The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Satellite Navigation
Old 20-05-2008   #1
Trader Rating: (0)
Exclamation Navman n40i Won't Adhere!!!
My N40i will not stick to my SeiSporting windscreen at all!
The flattest part seems to be just under the mirror, but it won't even stick their either. I've cleaned the glass many times (and the suction cup)
H E L P !!!!!!
Frank.
Frank S is offline
Old 20-05-2008   #2
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
Re: Navman n40i Won't Adhere!!!
well firstly the windscreen of the sei isnt that curved so i couldnt see that being a problem. simple what to check it is a small flat object, like a coaster, put it up on the area your tryin to stick the satnav adn see if there much a gap in the middle. if there is move the coaster about to see if you can find a flatter area
also from what i can remember the n40 is a quite old about 2 years so is relativly big this could be a problem if the suction cup is a pressure one as these arent as effective as the ones which use a lever mechanism to pull the centre of the cup up to make the enclosed volume larger
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
Old 21-05-2008   #3
Trader Rating: (0)
...It's definately the factory-supplied suction cup that's at fault; just tried a small Street Pilot mount and it sticks fast, even to the far right of the steering wheel. The original suction cup is just way too wide and has very little suction.
Trouble is, the ball is slighlty larger and won't seat properly in the n40i socket, otherwise this would have been perfect. It holds the weight of the n40i well, so what I need is a small surface area clamped cup...
Frank
Frank S is offline
Old 21-05-2008   #4
*custom name*
j0nny's Avatar
Trader Rating: (0)
yea pretty much, go into halfords or some place like that, bring your sat nav and check and see if any of the sat nav model balls fit in yours, get one with a lever. garmins suction cup is much better than tom tom and when using it your will see why
j0nny is offline
Old 28-05-2008   #5
Trader Rating: (0)
Another cause can be grease on the windscreen. Happens with time. Get some newspapers and distilled transparent vinegar (or transparent window cleaner), clean the windscreen and the suction cup, try again.
Don't forget to ventilate the car afterwards thoroughly as vinegar stinks lol
cojones is offline
Old 28-05-2008   #6
Trader Rating: (0)
Just remembered, warm water & lemon juice works just as good as vinegar, and smells far better.
cojones is offline
Old 28-05-2008   #7
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
Originally Posted by j0nny View Post
Garmins suction cup is much better than tom tom and when using it your will see why
Garmin's are better than TomTom full stop
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 31-05-2008   #8
Freddy Is All Teeth
fiatdrivingfan's Avatar
Trader Rating: (0)
fiatdrivingfan has donated! United Kingdom
Can't argue with that
Haven't you got a dash mounting thingy..... its a solid disc that sticks to the dashboard and the satnav sits on that.
Time flies like an arrow, fruit flies like a banana.
fiatdrivingfan is offline
Old 01-06-2008   #9
*custom name*
j0nny's Avatar
Trader Rating: (0)
that just a flat bit of plastic that imitates a windscreen for cars or vans wer the windscreen is too far away so they suck to that instead. you can copy this by using a coaster of something of that nature
i own a garmin but quite like tom toms ability of map corrections which i wish mine could do
j0nny is offline
navman s30 AMAZINGLENNIE Satellite Navigation 6 15-07-2008 13:12
Navman iDN 3000 lifeline Satellite Navigation 1 01-04-2008 23:40
Navman S90i and TMC barbarian Satellite Navigation 3 06-12-2007 22:45
Navman The Hunter Satellite Navigation 27 14-06-2007 11:03
Navman maps The Beast Satellite Navigation 9 20-02-2007 11:46
