The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > Satellite Navigation
Old 13-06-2007   #1
V.Owen-V.Yellow-V.500
OXCiD3's Avatar
Trader Rating: (1)
OXCiD3 has donated! United Kingdom
Exclamation Having problems with your satnav. try this:
Ok, i realise there are thousands of potential problems out there when it comes to satnav systems, but having worked with them for over 3 years, i have found that the majority of them can be fixed by pressing a couple of buttons.
so depending on your manurfacturer/unit here are some "insider" secrets (one of which i only learned last week) of how to do a FULL reset on a unit.
First up tomtom
TOMTOM ONE
on the tomtom one the reset button is quite obvious, if the unit freezes try prodding (gently) with a pin. the unit will reboot and hopefully problem solved...
if not, try turning the unit off then press and hold the power button AND the reset button for around 10 seconds, then power up the unit.
right now i cant remember how to get in to the maininance menu on tomtoms but i will add this info when i remember.
Tomtom 510/710/910
The same applies as above but the reset button is harder to find, to find it turn the unit upside down and find the gold pins that the mount hooks up to.
there will be a plastic rim to this with a notch taken out of it
-----u--
The reset button is inside that notch, prod it with a pin.
Garmin
Now garmin have gone a slightly different way, they allow users to access the mainenence menu, and to be akward they changed how to do it on every single unit.
if i recal correctly;
steps 1 and 2 are the same
just change 3 depending on unit
1: turn off the unit
2: press the power button whilst at the same time pressing the:
3:
310d: bottom left corner of the screen
660: bottom right corner of the screen
510d: volume down button
200/250: bottom left corner of the screen
This will bring up the mainenence menu where you will be able to reset all the features of the unit. BE CAREFUL AS YOU COULD SERIOULSY DAMAGE YOUR UNIT BY PLAYING AROUND WITH THIS!!!
NAVMAN
similar to farmin navman use a maintinance menu system, to access it (on the f series and n series)
turn off the unit, the press and hold the menu button (looks something like this
whilst holding that press the power button.
this will bring up the menu where you can reset everything propery as they do in the factory.
but again BE CAREFUL AS YOU COULD SERIOULSY DAMAGE YOUR UNIT BY PLAYING AROUND WITH THIS!!! I TAKE NO RESPONSABLITY FOR ANY DAMAGE!
i hope this helps you in some way,
i will update this when ever i hear any more (and remember the bits i've forgotten.. what can i say it's 2am...)
Owen
~~ REDDOT Racing ~~
RIP REDDOT JTD
"Luigi follow only the ITALIAN cars"
OXCiD3 is offline
vB code is On
Punto starting problem(s)... Please help!!! kwestcott Punto > Technical 4 05-10-2005 08:19
Uno 45 999cc Fire problems DJ Binks Uno > Technical 5 18-07-2005 18:59
CONSTANT problems with automatic clutch! any ideas Lisa82 Cinq/Sei > Technical 0 25-02-2004 15:53
Problems with car + Warrenty...please help! Sando Lets Talk FIAT 6 06-09-2003 01:57
Problems and warrenty...please heeeeeeelp! Sando Cinq/Sei > Technical 0 05-09-2003 13:25
