "Setup".
3.. Press "CONNECT" (button 10,11 or 12) quickly, 4 times.
4.. Press "ENTER".
5.. A new button labeled "SERVICE" or "AID" should apear on the screen.
6.. Scroll down to the new button and press "ENTER"
Sometimes you need to go through the process a few times before the "SERVICE" or "AID" button appears.
On some Stilo CN+s I've found it works better if at 3..Press "CONNECT" you press "CONNECT" once then wait 1 second then press it quickly, 3 more times.
If none of this works for you, then perhaps the Croma version doesn't have the self diagnostic proceedure. Even if you do find the software version your CN+ has, I have never seen any updates for the Croma version.
Old 22-03-2010   #19
Germany
Hello
have found the number.
SW 01N194L4011.0
Is this the latest version?
Regards
yamaheinz
Old 22-03-2010   #20
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Ahhh.. good, did the self diagnostic procedure work for you this time?
Version 11 is the latest version available for the Stilo. As I said above, I've never seen any updates for the Croma so I don't know if 11 is the latest for the Croma.
The software update discs are not available for sale from Fiat because the updates are supposed to be done only by a Fiat dealer.
There is, however, a setup disc that is needed to change the language from Italian after the software has been updated.
I have just checked on ePER, the Fiat parts catalogue, and the part number for the Stilo and Croma setup disc is the same. This may mean that the software is also the same.
There is a company in Germany that repair Magneti Marelli Connect Nav+s. They may be able to give you more information.
http://www.pavlek.de/fiat/index.htm
Please tell us if you find any more information.
Old 23-03-2010   #21
Germany
Hello
Many thanks for your help and info.
Pavlek I'll call and ask.
Regards
yamaheinz
Old 13-05-2010   #22
Netherlands
I would like to know how i can access the hidden menu in the Croma
(2005) connect nav+. Everywhere i search the net i find explenations for the stilo. Who can help.
crusadernl is offline Reply With Quote Quote
Old 03-11-2010   #23
Serbia
Hi friends,
Can someone help me to enter service menu on Fiat Croma?
Darko
darko79 is offline Reply With Quote Quote
Old 03-11-2010   #24
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Hi, Welcome to the FF.
I think it's the same as the Stilo. See post #18 above.
Old 04-11-2010   #25
Serbia
Hi friends,
Not same because doesn't have SETUP button on Connect Nav+ for Fiat Croma. Other solution?
Darko
Old 04-11-2010   #26
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
It seems as though you have to press the " TRIP " button on the Croma Connect Nav units to get to the " SETUP " and " CONNECT " menus.
The setup screen is shown on the picture in post #17 above and in the diagram from the Connect Nav+ owner's handbook below.
If you don't have a handbook, you can download one from here:
http://www.fiatforum.com/downloads.php?do=cat&id=19
Old 04-11-2010   #27
Serbia
Thanks friend. It works.
Darko
Old 24-12-2010   #28
Belarus
Hi!
I'm from Belarus/ eastern Europe. near Russia/ My car is Ulysse 2.
Has anybody seen the Belarus map for Connect Nav+ Fiat Ulysse? Or where i can find it? much money for this map!!!!!
my answer for myself - it's impossible! ...
Help please!!!
Treo is offline Reply With Quote Quote
Old 24-12-2010   #29
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Fiat or Navteq never made a map disc for Belarus for the Connect Nav+.
Old 24-12-2010   #30
Belarus
Quote Originally Posted by Davren View Post
.....That's very very bad! what's about Russia map? also is absent???
Thread Tools
(T) Connect NAV+ 9.8 Update CD & Setup CD peterdif Stilo 111 09-07-2017 09:18
(T) Connect Nav+ Setup disc 9.7 Bazarooney Stilo 27 25-03-2012 20:31
(G) Setup disc for connect nav+ MATMAT Stilo 4 18-04-2010 21:29
(T) Connect Nav (not +!) setup cd quash Stilo 9 06-03-2009 01:51
(T) Connect nav and Connect nav+ whats the difference??? donradious Stilo 1 14-11-2006 22:28
